lou
lou
Removing leading zeroes in a character column
Can Regex be used to strip leading zeroes from values in a character column?  If so, please provide an example.  If not, is there another method?
When leading zeroes occur, the number of leading zeroes can vary.  There are values in this column that are non-numeric.
Thanks,
Lou
vince_faller
Re: Removing leading zeroes in a character column
This works for me
dt = New Table( "Example",
	Add Rows( 3 ),
	New Column( "test",
		Character,
		"Nominal",
		Set Values( {"000123", "0AB", "XYZ", "ABC0"} )
dt << New Column("No Leading zeroes", character, <<Formula(Regex( :test, "^0*(.*)", "\1" )));
Vince Faller - Predictum
I am not a regex coder, but here is a real simple example of how to do this using other JSL functions:
	Add Rows( 3 ),
	New Column( "test",
		Character,
		"Nominal",
		Set Values( {"000123", "0AB", "XYZ"} )
For each row(
	while(substr(:test,1,1)=="0",
		:test = substr(:test,2)
vince_faller
This works for me
	Add Rows( 3 ),
	New Column( "test",
		Character,
		"Nominal",
lou
lou
Thanks!  That is what I needed.
