Jackie_
Remove "" from the list
Hi @txnelson ,
I am trying to remove quotation mark "" from the list.
The sitenum should have following results = {1, 2} no quotation mark. Any suggestions?
new window("", modal,
		ht = checkbox({"1","2"}),
			Buttonbox("Ok",
				get = ht << get selected();
sitenum ={};
Insert Into( sitenum, get);
Re: Remove "" from the list
Does this do what you need?
			Buttonbox("Ok",
sitenum ={};
for(i=1,i<=nitems(get),i++,
	get[i]=num(get[i])
If you have JMP16 and can be sure that the options will be numeric (which will be converted to strings), you could use Transform Each
New Window("test",	<< modal,
	ht = Check Box({"1", "2"}),
	Button Box("Ok",
sitenum = Transform Each({str}, get, Num(str));
In general looping over the get list while converting the strings to numeric using Num() and adding them to a list in some way should work.
Georg
In these cases (if different values are needed for display and internal processing) I like to use associative array like you can see in the below example.
site_aa = Associative Array( {{"Site 1", 1}, {"Site 2", 2}} );
New Window( "test",
	<<modal,
	ht = Check Box( site_aa << get keys ),
	Button Box( "Ok", get = ht << get selected() )
site_lst = {};
For Each( {value}, get, Insert Into( site_lst, site_aa[value] ) );
Show( site_lst );
Georg
Byron_JMP
and yet another solution.
In this case, I don't get rid of the quotes, I just use the list item as a number rather than a string.
			Buttonbox("Ok",
sitenum ={};
print(sitenum);
site=num(sitenum[1]);
print(site);
