yossih
Remove "Std Dev Chart" by default in JMP in Variability Charts
I'm new using JMP ...
Each time I create a Variability chart a "Std Dev Chart" is also created. i want to avoid removing it each time.
How do I remove "Std Dev Chart" *by default* in JMP in Variability Charts?
David_Burnham
Re: Remove "Std Dev Chart" by default in JMP in Variability Charts
To change default preferences for any platform, including the Variability Chart:
1. From JMP's File menu select Preferences.
2. From the list of Preference Groups select Platforms.
Now you can select Variability Chart - and change the default behaviour.
-Dave
David_Burnham
-Dave
yossih
Hi Dave,
