paul_apicella
Remove columns from a table
Hi everybody,
I need to export several tables (txt files containing 20 columns) under JMP, but only 10 columns are useful for my use.
How can I include in a script the deleting of specified columns? I have attached one example file: (1) the txt source (2) the JMP version with all columns (3) the final JMP version with 10 columns.
Thanks in advance,
Paul
Re: Remove columns from a table
Here is the very simple script to delete the unwanted columns.
names default to here(1);
dt=current data table();
dt << delete columns("I-delai", "I-durée", "I-pos",
	"R-delai", "N°-Rec", "E-durée", "TR-max", "TM-max",
	"code-PP", "cod-R-d");
The details are covered in the scripting index
     Help==>Scripting Index
To get started with scripting, I suggest you read the Scripting Guide
     Help==>JMP Documentation Library==>Scripting Guide
paul_apicella
Thanks txnelson,
You're absolutely right, the solutions (at least the simple ones) are in the scripting guide. We're always in a hurry to take the time to check it out.
All works well.
Have a good day
Paul
