Polygon0516
Remove Duplicate Entries from SQLQuery Based on Date
I've tried to use this video linked below to use the SQLQuery function. However, I'm having an issue.
community.jmp.com/t5/video/gallerypage/video-id/tvcW9lZTE6Ie3IFXxeru0AYNqvj5AB5r
Problem: Take Table 2 with "cylinder" "Received_Date" and "lot" & merge that into Table 1 that has "batch", "cylinder" and "Batch_Date"
I need to match exactly on "Cylinder" and then take the nearest backward "Received Date" to the "Batch Date" (Batch_Date >= Received_Date).
I created the query & also did the step to create a numeric tag that should theoretically provide only 1 unique lot number for each batch (not shown in table below)
However, this is what I'm getting
BatchBatch DateCylinder NumberLot NumberReceived Date
12/13/2023 55A6/14/2022
12/13/2023 55B10/21/2022
12/13/2023 55C11/30/2022
There should only be 1 row populated from the query (should be the last row 11/30/2022); the other ones are "ghosts" as we only made 1 "Batch 1"
Any help on how to improve the SQL code to prevent duplicate entries & pick the entry only if the received date is the closest <= batch date?
This was the code from the SQLQuery interface that was given
SELECT DISTINCT t1.Batch, t1.Batch_Date AS Date, t1.Cylinder_Number,
t2.Lot_Number, t2.Cylinder_Number AS "Cylinder_Number 2", t2.Lot_Date AS "Date 2", MIN(t2."Batch Num") AS "Minimum-Batch Num"
FROM "Table 1" t1
LEFT OUTER JOIN "Table 2" t2
ON ( ( t1.Cylinder_Number = t2.Cylinder_Number ) AND ( t1.Cat_Date >= t2.Lot_Date ) )
GROUP BY t1.Batch, t1.Batch_Date, t1.Cylinder_Number,
t2.Lot_Number, t2.Cylinder_Number, t2.Lot_Date;
10 REPLIES 10
Re: Remove Duplicate Entries from SQLQuery Based on Date
Which error are you getting?
They should go inside Custom SQL() part (I tried it and it did work just fine with the t2."wt%")
	CustomSQL(
		"\[SELECT
			t1.Cylinder,
			t1.Batch,
			t1."Batch Date",
			t2."Received Date",
			t2.Supplier,
			t2.Lot,
			t2."wt%"
		FROM t1
			LEFT OUTER JOIN t2 ON
				t1.Cylinder = t2.Cylinder
				AND t1."Batch Date" >= t2."Received Date"
If you want all columns from t2, I think the SQL JMP is using supports t2.*
