Polygon0516
Remove Duplicate Entries from SQLQuery Based on Date
I've tried to use this video linked below to use the SQLQuery function. However, I'm having an issue.
community.jmp.com/t5/video/gallerypage/video-id/tvcW9lZTE6Ie3IFXxeru0AYNqvj5AB5r
Problem: Take Table 2 with "cylinder" "Received_Date" and "lot" & merge that into Table 1 that has "batch", "cylinder" and "Batch_Date"
I need to match exactly on "Cylinder" and then take the nearest backward "Received Date" to the "Batch Date" (Batch_Date >= Received_Date).
I created the query & also did the step to create a numeric tag that should theoretically provide only 1 unique lot number for each batch (not shown in table below)
However, this is what I'm getting
BatchBatch DateCylinder NumberLot NumberReceived Date
12/13/2023 55A6/14/2022
12/13/2023 55B10/21/2022
12/13/2023 55C11/30/2022
There should only be 1 row populated from the query (should be the last row 11/30/2022); the other ones are "ghosts" as we only made 1 "Batch 1"
Any help on how to improve the SQL code to prevent duplicate entries & pick the entry only if the received date is the closest <= batch date?
This was the code from the SQLQuery interface that was given
SELECT DISTINCT t1.Batch, t1.Batch_Date AS Date, t1.Cylinder_Number,
t2.Lot_Number, t2.Cylinder_Number AS "Cylinder_Number 2", t2.Lot_Date AS "Date 2", MIN(t2."Batch Num") AS "Minimum-Batch Num"
FROM "Table 1" t1
LEFT OUTER JOIN "Table 2" t2
ON ( ( t1.Cylinder_Number = t2.Cylinder_Number ) AND ( t1.Cat_Date >= t2.Lot_Date ) )
GROUP BY t1.Batch, t1.Batch_Date, t1.Cylinder_Number,
t2.Lot_Number, t2.Cylinder_Number, t2.Lot_Date;
Re: Remove Duplicate Entries from SQLQuery Based on Date
This is quite close to the limit on what I would attempt to do with JMP's limited SQL capabilities (at least when using data tables). It is most likely simpler to use SQL + JSL
res = New SQL Query(
	Version(130),
	Connection("JMP"),
	JMP Tables(
		["t1" => "$DOWNLOADS\Table1-1.jmp",
		"t2" => "$DOWNLOADS\Table 2-2.jmp"]
	QueryName("SQLQuery2"),
	CustomSQL(
		"\[SELECT
			t1.Cylinder,
			t1.Batch,
			t1."Batch Date",
			t2."Received Date",
			t2.Supplier,
			t2.Lot
		FROM t1
			LEFT OUTER JOIN t2 ON
				t1.Cylinder = t2.Cylinder
				AND t1."Batch Date" >= t2."Received Date"
) << Run;
res << select where(Row() == Col Max(Row(), :Cylinder, :Batch) | Is Missing(:Lot));
res << Invert Row Selection;
res << delete rows;
10 REPLIES 10
Are these JMP tables you are performing the SQL query to? Can you share the tables?
Polygon0516
Just replied to the main thread with the files, thanks for reaching out
	Version(130),
	Connection("JMP"),
	JMP Tables(
	CustomSQL(
		"\[SELECT
			t1.Cylinder,
			t1.Batch,
			t1."Batch Date",
			t2."Received Date",
			t2.Supplier,
			t2.Lot
		FROM t1
) << Run;
res << delete rows;
Polygon0516
Hello - thank you for the quick help! I tried the macro & unfortunately for some items it is keeping the oldest possible date. It doesn't appear to be doing this for all entries though ( see last row of the table below).
So this is a definite improvement that there aren't multiple rows for the same batch, but it's not consistently pulling the right lot/received date for that batch in question.
Example
CylinderBatchBatch DateReceived DateSupplierLot Should Be Received Date
822738/9/20235/20/2022B55 6/22/2023
322748/10/20235/20/2022B55 6/22/2023
222758/11/20235/20/2022B55 6/22/2023
1022768/12/20235/20/2022B55 6/22/2023
622778/12/20235/20/2022B55 6/22/2023
922788/13/20235/20/2022B55 6/22/2023
122798/14/20235/20/2022B55 6/22/2023
21222808/15/20236/22/2023B74 (file is correct)
I'm not really sure how to read your table. If I take a look at Table 2-2 there is only 1 row for Cylinder 1 which has Received date 05/20/2022
Polygon0516
Hi - replying to keep the topic active. I think something occurred when I updated my file to remove proprietary information. I will look at it more tomorrow & will get back to you with a reply.
Polygon0516
Thank you for this assistance! I realized there was an error within my original data set (I modified it for entry on this website to anonymize the data). This code has been working well, will reach out with any other questions.
Polygon0516
Here are the files - sorry, meant to attach these.
Table 1-1 and Table 2-2 are as described above.
Query Results shows the final table where there are multiple entries for each batch (but there should only be 1 entry per batch as described above).
Polygon0516
One last question - how can I add where more columns are pulled over from Table 2 into the final query table, even if I'm not using them as a match criteria?
I tried adding into your code above a t2."wt%" column but the code now throws me an error. I have other columns I'd like to pull in at the same time (about 10 columns in total) but not sure how to do this without getting an error.
Thank you!
