hogi
Level XIII
Remove Caption Legend
The legend of the caption box is partially redundant in combination with the legend on the right.
In addition, it collides with the numeric entries.
Is there a setting to hide the legend of the caption?
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
gb = Graph Builder(
	Graph Spacing( 4 ),
	Variables( X( :age ), Y( :height ), Overlay( :sex ) ),
	Elements(
		Box Plot( X, Y, Legend( 4 ) ),
		Caption Box( X, Y, Legend( 5 ), Summary Statistic( "Mean" ), Location( "Graph per factor" ) )
hogi
Level XIII
Re: Remove Caption Legend
workaround via JSL:
segs = Report( gb )[FrameBox( 1 )] << find segs( "Text Seg" );
segs[1] << set text( "" ); // the caption box legend
gb << set dirty;
hogi
Level XIII
workaround via JSL:
gb << set dirty;
hogi
Level XIII
Hm, no real solutions?
Then I will mark the workaround as a "solution".
