drblove
Regex to pull file from path with JSL
I am sure this is a straightforward answer to this question, but if I have the following:
full_path[i] = "C:\dir1\dir2\dir3\dir4\file.xlsx"
and I want to get just "file.xlsx" and the directory depth is variabile, i.e. maybe 2 directories maybe 5, how would I do it?  In Perl I would split the string into an array by the \ and grab the last part of the array, but not sure how to do this in JSL.  Any help would be appreciated!
Re: Regex to pull file from path with JSL
word ( -1, full_path[i], "\" )
You can use negative values, in the word() function, so -1 gives the last word, using the delimiter of choice.
You can use the JSL function Words() to separate a path into its component part, and then take just the last piece. Example:
full_path = {"C:\dir1\dir2\dir3\dir4\file.xlsx"}; i = 1; // setup
full_path[i] = "C:\dir1\dir2\dir3\dir4\file.xlsx";
filename = Words(full_path[i], "\"); // separate the path based on the backslash as a delimiter - returns a list
filename = filename[N Items(filename)]; // get the last string in the list
"file.xlsx"
Jeff_Perkinson
Try the Words() function.
full_path = "C:\dir1\dir2\dir3\dir4\file.xlsx";
listofwords=words(full_path, "\");
filename=listofwords[nitems(listofwords)];
"file.xlsx"
-Jeff
ms
Super User (Alumni) ms
Two examples of how it could be done:
//Regex (fails if filename contains non-word characters)
file1 = Regex(full_path, "[\w.]+$");
// Split string
file2 = Reverse(Words(full_path, "\"))[1];
Show(file1, file2);
drblove
This is a great solution, one line.  Thank you very much!
