- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Reference line
Hi, I'm trying to edit a graph builder script to use my table variables instead to plot the reference lines in the graphs. it's a plot of pressure drop vs dates. I have no issues with the y axis reference line, but the x axis reference line is giving me issues. I tried using the Date MDY() function to incorporate my table variables but it's not working.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Reference line
- Is the X axis a numeric column?
- Is the X axis a JMP Date/Time column?
- Table variables are all character strings. Are you trying to use it as a character, and the X axis is a numeric. If so, you need to convert it to a numeric.
- Can you provide a sample data table, and a sample of the graph?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Reference line
Hi, x axis is a date/time column while y axis is a numeric continuous column. I plotted y vs x and saved the graph as a script. The reference lines were manually added inside e.g. y axis = 7, and x axis = 9/1/2023.
I then created a table variables called dp limit with a value of 7. I edited the graph script and replaced the reference line input to :dp limit, and it worked. So when I changed the dp limit variable, the graph reference line is changed. I can't do the same for the x axis reference line. It's a series of numbers in the script which I think is the date/time in seconds format. I'm not sure what I should input as a table variables for it to work. Hope this is clearer, thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Reference line
The table variable is a character string, as I mentioned before. The JMP DateTime values are the number of seconds since January 1, 1904. So before you can use the table variable, it needs to be converted into a DateTime value. In the JSL below, I choose to use an Informat() function to convert the value.
dt = New Table( "Example",
Add Rows( 355 ),
New Table Variable( "Reference Date", "07/15/2001" ),
New Column( "Event Date",
Format( "m/d/y", 12 ),
Input Format( "m/d/y" ),
Set Values(
[3061584000, 3061584000, 3061756800, 3061756800, 3062016000, 3062102400, 3062275200, 3062275200, 3062361600, 3062361600, 3062620800,
3062707200, 3062880000, 3062966400, 3063052800, 3063139200, 3063139200, 3063139200, 3063398400, 3063484800, 3063830400, 3064089600,
3064089600, 3064089600, 3064262400, 3064262400, 3064348800, 3064348800, 3064435200, 3064435200, 3064435200, 3064608000, 3064608000,
3064694400, 3064780800, 3064867200, 3064867200, 3064953600, 3065040000, 3065040000, 3065040000, 3065126400, 3065299200, 3065299200,
3065385600, 3065472000, 3065558400, 3065731200, 3065990400, 3066163200, 3066422400, 3066681600, 3066854400, 3066940800, 3066940800,
3066940800, 3067027200, 3067200000, 3067804800, 3067891200, 3067891200, 3068064000, 3068236800, 3068409600, 3068582400, 3068668800,
3068755200, 3068841600, 3068841600, 3068841600, 3068928000, 3069014400, 3069014400, 3069360000, 3069446400, 3069532800, 3069619200,
3069619200, 3069705600, 3069705600, 3069705600, 3069878400, 3070051200, 3070051200, 3070310400, 3070310400, 3070396800, 3070483200,
3070742400, 3070742400, 3070742400, 3070915200, 3071088000, 3071174400, 3071260800, 3071260800, 3071433600, 3071433600, 3071520000,
3071865600, 3071952000, 3071952000, 3072384000, 3072384000, 3072470400, 3072470400, 3072556800, 3072556800, 3072556800, 3072643200,
3072643200, 3072729600, 3072816000, 3072988800, 3073075200, 3073248000, 3073334400, 3073334400, 3073334400, 3073507200, 3073507200,
3073680000, 3073680000, 3073766400, 3073766400, 3073766400, 3073852800, 3073852800, 3073852800, 3073939200, 3074284800, 3074284800,
3074371200, 3074371200, 3074371200, 3074371200, 3074371200, 3074371200, 3074457600, 3074630400, 3074630400, 3074716800, 3074976000,
3074976000, 3075062400, 3075235200, 3075321600, 3075321600, 3075408000, 3075494400, 3075494400, 3075494400, 3075494400, 3075494400,
3075494400, 3075494400, 3075667200, 3075926400, 3075926400, 3076012800, 3076099200, 3076185600, 3076185600, 3076272000, 3076272000,
3076272000, 3076876800, 3076876800, 3076963200, 3077222400, 3077308800, 3077308800, 3077568000, 3077568000, 3077654400, 3077654400,
3077740800, 3077827200, 3077827200, 3077913600, 3077913600, 3078000000, 3078000000, 3078172800, 3078259200, 3078345600, 3078432000,
3078518400, 3078518400, 3078518400, 3078518400, 3078518400, 3078604800, 3078604800, 3078691200, 3078777600, 3078777600, 3078777600,
3078950400, 3078950400, 3078950400, 3079123200, 3079123200, 3079123200, 3079123200, 3079123200, 3079209600, 3079296000, 3079296000,
3079382400, 3079382400, 3079468800, 3079468800, 3079641600, 3079728000, 3079728000, 3079814400, 3079814400, 3079814400, 3080160000,
3080160000, 3080246400, 3080246400, 3080332800, 3080332800, 3080419200, 3080419200, 3080505600, 3080592000, 3080678400, 3080851200,
3081024000, 3081024000, 3081024000, 3081196800, 3081283200, 3081283200, 3081369600, 3081369600, 3081369600, 3081456000, 3081456000,
3081456000, 3081456000, 3081542400, 3081628800, 3081715200, 3081715200, 3081715200, 3081715200, 3081888000, 3081974400, 3082060800,
3082060800, 3082060800, 3082492800, 3082492800, 3082492800, 3082492800, 3082752000, 3082838400, 3082838400, 3082838400, 3082924800,
3083011200, 3083011200, 3083011200, 3083011200, 3083270400, 3083443200, 3083961600, 3084134400, 3084134400, 3084220800, 3084480000,
3084566400, 3084566400, 3084739200, 3084912000, 3084912000, 3084998400, 3084998400, 3085084800, 3085257600, 3085516800, 3085516800,
3085776000, 3086035200, 3086035200, 3086208000, 3086208000, 3086294400, 3086294400, 3086380800, 3086467200, 3086467200, 3086553600,
3086553600, 3086553600, 3086553600, 3086640000, 3086985600, 3087072000, 3087244800, 3087244800, 3087331200, 3087590400, 3087590400,
3087590400, 3087676800, 3087676800, 3087763200, 3087936000, 3088022400, 3088195200, 3088281600, 3088368000, 3088368000, 3088368000,
3088454400, 3088540800, 3088627200, 3088713600, 3088713600, 3088886400, 3088972800, 3089145600, 3089145600, 3089232000, 3089232000,
3089232000, 3089232000, 3089664000, 3090009600, 3090096000, 3090268800, 3090355200, 3090528000, 3090700800, 3090700800, 3090700800,
3090787200, 3090873600, 3090960000, 3090960000, 3090960000, 3090960000, 3091132800, 3092083200, 3092256000, 3092342400, 3092428800,
3092428800, 3092515200, 3092601600]
New Column( "Total Fatal Injuries",
Set Values(
[2, 0, 1, 1, 1, 2, 9, 2, 1, 1, 2, 0, 2, 1, 2, 4, 2, 2, 10, 1, 2, 2, 2, 2, 2, 2, 1, 1, 0, 2, 1, 1, 2, 2, 2, 5, 2, 4, 2, 4, 4, 1, 3, 4, 3,
1, 2, 1, 1, 1, 1, 2, 1, 1, 1, 2, 1, 4, 1, 1, 2, 2, 1, 1, 3, 18, 1, 1, 1, 1, 2, 1, 1, 2, 2, 2, 2, 1, 3, 1, 2, 1, 1, 1, 1, 1, 1, 4, 2, 1, 1,
2, 1, 1, 1, 2, 1, 1, 2, 1, 2, 1, 2, 2, 1, 1, 4, 1, 2, 1, 2, 1, 1, 2, 1, 3, 1, 2, 1, 2, 2, 1, 1, 1, 1, 1, 3, 3, 1, 4, 2, 2, 1, 3, 1, 1, 1,
5, 1, 1, 3, 1, 2, 2, 3, 1, 1, 2, 1, 2, 1, 1, 1, 1, 1, 1, 1, 2, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 1, 1, 1, 2, 6, 1, 1, 1, 4, 1,
1, 3, 1, 2, 2, 2, 2, 1, 1, 2, 3, 1, 2, 1, 1, 1, 1, 1, 4, 2, 1, 1, 1, 6, 6, 1, 2, 2, 2, 1, 1, 2, 2, 1, 1, 2, 1, 2, 1, 6, 3, 2, 1, 2, 1, 2,
2, 2, 3, 3, 1, 1, 1, 1, 1, 2, 1, 1, 2, 2, 1, 1, 2, 1, 2, 2, 1, 1, 3, 1, 1, 3, 1, 1, 1, 3, 2, 1, 2, 1, 1, 92, 65, 64, 44, 1, 1, 1, 2, 1, 1,
1, 3, 1, 1, 1, 3, 2, 1, 2, 1, 10, 1, 1, 2, 2, 3, 3, 2, 1, 1, 1, 1, 2, 1, 2, 1, 1, 1, 2, 1, 2, 1, 3, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 265, 4,
2, 1, 2, 1, 1, 1, 1, 5, 1, 1, 2, 2, 2, 2, 2, 4, 1, 2, 1, 4, 2, 1, 2, 2, 3, 1, 3, 4, 1, 2, 3, 2, 1, 1, 1, 1]
gb = Graph Builder(
Size( 531, 464 ),
Variables( X( :Event Date ), Y( :Total Fatal Injuries ) ),
Elements( Points( X, Y, Legend( 5 ) ) ),
Dispatch(
"Event Date",
ScaleBox,
{Min( 3059894016 ), Max( 3093859584 ), Interval( "Month" ), Inc( 1 ),
Minor Ticks( 1 ), Label Row( Label Orientation( "Angled" ) )}
Dispatch(
ScaleBox,
{Format( "Best", 10 ), Min( -0.147373575211003 ),
Max( 11.0505783676065 ), Inc( 2.5 ), Minor Ticks( 0 )}
gbr = gb << report;
refDate =informat(:Reference Date, "m/d/y");
gbr[axisbox(1)] << add ref line( refDate );
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Reference line
Thanks that solved my problem, I just added Informat(:variable) into the ref line input and that solved the problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Reference line
Jim probably asked the right question, but here's an example Use Summary to Automatically Add Reference Lines to Graph Builder
