Georgios_Tsim
Reference Lines in Variability Chart taken from a list using for loop
I have a list say "myList"  that contains a dynamic number of elements. I would like to add reference lines taken from the list in the following variability charts
Variability Chart(
					Y( :Value),
					X( :Time Point, :Storage Condition, :Level ),
					Std Dev Chart( 0 ),
					By( :Parameter ),
						Dispatch(
							{"Variability Chart for Value"},
							"Variability Chart",
							FrameBox,
							{Row Legend(
								:Label,
								Color( 1 ),
								Color Theme( "JMP Default" ),
								Marker( 0 ),
								Marker Theme( "" ),
								Continuous Scale( 0 ),
								Reverse Scale( 0 ),
								Excluded Rows( 0 )
If there is a solution without using a loop it is even better.
Re: Reference Lines in Variability Chart taken from a list using for loop
Is there some specific reason for avoiding loops?
These older posts might help (things might be changed a bit depending on your JMP version), but basically: loop over the charts and add the lines as reference lines
