Madwolf
Recode numerical days into Monday, Tuesday, Wednesday etc
Hi, I have a column that is indicated as days, in ordinal data.
How can I recode it, such that they are (Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, Sunday)?
Currently:
1 = Wednesday
2 = Thursday
3 = Friday
4 = Saturday
5 = Sunday
6 = Monday
7 = Tuesday
9  =Wednesday
416 = Friday
417 = Saturday
418 = Sunday
Is there a way to recode it without me having to type Mon - Sun all the way from 1 to 418?
Jeff_Perkinson
Re: Recode numerical days into Monday, Tuesday, Wednesday etc
Building on @txnelson's solution, you can use a Formula column with the Modulo() function that he showed, along with the Value Labels property.
The attached data table has this example.
-Jeff
Here is an example of a script that will create a new column with the desired values
// Create an Example data table
dt = New Table( "Example", add rows( 418 ), New Column( "weekday", set each value( Row() ) ) );
// Create a new column Using a script
dt << New Column( "Weekday 2",
	character,
	set each value(
		theList = {"Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday", "Monday"};
		theList[Mod( :weekday, 7 ) + 1];
Madwolf
Thank you so much. However, if I may ask, how do I do it, such that the new column is inside my existing table?
For instance, my existing table name is transaction_data.
Which are the field that I needed to change to "transaction_data" above, without the need to create a new table?
Jeff_Perkinson
-Jeff
Madwolf
Thank you so much!!
Select the column with the current values (1..7). Select Cols > Column Info. Select Column Properties > Value Labels. Define the character string label for each data value.
