Recode multiple columns with list
MargaretWM
I want to recode multiple columns using a conditional formula by going through each column with a For Each function. I am not able to recode successfully with the following code:
//Create list of columns to be recoded
ColNames = {dt:Name( "col 1" ), dt:Name( "col 2" ), dt:Name( "col 3" ), dt:Name( "col 4" )};
For Each( {listitem}, ColNames,
	Recode(
		listitem,
		{Lowercase( _rcNow ), If( Contains( _rcNow, "too much" ),
			"1000",
			_rcNow
		), Regex( _rcNow, "\D*(\d+\.?\d*)\D*", "\1", GLOBALREPLACE )}
My hunch is that the body of the For Each clause is incorrect -- that I have to somehow call out the columns more clearly.
The data table as "dt" is established earlier in the code. For the record, I don't get an error when I use the script but the columns are not recoded properly. Thanks.
Re: Recode multiple columns with list
Maybe you just need to use Recode Column instead of Recode and then tinker a bit on how to reference on columns.
This seems to be working, at least it replaces too much with 1000 in col 1:
dt = New Table("Untitled 2",
	Add Rows(1),
	New Column("col 1", Character, "Nominal", Set Values({"too much"})),
	New Column("col 2", Character, "Nominal", Set Values({"a"})),
	New Column("col 3", Character, "Nominal", Set Values({"c"})),
	New Column("col 4", Character, "Nominal", Set Values({"d"}))
ColNames = {"col 1"};
For Each({listitem}, ColNames,
	dt << Recode Column(
		//As Column(dt, listitem),
		AsColumn(listitem),
		{Lowercase(_rcNow), If(Contains(_rcNow, "too much"),
			"1000",
			_rcNow
		), Regex(_rcNow, "\D*(\d+\.?\d*)\D*", "\1", GLOBALREPLACE)},
		Update Properties(1),
		Target Column(Column(listitem))
	Add Rows(1),
		AsColumn(listitem),
			"1000",
			_rcNow
MargaretWM
I adapted the code here for my purposes (several columns in the list) but it still does not work:
ColNames = {dt:Name("col 1"), dt:Name("col 2"),
 dt:Name("col 3"), dt:Name("col4")};
	dt<<Recode Column(
	AsColumn(listitem),
		"1000",
		_rcNow
	), Regex( _rcNow, "\D*(\d+\.?\d*)\D*", "\1", GLOBALREPLACE )},
	Target Column(Column(SPcol))
Were you suggesting I go column by column to recode?
I'm not sure which formats for columns Recode Columns requires. You can see that we are using different syntaxes for ColNames (I'm using list of column names, and you are using old way to reference columns (Name("col name"), it has been replaced by "col name"n), also we are using different columns in Target Column.
If run the example I gave with this data table:
I end up with this
Here is updated example with new table and more columns added to ColNames list
	Add Rows(3),
	Compress File When Saved(1),
	New Column("col 1", Character, "Nominal", Set Values({"1000", "too much", "too much"})),
	New Column("col 2",
		Character,
		"Nominal",
		Set Values({"too much", "", ""}),
		Set Display Width(65)
	New Column("col 3", Character, "Nominal", Set Values({"c", "", "too much"})),
	New Column("col 4", Character, "Nominal", Set Values({"d", "", ""}))
wait(1);
ColNames = {"col 1", "col 2", "col 3", "col 4"};
		As Column(listitem),
			"1000",
			_rcNow
MargaretWM
Thanks for your help! Jordan Hiller helped me understand your original reply. I don't understand why using the list of columns as strings works while using a list of actual columns does not work, but I follow your solution now anyway. Helpful to see how column names are called out now too. Good reminder. Thanks again.
I always like using column names and then figuring out (or at least try to...) how to use them when I need to manipulate columns / get values from columns. Usually it is one of As Column(), Column() or Eval(), but sometimes you have to get more creative.
Here are few snippets that might come handy from time to time:
// set name which would usually break
Column(dt, "name") << Set Name("@na-me");
str_col_list = dt << Get Column Names("String");
show(str_col_list);
column_list = dt << Get Column Reference(str_col_list);
show(column_list);
ascolumn_list = Transform Each({col_name}, str_col_list,
	Name Expr(As Column(dt, col_name))
show(ascolumn_list);
Also see Deprecating the Name() parser directive in JMP 16  and Names (jmp.com) regarding Name("col name")
