Phil_Nash
Recode a value in a column with a formula instead of a static value
The original value that is in the table that I want to recode will always be 01/01/1900.  I want to recode that to today's date.  This only returns a blank, and not today's date.  Any idea what I need to change?
Thanks!
Transfers << Begin Data Update;
Transfers << Recode Column(
	Transfers:OrderDate,
	{Map Value( _rcOrig, {-126144000, short date(today())}, Unmatched( _rcNow ) )},
	Update Properties( 1 ),
	Target Column( :OrderDate )
Transfers << End Data Update;
Re: Recode a value in a column with a formula instead of a static value
I am not sure that the source column and the destination column can be the same data column. Here is the example from the scripting index:
col = New Column( :age );
col << Data Type( "Character" );
dt << Recode Column(
	:age,
	{If(
		_rcNow >= 17, "Older",
		_rcNow >= 15, "Middle",
		"Younger"
	Target Column( col )
hogi
Level XIII
To recode entries in a column and save the result to the same column, one can select In Place from the drop down menu:
In the JSL code the target column will match the input column.
Hm, Why does the code not work?
a) Short Date() converts the date to a String - but the column is numeric.
b) even after removing short date() it doesn't work. Because  Map value() doesn't allow expressions? maybe:
So let's try:
Transfers = New Table( "transfers",
	Add Rows( 1 ),
	Compress File When Saved( 1 ),
	New Column( "OrderDate",
		Format( "y/m/d"),
		Set Values( [-126144000] )
Eval (Eval Expr(Transfers << Recode Column(
	{Map Value( _rcOrig, {-126144000, Expr(today())}, Unmatched( _rcNow ) )},
