OneNorthJMP
Level V
Rank Unique
I want to calculate a new column to rank a column uniquely. Below are the example output that i want to achieve. But by using the JSL rank formula doesn't help me to achieve what i want. Can anyone please advise me?
The formula i use is Col Rank(:Label)
LabelRankWhat I want
NVM_VMAX_PRG_EVENR2_DCMP[1],80376,max11
NVM_VMAX_PRG_EVENR2_DCMP[1],80376,max21
NVM_VMAX_PRG_EVENR2_DCMP[1],80376,max31
NVM_VMAX_PRG_EVENR2_DCMP[1],81999,max42
NVM_VMAX_PRG_EVENR2_DCMP[1],81999,max52
NVM_VMAX_PRG_EVENR2_DCMP[1],81999,max62
NVM_VMAX_PRG_EVENR2_DCMP[1],86491,max73
NVM_VMAX_PRG_EVENR2_DCMP[1],86491,max83
NVM_VMAX_PRG_EVENR2_DCMP[1],86491,max93
Re: Rank Unique
There are a couple of ways to do this....(that I can think of, this early in the morning)
  1. Use a summary table to create the ranks
    1. Run Tables==>Summary
    2. Group by your Label column
    3. Assuming the output data table is sorted from low to high, create a new column called "Rank" and give it the formula........Row()
    4. Run    Tables==>Update to join the summary table back to the original table, matching on the Label column
  2. Create a new Rank formula column
    1. Sort the data by Label
    2. Create a new column called Rank with the formula
      If( Row() == 1,
      	count = 1,
      	If( :Label != Lag( :Label ),
      		count
      count;
    3. Be sure to go to Column Info and remove the after the column is created.  The reason for this is that since the formula is based upon the order of the data, and the completeness of the data, any changes in the data(sorting etc.) will rerun the formula and possibly change the rankings.
ms
Super User (Alumni) ms
Re: Rank Unique
If you want a column formula this should work. Independent of sorting.
Local( {L = Associative Array( :Label ) << get keys}, Loc( L, :Label ) )
Same approach could be used in JSL without a column formula.
dt = Current Data Table();
dt << New Column( "Rank Unique", continuous );
L = Associative Array( :Label ) << get keys;
For Each Row( :Rank Unique = Loc( L, :Label ) );
7 REPLIES 7
Re: Rank Unique
      If( Row() == 1,
      	count = 1,
      		count
      count;
OneNorthJMP
Level V
Re: Rank Unique
Hi Jim,
Thanks for advice. For the #2 solution. How do remove the formula by using JSL instead of doing it manually?
Re: Rank Unique
dt = current data table();
dt:Rank << delete formula;
ms
Re: Rank Unique
OneNorthJMP
Level V
Re: Rank Unique
Thanks Jim & MS. It work brilliantly!
BHarris
Re: Rank Unique
This is long-since solved, but I found a solution to this yesterday that I figured I'd share in case it's helpful to anyone.  Create a new formula column with this formula:
Col Maximum(
	Col Rank(
		If( Row() == Col Minimum( Row(), :Label ),
			:Label,
	:Label
Basically this first creates a new array with the label in the row corresponding to its first instance in the original column, and "." everywhere else.  Then we ask for the ranking of each label, which results in another array with the label ranking instead of the label itself, and then finally we output an array with the ranking in all rows with that label, and that's what ends up in the formula column.
In my case I was trying to rank groups of sets of data based on their highest value in another column -- e.g. with columns Group, Set, Time, Value, I wanted to find the set's rank within the group based on the highest Value observed across time.  Here's a formula that worked:
Col Maximum(
   Col Rank(
      If ( Row() == Col Minimum( Row(), :Group, :Set),
         Col Maximum( :Value, :Group, :Set ),
      :Group,
<<tie("row")
), :Group, :Set )
I don't know if this is the best way, but it works, and ChatGPT couldn't offer a solution at all, so maybe this will help someone.
hogi
Level XIII
Re: Rank Unique
