msharp
Randomize a List
I need to randomize a list.
randomizeList = Function({List}, {Default Local},
     //Code goes here
     return List;
list = {1,2,3,4,5};
randomList = randomizeList(list);
print(randomList); //Expected output something like {2,4,5,1,3}
There are lots of ways to do this and no wrong answer.  I appreciate any feedback, thanks!
13 REPLIES 13
Phil_Brown
Re: Randomize a List
Yet another way....
// Philip Brown Jul 14, 2016 9:50 AM
phil_randomizeList =Function({aList},{Default Local},
    aList[rank( Repeat({random uniform()}, nitems(aList) ) )]
I don't think this is faster than the built-in function Random Shuffle, but I've always liked using Repeat({<Expr>}, n) to generate lists for certain applications.
PDB
pmroz
The code below compares the four algorithms.  Data is stored in a table and then graphed.  I'm curious what this looks like in JMP 13?
// pmroz version
pmroz_randomizeList = Function({aList}, {Default Local},
    nr = nitems(aList);
    dt = New Table( "", private, Add Rows( nr ),
        New Column( "Data", Numeric, Continuous, Format( "Best", 12 ),
            Set Values( aList ) ),
        New Column( "Randomized", Numeric, Continuous, Format( "Best", 12 ),
            Formula( Random Uniform() ) )
    dt << sort(replace table, by(:Randomized));
    random_list = dt:Data << get values;
// Jeff Perkinson Jul 13, 2016 2:00 PM (in response to Peter Mroz)
jeff_randomizeList =Function({aList},{Default Local},
    aList[rank(j(nitems(aList), 1, random uniform()))]
// Byron's function
byron_randomizeList = Function({aList},{Default Local},
    nr = nitems(alist);
    rslist = random shuffle(1::nr);
    blist = alist[rslist[1::nr]];
nlist = {100, 1000, 10000, 20000, 30000, 40000, 50000, 70000};
dt = new table("Randomize List", Add Rows( nitems(nlist) ),
    New Column( "N Items", Numeric, Continuous, Format( "Best", 12 ) ),
    New Column( "pmroz", Numeric, Continuous, Format( "Best", 12 ) ),
    New Column( "Jeff", Numeric, Continuous, Format( "Best", 12 ) ),
    New Column( "Byron", Numeric, Continuous, Format( "Best", 12 ) ),
    New Column( "Phil", Numeric, Continuous, Format( "Best", 12 ) )
for (i = 1, i <= nitems(nlist), i++,
    nm = nlist[i];
    dt:N Items[i] = nm;
    my_list = (as list(1::nm))[1];
    start = tick seconds();
    randomList = pmroz_randomizeList(my_list);
    elapsed = tick seconds() - start;
    dt:pmroz[i] = elapsed;
    wait(0);
    randomList = jeff_randomizeList(my_list);
    dt:Jeff[i] = elapsed;
    wait(0);
    randomList = byron_randomizeList(my_list);
    dt:Byron[i] = elapsed;
    wait(0);
    randomList = phil_randomizeList(my_list);
    dt:Phil[i] = elapsed;
    wait(0);
dt << Graph Builder( Show Control Panel( 0 ),
    Variables( X( :N Items ), Y( :pmroz ), Y( :Jeff, Position( 1 ) ), Y( :Byron, Position( 1 ) ),
        Y( :Phil, Position( 1 ) ) ),
    Elements( Points( X, Y( 1 ), Y( 2 ), Y( 3 ), Y( 4 ), Legend( 1 ), Jitter( 1 ) ),
        Smoother( X, Y( 1 ), Y( 2 ), Y( 3 ), Y( 4 ), Legend( 2 ) ) )
Byron_JMP
I increased the list sizes to help differentiate a little better, although the differences between methods aren't that big. What is surprising is the time differences between the results above and these. Also, it seems weird that pmroz's method is slower with 100 rows than with 10000. Maybe its due to repeating the task of making the table?
JMP 13 beta 8
Mac 2.5 GHz Intel Core i7
16 GB 1600 MHz DDR3
N ItemspmrozJeffByronPhil
1000.1833333333000
10000000
100000.0166666667000
500000.050.016666666700.0166666667
1000000.10.03333333330.03333333330.0333333333
5000000.60.23333333330.16666666670.2666666667
10000001.31666666670.51666666670.36666666670.5666666667
1000000017.6333333336.18333333334.37.15
Craige_Hales
love the straight lines; the N^2 behavior for lists is fixed!
Craige
