Martin
Level V
Radio Button activate Radio Button
I have two groups of radio button groups, Group 1 and Group 2. Group 1 has two radio buttons, RB1 and RB2 while Group 2 has two radio buttons RB3 and RB4. When a user selects RB2, I want the script to select RB4 and run the jsl that is behind the selection of RB4. Currently, I can get the script to select RB4 but it does not also run the jsl behind RB4.
Any thoughts would be appreciated.
Thanks,
Martin
pmroz
Re: Radio Button activate Radio Button
Forgot that part:
rb4_expr = expr(
    print("Running RB 4 Code");
nw = new window("Radio Button Demo",
    hlistbox(
        panelbox("Group 1",
            rb1 = radio box({"RB 1", "RB 2"},
                one_rb = rb1 << get selected;
                if (one_rb == "RB 1",
                // then
                    print("Running RB 1 Code");
                // else
                    one_rb == "RB 2",
                    print("Running RB 2 Code");
                    rb4_expr;
                    rb2 << set (2);
        panelbox("Group 1",
            rb2 = radio box({"RB 3", "RB 4"},
                one_rb = rb2 << get selected;
                if (one_rb == "RB 3",
                // then
                    print("Running RB 3 Code");
                // else
                    one_rb == "RB 4",
                    rb4_expr;
6 REPLIES 6
pmroz
rb4_expr = expr(
    hlistbox(
        panelbox("Group 1",
                // then
                // else
                    one_rb == "RB 2",
                    rb4_expr;
        panelbox("Group 1",
                // then
                / else
                    one_rb == "RB 4",
                    rb4_expr;
Martin
Level V
So this is close.  I was hoping that in the section of the code when RB 2 is selected - RB 4 would be selected automatically - causing the code of RB 4 to run.  Does this make sense?
Thanks
pmroz
Forgot that part:
rb4_expr = expr(
    hlistbox(
        panelbox("Group 1",
                // then
                // else
                    one_rb == "RB 2",
                    rb4_expr;
                    rb2 << set (2);
        panelbox("Group 1",
                // then
                // else
                    one_rb == "RB 4",
                    rb4_expr;
Martin
Level V
So if I understand this correctly, every time RB 2 is selected, "Running RP 2 Code" is printed, then "Running RP 4 Code" is printed via the Expr command (not sure why this can not be just added directly into the RB 2 code, without the Expr command), and then the RP 4 button is selected.  It is not by virture of the RP 4 button being selected that the "Running RP 4 Code" is printed when the RP 2 button is selected.  Correct?
Is the benefit of using the "rb4_expr" reusing the same code for two different parts of the program?
Thanks
pmroz
Yes that's correct.
It is not by virtue of the RP 4 button being selected that the "Running RP 4 Code" is printed when the RP 2 button is selected.  Correct?
Yes.
Yes.
This is straight "call-back" programming for a dialog box.  It's more work than straight linear programming; you have to do more housekeeping.
ms
Super User (Alumni) ms
There is an optional argument for rb << set() to run the script besides selecting the button.
rb2 << set( 2, run script( 1 ) );
The script will only run if the button is not already selected, i.e. only the first time unless RB 4 is deselected. PMroz code forces the script to run every time RB 2 is selected/clicked. Compare his code with the below:
nw = New Window( "Radio Button Demo",
  H List Box(
  Panel Box( "Group 1",
  rb1 = Radio Box(
  {"RB 1", "RB 2"},
  If(
  one_rb == "RB 1",
                // then
  Print( "Running RB 1 Code" ),
                // else
  one_rb == "RB 2",
  Print( "Running RB 2 Code" );
  rb2 = Radio Box(
  {"RB 3", "RB 4"},
  If(
  one_rb == "RB 3",
                // then
  Print( "Running RB 3 Code" ),
                // else
  one_rb == "RB 4", Print( "Running RB 4 Code" )
