justvince
JMP Script to open web page
I am importing data from a web server, but it requires a secure log in before I can run my scripts to get the data from the server.  If I use the menus in JMP, for example <File> <Internet open> and then select {open as "Web Page"}, jmp will open the web page login screen and I can login, then start my scripts with calls to the server to get data.   All of my calls begin with something like Mydata_dt = open(http://severname.com);  I am omitting specific trailers for my data pulls here but...
My question is, can I have a script that actually starts with "internet open" where the open command opens a web page instead of trying to import data into a table?
ms
Super User (Alumni) ms
Re: JMP Script to open web page
The Web() function may do what you want:
Web( "http://www.jmp.com/", JMP window )
ms
justvince
Perfect!!  It works!  Thanks very much, this was not documented in my scripting guide book.
