LgWagon
ROC curve analysis: sensitivity at fixed specificity
Dear all,
I'm a novice of JMP and I'm stunned with its great potential. I ask your help to solve my problem. I made a ROC analysis on a data set, and I need to calculate, based on ROC curve, sensitivity at fixed 80%, 95% and 99% specificity. The software doesn't seem to provide this option. I know I can approximate these values looking at the cut-offs in the ROC table, however it's only an approximation. Other software, for example MatLab or MedCalc give this option. For example MedCalc has the option to build "a table with estimation of sensitivity and specificity, with a BCa bootstrapped 95% confidence interval (Efron, 1987; Efron & Tibshirani, 1993), for a fixed and prespecified specificity and sensitivity of 80%, 90%, 95% and 97.5% (Zhou et al., 2002)." How can I solve?
Thank you very much, you are a great community!
Thierry_S
Re: ROC curve analysis: sensitivity at fixed specificity
You may find what you need by expanding the "ROC Table" at the bottom the ROC plot.
Best regards,
TS
Thierry R. Sornasse
