BHarris
Quickly show Data View with subset of rows that match regex
I'm looking for a JSL script that does the following:
  1. Gets the currently selected columns in the active data table.
  2. Takes the first selected column.
  3. Prompts the user to enter a regular expression.
  4. Selects only the rows in the table where the value in that column matches the regex.
  5. Opens a Data View window showing only those matching rows.
Is this possible with JSL?
10 REPLIES 10
Re: Quickly show Data View with subset of rows that match regex
Looks good! I would make few small changes:
  • Before opening the New Window check that there is a table open and if there isn't one, run stop();
  • If there are no matches, the last row will throw an error. You could either check selected row count and use stop() if it is 0 or show information to the user that there was no matches
  • << Get Rows Where is mos likely faster than << Select Where
    • Some additional speed-up can most likely be gained by evaluating the column reference
  • << On Validate could also be used if you wish to let user input new regex if the first doesn't have any matches
View more...
If(N Table() == 0,
	stop(); // display error message to user if necessary
nw = New Window("Enter search regex",
	<<modal,
	<<return result,
	V List Box(align("center"),
		Panel Box("Input search regex",
			userinput = Text Edit Box("",
				<<Set Script(
					okBtn << Click()
				, <<set width(400)
				, << Set Hint("search regex...")
		Lineup Box(N Col(2),
			okBtn = Button Box("OK"),
			Button Box("Cancel")
If(nw["Button"] != 1,
	stop();
inputRegex = nw["userInput"];
If(IsMissing(inputRegex),
	stop(); // empty regex
selCols = dt << Get Selected Columns("String");
If(N Items(selCols) > 0,
	col = selCols[1];
	col = Column(dt, 1) << get name;
selrows = Eval(EvalExpr(
	dt << Get Rows Where(!Is Missing(Regex(Expr(NameExpr(As Column(dt, col))), inputRegex, "1", IGNORECASE)));
If(N Rows(selrows) == 0,
	stop(); // display error message if necessary, this could also be done already within modal window (<< On Validate), if you wish to let user perform new search
dt2 = dt << Subset(Rows(selrows), Selected Columns(0), Link to original data table(1), Output Table(""));
// dt2 << Select Rows(1::NRows(dt2)); // to select rows if necessary
