miguello
Question on ComboBox
I can create options for Combo Box with pop up tips using something like that (found this experimentally):
list = {"One" ("This is One"), "Two" ("This is two")};
New Window( "Example",
	cb = Combo Box(
		list,
		selection = cb << GetSelected();
		Print( selection );
But then when I look at the selection - it only has "One" or "Two" as a result of << Get Selected.
Two questions:
1. What kind of data structure is the list above? It's a list of what? list[1] gives me exactly "One"("This is one") - is it a string, or what is it?
2. How do I work with this list, let's say if it was a normal list like {"One", "Two"}, I would put in a script part something like this:
if(
selection == list[1], doThis,
selection==list[2], doThat
But how do I do it when I have pop up tips included?
Re: Question on ComboBox
There may be a Community member that has a better way of dealing with the Combo Box list structure, but the only way that I figured out how to deal with it is by making the whole list into a string, and then parsing it out with the Word Function
tipstr1 = word(4,char(list),"\!"");
which returns
"This is One"
pmroz
The scripting index shows that structure for tip strings in the combo box.  I never realized you could include tooltips with a combobox - neat feature.
You can create the "real" list from the list with tooltips.  Also I'd refrain from using "list" as a variable, as it is a function in JSL.
list_tips = {"One" ("This is One"), "Two" ("This is two")};
	cb = Combo Box(
		list_tips,
		Print( selection );
mylist = {};
for (i = 1, i <= nitems(list_tips), i++,
	pq = contains(list_tips[i], "(\!"");
	mylist[i] = substr(list_tips[i], 1, pq - 1);
if (
	selection == mylist[1], doThis,
	selection == mylist[2], doThat
In your example, List is a list that has 2 entries.
  1. "One" ("This is One")
  2. "Two" ("This is two")
The Combo box divides each list entry into Item and tipstr.
returns only the item
If you want the tipstr returned, you need to use
tipstr = (cb << get items)[cb << Get];
miguello
Thanks, Jim.
Still not very clear - each entry is a string? Where quotes escaped?
And if I want to use the same list in an if statement in a script for the combobox, I would have to extract the item itself? Like:
if(
selection == Word(1, list[1], "\!"()"), doThis,
selection==Word(1, list[2], "\!"()"), doThat
which returns
"This is One"
pmroz
	cb = Combo Box(
		list_tips,
		Print( selection );
mylist = {};
if (
