Djtjhin
Quantiles with missing values
If I have a column named X with 100 values which is a sequence from {1-100}, and I want to retrieve the 10 smallest values, I know I can use the command below:
dt = current data table();
temp1 = dt:X << get values;
temp2 = quantile(0.1,temp1);
dt << get rows where(:X<temp2);
Let's say I'm replacing the 10 largest values (i.e. 91-100) with missing values, is there a way to get the same 10 smallest values ? I believe the Quantile function will not take consideration of the missing values.
Appreciate the help
Re: Quantiles with missing values
Do you want to get the rows or values? Here is one example how you should be able to get 10 smallest non missing values
temp1 = Sort Ascending(dt:X << get values); //get values in column Value
temp1 = temp1[Loc(temp1)]; //ignore missing
tensmallest = temp1[1::10]; //get 10 first values in list
Djtjhin
This works for the solution that I was working on. Thanks!
See for yourself.
Names Default to Here( 1 );
dt = New Table( "Untitled 2",
	Add Rows( 10 ),
	New Column( "Full",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [1, 2, 3, 4, 5, 6, 7, 8, 9, 10] )
	New Column( "Partial",
		Numeric,
		"Continuous",
		Set Values( [1, 2, 3, 4, 5, 6, 7, ., ., .] )
values = :full << Get As Matrix;
Show( Quantile( 0.1, values ) );
values = :Partial << Get As Matrix;
The presence of missing values changes the sample quantile, so it will of curse change the rows that are selected.
