ptijerome
Quantile plot in anova : can I remove markers?
When quantile plot is activated each X group is associated with a color.
However when a large numbre of data is used(several thousands), all the curves become "black", as the colored curves are fully covered with black markers. It become difficult to distinguish between X variables...
My best attempt is to reduce marker size and thicken the line. When I extract the script it provides :
Dispatch(
"Oneway QuantilePlot",
 FrameBox,
{Marker Size( 0 ), Line Width Scale( 4 )}
But Is there a way to fully get rid of the marker or to get the same color between markers and the line that is drawn between 2 markers?
Jérôme
Re: Quantile plot in anova : can I remove markers?
Not very elegant but you can right-click in the normal quantile plot and select Customize. Then select Marker and change Transparency to 0.
You can also use Rows > Color or Mark by Column. Select the grouping column (factor) and use the JMP default colors so that the marker color matches the line color. That way you don't have to get rid of them but they are distinguishable.
