awsmagala
Purposefully Raising Error in JSL
I have been searching the forum and scripting index for a way to do this but have not found anything to accomplish what I am trying to do.  I am looking for something that has similar functionality to Python's "Raise" function.  Or essentially the same functionality as the Try Throw statements but without a JSL exception being raised.
For example I am writing a function that requires the user to enter a date in the form of a string.  In order to prevent errors I want to check the input before using it in the function.
Example Function = Function({start_date,end_date},
    chk1 = Is String(start_date);
    If(chk1 == 0, //Raise some error here);
I think I could accomplish what I want with a Show("Error message") and Break() sequence but I am wondering if there is any native JSL methods to accomplish this task.
Re: Purposefully Raising Error in JSL
use the Try() function and then check on the results of it
Jeff_Perkinson
You can use Throw() without a try. I think it's similar to Raise() in Python.
show("Here");
throw("This didn't work");
show("Here 2");
"Here";
This didn't work
-Jeff
pmroz
I use a combination of a modal window to provide an error message for the user, and throw to terminate execution.
Example Date Check = Function({start_date,end_date},
    If (!chk1 == 0,
		emsg = "Invalid start date [" || char(start_date) || "]";
		ew = new window("Invalid date", << modal(),
			text box(emsg),
		throw(emsg);
    chk2 = Is String(end_date);
    If (!chk2 == 0,
		emsg = "Invalid end date [" || char(end_date) || "]";
			text box(emsg),
		throw(emsg);
example date check(today(), today());
example date check("31-Feb-2018", today());
David_Burnham
You can use Throw to throw an error.  In the context of capturing user input errors you can use a modal window with an OnValidate message:
NewWindow("Demo", <<Modal,
	<<OnValidate(
		n = teb << Get;
		show(n);
		If (n<=100,
			isValid = 1;
			tbStatus <<SetText("")
			isValid = 0;
			tbStatus <<SetText("try again!")
		isValid
	BorderBox(Top(20),Bottom(20),Left(20),Right(20),
		VListBox(
			HListBox(
				TextBox("Enter a number less than 100:  "),
				teb = NumberEditBox()
			tbStatus = TextBox("",<<FontColor("red"))
show(n)
-Dave
