nter
Project multiple different axis settings in graph builder to different pages
One of the nice features of the page field is the ability to export a PDF or PPT with many pages, but I'm having trouble customizing the axes on the second and subsequent pages.
Starting with the consumer preferences data set, I can make a graph like this with customized y axis labels.  For example I customized "years at current employer" to read "Years Exp"
 Then if i add "age group" in the page field
You'll notice that the custom axes are not kept for the later pages.
If I try copying axes properties and broadcasting with ctrl+paste axes properties, it broadcasts properties from a single y axis to all graphs and y axes, which causes a problem because "years exp" has a different range than "is parent"
Is there a good way in graph builder or JSL to broadcast the customized axes properties when dealing with multiple stacked y axes, for example?
floydfoxfb
Re: Project multiple different axis settings in graph builder to different pages
nter,
I apologize in advance that I do not have a solution to your question but it is now April 26, 2023 and I am also seeking a response to this very question.  If you have found a solution to this please let me know.  BTW, I am using JMP 17 Pro v17.0.0.  Perhaps this response to your question will prompt an answer from the community or JMP tech support.
Thank you
Floyd
This script illustrates one approach:
Names Default to Here( 1 );
// open example
dt = Open( "$SAMPLE_DATA/Consumer Preferences.jmp" );
// launch graph builder with multiple pages
gb = dt << Graph Builder(
	Size( 528, 3450 ),
	Show Control Panel( 0 ),
	Variables( X( :Gender ), Y( :Years at Current Employer ), Page( :Age Group ) ),
	Elements( Box Plot( X, Y, Legend( 4 ) ) )
// access report layer
rpt = gb << Report;
// find all text edit boxes
axis = rpt << XPath( "//TextEditBox" );
n = N Items( axis );
// change text in all text edit boxes of vertical axes
axis[4::n::2] << Set Text( "Years Exp" );
