I search a description what are the advantages in detail of the underneath shown Profiler display of multilevel categorical Factors in “Fit Group” with "personallity Stepwise". (two Top left graphs vs six left graphs in the lower Picture) Is there a paper available that explains why the two personallity/methods using different outputs. Can I switch the “Personallity: Stepwise” to the Graphical display used in “Standard least Squares” (upper Graph), what I like currently much more.
I know, I can go via “Model Dialog” and doctoring the Factors to get the display I currently want to have. But I have multi Y’s and that would cause a mess of manual work. Hence I’m looking for a stepwise method with least squares Display.
A script would be helpful if it is easy to apply. I’m beginner with Scripting.
Thanks Peter
