Gary,
For the splitting, use Tables > Split. Put Condition in Split By and Perfomance in Split Columns.
From there go to Analyze > Distribution and select the 5 Condition columns.  Click OK
Hold down the Control Key (Windows) and then click the red hot spot by "20".  Go to Continuous Fit near the bottom and toggle over to "All".  This will find the best overall distribution for the 5 columns.  I would suggest you do regular and non-normal capability analysis the Normal Mixture distributions and see if they come out different from each other.
Bill
