Vvvv
Problem with copying graph to word
Hi.
I am having an odd problem that I have not encountered before when I try to copy a graph from the graph builder to MS Word.
Basically a big part of the picture crops off, and I am left with an unfulfilling graph. See pictures below. I used the selection (S) to choose which part of the graph to copy.
Has anyone encountered this? It has never happened to me before.
First picture is what I select, and second picture is what is copied into word. If I try to enlarge the picture in word I just get the same thing, but of course a larger picture.
Vvvv
Re: Problem with copying graph to word
Restarting jmp fixed it.
Vvvv
