r23426
Problem with Clear log () in JMP14
I have a problem with the clear log (); instruction.
It was working well in jmp 12, 11, 10, etc...
But with the new JMP14 ( Iswitch about 1 month ago), some time it works, some time not.
All my scripts start with this header:
Names Default to here (1);	// set all variables as local
Open log (1);	clear log();
include("My_own_path.jsl");  // define the path stored in include_path variable
// Real script starts belwo this comment line
Any idea where my pb comes from ?
msharp
Re: Problem with Clear log () in JMP14
I run similar scripts and haven't had an issue with JMP 14. The fact that it's intermittent is also mysterious. I'd recommend re-installing and see if that helps. If it doesn't I'd submit a ticket to [email protected] and be sure to tell your JMP Version, Operating System, ect.
Also, syntax wise, you shouldn't have spaces between your function name and function call. (e.g. Names Default to Here(1); not Names Default to here (1);). JSL is too forgiving with white-space and capitalization compared to other languages. I doubt this is your issue, but the interpreter could be having problems parsing the script... Best to always follow correct standards.
r23426
Hi thanks for the feed back.
I have correcetd some spacing as you mention, in my scrupts, but still the same problem ( not really a pb in fact, more a nuisance).
I confirm it is Ok with same script/same dataset on jmp12.
This issue should probably be passed on to the support folks at JMP
     [email protected]
