nliu6
Problem to save a dashboard as interactive HMTL
Hello all,
I have difficulty to save dashboard to interactive HMTL. I also got three save as type to select: JMP Source File, JMP Application File or JMP Script.
But I can save a graph as interactive HMTL with no issue.
Can anyone help me?
stan_koprowski
Re: Problem to save a dashboard as interactive HMTL
Hi @nliu6,
You can learn more about saving and sharing reports from the Using JMP book chapter 10.
Help>>Books>>Using JMP or Interactive HTML.
Be sure to run the dashboard and then proceed with the sharing.
Run DashboardRun Dashboard
From within JMP ensure your dashboard is the active window and then Select File > Save As and select Interactive HTML with Data from the Save as type list.
On Macintosh, select File > Export > Interactive HTML with Data.
 File >> ExportFile >> ExportSelect Interactive HTMLSelect Interactive HTML
cheers,
Stan
stan_koprowski
Hi @nliu6,
cheers,
Stan
