Sburel
Problem extracting eigen value data from PCA report when using 'by'
I running a PCA on a data table independently for several categories (specimen_material_type).
For each category, I want to save the eigenvalues of principal components into an eigenvalue data table labelled 'Eigenvalue for XYZ'.
In the example table, I have 2 categories. I manage to retrieve the first set of values using a For loop but then it crashes for the second category.
Any suggestions to keep the loop going would be greatly appreciated.
Thanks in advance
Sebastien
Here's the script I'm trying to run
names default to here(1);
clear log();
define data table=expr(
	New Table("PCAfull NGS library ID", Add Rows(83), New Column("NGS library ID", Character(5), "Nominal", Set Values({"75522", "75523", "75524", "75525", "75526", "75527", "75528", "75529", "75530", "75531", "75532", "75533", "75534", "75535", "75536", "75537", "75538", "75539", "75540", "75541", "75542", "75543", "75544", "75545", "75546", "75547", "75548", "75549", "75550", "75551", "75552", "75553", "75554", "75555", "75556", "75557", "75558", "75559", "75560", "75561", "75562", "75563", "75564", "75565", "76960", "76961", "76962", "76963", "76964", "76966", "76967", "76968", "76970", "76971", "76973", "76974", "76975", "76976", "76978", "76979", "76980", "76981", "76982", "76983", "76984", "76985", "76986", "76987", "76988", "76989", "76990", "76991", "76992", "76993", "76994", "76995", "76996", "76998", "76999", "77000", "77001", "77002", "77003"})), New Column("specimen_material_type", Character, "Nominal", Set Values({"not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "not eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye", "eye"})), New Column("A", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([2.81523292027604, -1, 4.02478319241904, -1, -1, 4.2815929302584, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 2.53194594573136, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 4.08894841905084
	, -1, -1, -1, -1, -1, -1, -1, 2.3126602484075, -1, -1, -1, -1, 3.09560226904009, 1.43786024971756, -1, -1, -1, -1, -1, 1.05304952521298, -1, -1, -1, -1, 1.003842679008, -1, -1, -1, -1, 1.95818375033999
	, -1, -1, -1, -1, 1.62415360527231, 1.05658148223493, 0.692643724473693, -1, 2.86745617620997, -1, -1, -1, 0.656877178052666, -1, -1, -1, -1, -1, -1])), New Column("A2m", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([1.60451338039627, 1.7379934887408, 0.0949197636764503, -2.26893148160169, 1.2199823602359, 0.458316522555575, 0.617560407004941, 1.7108769603372, 0.454215559055898, 0.0147856422376059, 1.15700394899866
	, 0.279743989721128, 1.35568218961989, 0.40897732862397, -2.02554849205654, 0.0626028063787076, 0.032908895992389, 0.47614932094771, -1.20603986236648, 2.35032677037154, 2.49935991525021, 1.25819216652684
	, -0.835378672699606, -0.672402130524789, 0.743583435555904, 0.876602029715063, 4.51735686417174, -0.567303962335732, 2.42061275046452, 1.17444161963283, 1.50738267258403, 2.78243291570032, 1.01145663002848
	, -1.70623882010435, 0.370009375727261, 1.37841631207877, -0.0134933653383186, 1.62385927984512, 1.88393225412704, -0.979394138326553, -0.103610377459425, -0.345939437516782, 1.06267457946493, 1.86623270947081
	, 1.78960085972607, -0.495155988494079, 0.0745873543714788, 0.430158039913087, 0.539410767349254, -0.973206444265609, -1.07967825558086, -0.297846735818846, 0.760328152917581, 1.71484613865236, -0.334160806593491
	, -2.09591658220969, -0.315725057874633, 1.50737970639471, 1.39501707648347, -0.154497042356808, -2.81779520222204, -0.667291774652886, 0.19750554193735, -1.11220589050919, 0.255260658034548, 2.61959680473956
	, -0.684104987689079, 0.00057926987013414, -0.031045353785337, -0.105164619549189, -0.809486125370554, -1.14618728027108, 0.356029277801129, -0.448745730819161, -0.26531862727983, 1.72349091457392, -0.739389904259247
	, 2.44700954268139, 1.44125544875698, -0.329260023996972, -0.975343013225854, 0.337139725887604, 0.21206920364088])), New Column("A2ml1", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.267978719985849, -0.57250805741047, 0.422595786895291, 0.0337302041764496, 0.256583975269946, 0.97204965643375, -1.10964843491292, -0.968739626568384, -0.0924908185609332, 0.987959624014818, 0.0428621603687659
	, -0.34308291104752, 0.223923522254772, 0.16586749861605, 0.727895389908675, 0.769661379859143, -0.747772586004821, -0.214541084912323, -0.645880659190569, -0.719279611493273, 0.588939988868035, 0.418846134760733
	, 0.165742153121929, 0.543662340131567, -1.06489559197305, -0.602369724709973, 1.3354547344466, 0.465222369982708, -0.59518575496857, -0.210300440595899, 1.00913431778553, 0.667772707380214, 0.417090894786379
	, -0.253129982515899, -1.06592765793185, 0.0661279908786629, -0.31386524605738, -0.181897810440236, -1.50004575062989, -1.00857188666128, -0.389849305668704, -0.407090704300613, -0.444327620258024, 0.341457069791423
	, 0.951853625632966, 0.134406855464686, 0.105437337057311, 0.717468775552468, 0.517255526785056, 0.155459648717432, 0.50842269067594, 0.51577812308835, 0.612075578925282, 0.629044377526836, -0.66539904104507
	, -0.1036827279477, -0.0129983670503679, 0.203561465009655, 0.516066074841332, 0.517813183584936, -0.336776870686451, -0.814588241947477, -1.35408905640973, 0.39675706986058, -0.2737185401739, 0.422722614011725
	, 0.0865542503175254, -0.279628756097143, -0.437228887969871, 0.298417028099155, -0.19538137709075, -0.435254561055781, -0.638538725913414, -0.316802040313222, -1.04627667620181, -0.556029080996659, -1.30730843834738
	, 0.609729574045428, 0.416365318833071, -1.04388638396783, -0.913265784961486, -0.290675349503202, -0.0400155946788967])), New Column("A3galt2", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-1.08509715850208, 0.104736022524232, -0.00862556692992981, -1.31278591792405, -1.63876926962991, -0.743029038725354, -0.187228658512325, -0.513444632685201, 0.406839647795159, -4.90033007877813, -4.90033007877813
	, -4.90033007877813, -1.16546254288738, -4.90033007877813, -4.90033007877813, -0.275450723257436, -4.90033007877813, -4.90033007877813, -0.281520643000253, -4.90033007877813, -4.90033007877813, -4.90033007877813
	, 0.0824731876691679, 0.477725223131015, 0.977337235198232, 0.818027108291735, -0.633775268505485, -0.972298969685575, -1.57432644387473, -0.148682164915817, -4.90033007877813, -4.90033007877813, 0.888711218340541
	, 1.04369012360226, 0.467036902374083, -0.518782842514448, -0.986932806012085, 0.431040677572898, -4.90033007877813, -0.205571090822207, -2.72089525768561, -0.266361713334346, -1.49104756949032, -2.18421116696945
	, -1.66522556544516, -2.00170948702876, 0.418851832415982, 0.363316161698881, 0.063429803528219, -4.29780991059757, -2.34672285291133, -2.51759935044583, 0.634273780941373, -0.532350612793235, -4.29780991059757
	, -0.436658161850398, 0.962745887694349, -2.06214552205818, -0.293008158950686, -0.648614984276923, -4.29780991059757, -0.107018739493328, -0.572781900835527, 0.115943187818302, -0.0803327573500455, -0.740178092801829
	, -1.19956990919536, 0.996698413602645, -0.795676590419268, -2.24122842836264, 0.985824730901028, -0.553942611026116, -1.83004830880123, -0.121849875332677, -0.702004751415262, -0.351511718010065, -0.498723290633013
	, -4.29780991059757, 0.0809430331571471, -4.29780991059757, -2.05694907587967, -4.29780991059757, 0.308156028741795])), New Column("A4galt", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.889665228771552, -3.80390995896744, -3.80390995896744, -0.216365798113365, -1.05398968418564, -3.80390995896744, 1.66369696632116, -0.108734774662702, -0.0106071917501523, 2.16831580128544, -1.8662868899133
	, 1.93009280651242, 0.287540790350048, -0.538592757860935, -3.80390995896744, -3.80390995896744, -0.14278365459503, 1.70063825493234, -3.80390995896744, 1.54043366203514, -0.224494135582669, -3.80390995896744
	, -0.455359035926893, -3.80390995896744, 0.392937775443059, 0.174019861707017, -3.80390995896744, -3.80390995896744, 1.40994889260144, -0.38069624560772, 0.914892212393309, -3.80390995896744, -1.0564970765824
	, -3.80390995896744, 1.76524047693643, 0.0268734932982034, -1.62856069230588, -3.80390995896744, 1.0167712021825, 0.544108133165686, -3.80390995896744, -3.80390995896744, 1.09684116317113, -0.201324078893179
	, -0.669132160573488, 0.646313509989108, 0.404196659113136, -1.24921583494755, -0.0676987267952137, -1.20031409057822, 0.56371881768849, 0.483341026588599, -0.19970310940064, 1.09746747303447, -0.179902344696605
	, -0.0728936948293486, -4.18043793687061, -1.94477354833121, 1.34813418085793, -2.19365819578634, 0.291550250037317, -2.38715250482555, -0.210674611899095, -1.22172631995644, -0.352376813796417, 1.28224388930992
	, 1.09824086644765, -0.0320702135084519, -0.382069760280038, 0.350628977472457, 0.618420676141251, -0.19159642608436, 0.383893989711438, -2.39830171891859, -0.584632777688297, 1.12118640617489, -0.173841385885346
	, 0.0327246711893619, -1.25421836466334, -4.18043793687061, -1.9395771021527, 1.33451698238299, -0.130112754426275])), New Column("Aa386476", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-4.50685280135483, -4.50685280135483, -4.50685280135483, 0.987753901634562, -4.50685280135483, -4.50685280135483, -1.4697622476146, -4.50685280135483, 0.0485046626415249, 1.57730455721776, -0.0479483630680235
	, 0.698850242015833, 0.336447902516759, 0.753645003200841, 1.64438286416573, -4.50685280135483, 0.0960949343489815, 1.24168197582379, -0.283639640435177, -1.34895719521867, -4.50685280135483, 0.674511415755513
	, -4.50685280135483, 1.16424348597594, -2.54714079274661, -2.27748817832988, -4.50685280135483, -0.578821692262277, -4.50685280135483, -1.60287750814917, -1.77996361616959, -1.47139267847704, -4.50685280135483
	, -4.50685280135483, -4.50685280135483, -2.40006832853519, -0.593455528588788, -0.497772178726066, 0.313828359795113, -0.616199444523314, -1.49615864798592, -4.50685280135483, 0.229997588832439, 0.476854510236987
	, 1.57813987915373, -3.64719332465353, 0.792103419751357, -0.0567185451065921, -0.616284099885636, -3.64719332465353, 0.538668959152315, 0.317073885077031, 1.28489036688542, -1.59414379944055, 0.353342267520478
	, 1.0171430565263, -3.64719332465353, -3.64719332465353, -3.64719332465353, 0.00200160166712326, 1.31973238370759, -0.205692264324131, -0.217072746454696, 0.516999562551478, 1.12916159734468, 0.597542751881878
	, -0.0212681417659766, -1.11590727170114, 1.09837351269873, -0.208559801700974, 1.02847224231552, 0.551000631536326, 0.967918842193974, -3.64719332465353, 1.1971077633916, -1.1098660927041, 0.151893295311033
	, 1.52654381772209, -0.720973752446256, -3.64719332465353, -3.64719332465353, 1.2984887711908, -0.13893601691152])), New Column("Aa387200", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([3.76305645302726, -1, -1, -1, -1, -1, -1, 3.38688544609292, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 1.81565944086042, -1, -1, -1
	, 2.3126602484075, -1, -1, 1.59002753949058, -2.46343800898765, -2.46343800898765, -0.0255777592700888, -2.46343800898765, -2.46343800898765, -2.46343800898765, -2.46343800898765, 2.21503192304211, -2.46343800898765
	, -2.46343800898765, -2.46343800898765, -2.46343800898765, -2.46343800898765, 1.78934171595322, -2.46343800898765, -2.46343800898765, -2.46343800898765, -2.46343800898765, -0.330622702120802, -2.46343800898765
	, -0.264440043581969, -2.46343800898765, -2.46343800898765, 0.160715596284659, -2.46343800898765, -2.46343800898765, 1.28042929058381, 0.0043235928086938, -2.46343800898765, -2.46343800898765, -2.46343800898765
	, -2.46343800898765, -2.46343800898765, -2.46343800898765, -2.46343800898765, 0.616124500994075, -2.46343800898765, -2.46343800898765])), New Column("Aa414768", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([1.30599152996528, -2.56934332420211, 1.63996588169576, -2.56934332420211, -2.56934332420211, -2.56934332420211, -2.56934332420211, 2.7254805378095, -2.56934332420211, -2.56934332420211, -2.56934332420211
	, -2.56934332420211, -2.56934332420211, -2.56934332420211, -2.56934332420211, 1.27580191203437, -2.56934332420211, -2.56934332420211, 2.1742595702753, -2.56934332420211, -2.56934332420211, 2.52088479189452
	, -2.56934332420211, -2.56934332420211, 2.09461942188588, 0.0651797360230457, -2.56934332420211, 1.39509798933152, -2.56934332420211, 1.0813775019842, -2.56934332420211, 0.150408207174271, -2.56934332420211
	, -2.56934332420211, -2.56934332420211, -2.56934332420211, -2.56934332420211, -0.562074257992818, -2.56934332420211, 1.59034030715347, -2.56934332420211, 1.68858358967585, -2.56934332420211, -2.56934332420211
	, -2.41005638772402, -0.0900389788353348, -2.41005638772402, 0.542390252427999, -0.255722801023622, -2.41005638772402, 0.399766153884161, -0.534042776343591, -2.41005638772402, 1.77698925638217, -2.41005638772402
	, -0.441397441889698, 1.25115684043918, -2.41005638772402, 0.401689332916946, -2.41005638772402, -2.41005638772402, 0.779614084678383, 0.148060534388948, -2.41005638772402, -2.41005638772402, -0.615988823239128
	, -2.41005638772402, -2.41005638772402, -2.41005638772402, -2.41005638772402, -2.41005638772402, -2.41005638772402, -2.41005638772402, 1.76747205383295, -0.494485157009868, -2.41005638772402, -0.484596854522701
	, -2.41005638772402, -2.41005638772402, 1.09029457419312, 0.864610693646383, -2.41005638772402, -2.41005638772402])), New Column("Aa465934", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.14586611648502, -0.0358581460873329, 0.093369816016682, 0.700561862565925, -0.21370878235382, -0.272390671168497, 0.0966973234335064, -0.513134617006793, -0.00754014528700059, -1.93611799856985, -0.699438949686812
	, -0.240397180969831, 0.178626529629728, 0.548431614966786, 0.652539131474003, 0.0253286106653095, -0.483132145632624, -0.25218308059081, -0.639655130613894, -0.79594191013135, -0.170823445517632, -0.0978898675819208
	, -0.856650144006329, 0.043775026994883, -0.141892757859602, -0.0189094899883764, -2.67976297835181, -0.437923902702204, -0.250993579947205, -0.370594147432187, -0.387460761465509, 0.0948477915457623, -0.257082847533153
	, -0.439216279766959, -0.0039749950304788, 0.345606673020644, -0.000535726611899702, -0.283999187928499, -0.670616623287056, -0.573376496507034, 0.470157033339979, -0.68017184747645, -0.693334158448815
	, -0.0841703565099253, 0.273225953845101, -0.896740708570625, -0.00577958890664041, 0.0246618177327347, -0.370272137986586, -0.34669313110639, 0.29578562869207, -0.206756189555985, 0.474472398646103, 0.286523448083837
	, -0.131896011708863, 0.0514974827323128, -0.290031331333168, -0.240563612791726, -0.185965020293408, 0.394692609362017, 0.195366828338373, -0.0152606553057575, 0.292844401446828, 0.151778974516861, 0.00464494890766987
	, -0.00158154567032283, -0.18453113913132, 0.286489139409958, -0.910471867837997, 0.404920932915371, -0.00357733356204158, -0.162366914415167, -0.34713648640589, 0.584170191206224, -0.115326051578294, -0.225862553185939
	, -0.0121161756927253, -0.3491661061385, 0.403592834159426, 0.259456485982451, 0.610564710543569, -0.417223161234535, 0.283918561920468])), New Column("Aa467197", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([1.28409760077006, -0.0853522356012318, 1.33581784990354, -0.93191416106145, -0.0149956830596571, 0.0254042074934571, 0.781157154082224, 0.447810233976539, -0.561021653003563, -4.90417705123491, 1.41269020033657
	, 0.738522255195703, 1.06321721941473, -0.504859744605221, 0.581114804534734, -2.77262002955658, -4.90417705123491, 0.773282276975488, 0.770669201354354, 1.37401090338324, 0.807064999024639, 1.25716975346187
	, -1.55562612819436, -2.04736464261956, -0.312094071202269, 1.85055928730822, 2.56658051077131, -2.96146208198243, 1.33390590503428, 0.0114331958467251, -0.0411638661208697, 0.674579027743176, -0.722648608832244
	, 1.27724150976268, 1.49940117881734, 2.15427377175861, 0.746510380216456, 0.628859043552522, -0.48161594203322, 1.10990531913612, 0.849277993696471, -0.454576884163023, -0.167326661047644, 0.313506441940093
	, -0.422229639124484, 0.558930033811994, 0.832990346189733, -1.84110885425242, 0.752148626044906, -0.0275259645113251, -0.407741262655873, -0.402487748327289, 0.695632347115219, -0.275832614346647, -1.03872211944424
	, -2.24268556200971, -0.171027835507427, 1.42644284903449, 1.69244507472008, 0.2143472416015, -0.09683162035362, -1.05805618937585, -0.396795642017498, 0.930489874746652, 0.195110669428449, -0.373075401105346
	, 0.103922076867436, -0.227736164881893, -0.686016796447097, -0.14914645470791, -0.755918066830301, -0.74258965734945, -0.212229738353609, -0.910900148483793, -0.116276717019357, 1.23953467672211, -1.87495053252787
	, -0.755390940879572, 0.952371130083832, 1.8329142907273, -0.173520724792851, 1.06750910095501, -0.988156201240619])), New Column("Aa543186", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-2.91622921535319, 1.4474184780717, -2.91622921535319, -2.91622921535319, 1.27518412621323, 2.85654716245206, -2.91622921535319, -2.91622921535319, -2.91622921535319, -2.91622921535319, -2.91622921535319
	, -2.91622921535319, -0.0768785434306997, 0.857567025298007, -2.91622921535319, -2.91622921535319, -2.91622921535319, -2.91622921535319, -0.935759713887433, -2.91622921535319, -2.91622921535319, -2.91622921535319
	, -2.91622921535319, -0.872861985233122, -2.91622921535319, -2.91622921535319, 1.35032559491945, 1.49805207592523, -2.91622921535319, -0.0122539221475286, -2.91622921535319, -2.91622921535319, -2.91622921535319
	, -2.91622921535319, -2.91622921535319, -0.809444742533553, 0.0898716530883236, -2.91622921535319, -2.91622921535319, 0.982126295187849, -2.91622921535319, -2.91622921535319, -2.91622921535319, -0.995740167855457
	, -1.92095179641529, -1.92095179641529, 1.96625443285907, -0.0924690125114348, 0.178138325273043, -1.92095179641529, -1.92095179641529, 1.18513043925383, -1.92095179641529, 2.39821154859678, -1.92095179641529
	, 1.95547141195394, -1.92095179641529, -1.92095179641529, -1.92095179641529, 2.04187914913661, 2.74729389900729, -1.92095179641529, -1.92095179641529, 0.371356235320889, 1.41355245895301, 1.63668002138045
	, 2.88867908317616, 0.638952137974145, -1.92095179641529, -1.92095179641529, 2.11540989393888, 1.72099514561077, -1.92095179641529, 2.51070355404533, 2.70383845630427, -1.92095179641529, 2.66540540818429
	, 2.31790308143018, 0.208268551793584, -1.92095179641529, 1.78195945062379, -1.92095179641529, 2.45327541724583])), New Column("Aa545190", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-1.52568692471023, 3.47937917659213, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023
	, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023
	, -1.52568692471023, -1.52568692471023, -1.52568692471023, 1.48041394373128, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023, -1.52568692471023
	, -1.98342361469311, 0.312676808875709, -1.98342361469311, -1.98342361469311, -1.98342361469311, -1.98342361469311, -1.98342361469311, -0.203213054541357, -1.98342361469311, -1.98342361469311, -1.98342361469311
	, -1.98342361469311, -1.98342361469311, 0.252240773846293, -1.98342361469311, -0.0249203309298787, -1.98342361469311, 1.08663923043908, 1.07559883030132, 1.49647620977399, -1.98342361469311, -1.98342361469311
	, -1.98342361469311, -1.98342361469311, -1.98342361469311, -1.98342361469311, -1.98342361469311, 0.591624499482331, -1.98342361469311, -1.98342361469311, -1.98342361469311, -1.98342361469311, -1.98342361469311
	, -1.98342361469311, -1.98342361469311, -1.98342361469311, 1.62306251428861, -1.98342361469311, -1.98342361469311])), New Column("Aa672651", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([2.81523292027604, -1, -1, -1, 2.26156080914822, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 3.55191402104942
	, -1, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, 0.640530379746941, -2.79813846981145, -2.79813846981145
	, 0.390759601978191, 1.75032591971506, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -1.01376332592998, 0.749016877344312, -2.79813846981145, -2.79813846981145
	, -0.540564450379237, -2.79813846981145, -2.79813846981145, 0.0737028510691526, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, 0.609248383462411, -2.79813846981145
	, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -2.79813846981145, -0.952282294774326])), New Column("Aa792892", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.999558602847808, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 3.13773026808137, -1, -1, 5.72941601790856, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 2.77498589591564, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1
	, 2.76663572728425, -1, -1, 3.40077825354302, -1, -1, -1, -1, -1, -1, 3.25559628473738, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 1.95271339623582, -1, -1, -1
	, -1, -1, -1, -1, -1, -1, -1, -1, -1])), New Column("Aa986860", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.252914456323856, -0.341968130135721, 1.27277576627463, -1.14260922530588, -0.774981461982331, 0.180245490396191, 0.488580001792252, 0.680400912599102, -1.18140082367878, 1.07588109051824, -1.61128348248461
	, -0.112953579095842, 0.532028018008303, 0.971359122502745, -6.23280544527641, -4.10124842359808, -0.166292360705351, 0.101599987615533, -1.79827703424092, -0.482329582606065, -0.113426666952383, 0.657421568685297
	, 0.255844566769135, 1.30014910560885, -0.2198669645458, 0.127629614653369, -6.23280544527641, 0.198959968859092, -0.635914433041952, -0.0562142304576665, 0.317701087603351, -0.116125536274017, -0.371068732973793
	, -1.70777943082008, 0.222631454647097, 0.315699853151761, -0.799732090631412, 0.376691863128095, -0.121156680727182, -0.646964868726063, 0.507215689461345, -0.384947508255386, 0.166532238237182, -0.479929545662569
	, -1.44535882597072, 0.243134284347896, -0.221377925144165, 0.169902683920676, 0.274898876290278, -1.36457631399109, -1.30984271273344, -1.40451031390998, 0.024765747263652, 0.116722913121481, 0.139804957032113
	, -0.346763473759914, 0.359115153888057, -3.12685916671964, -0.495146581378385, -0.324541508282205, -0.187662079684857, -0.0703182442404869, 0.425650153330557, -0.50612260288532, -0.573914982156877, -0.860487335538108
	, -0.349409802591862, -0.740266133145369, -0.223725515292635, -0.805549116868012, 0.145806293311037, -1.25793285588049, -0.295787355087979, -0.137484578723332, -0.885302368604683, -1.30188082428716, -0.541636909693758
	, 0.088663644200587, -0.283883330630115, -0.748684392201103, -0.278681648334513, 0.0386354632176634, -0.475597769357723])), New Column("Aaas", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.383255064287147, -0.819476957991885, 0.156439153402618, 0.570246813941001, 0.144013634299021, -0.318222122643122, 0.0806952453636388, 0.609708362326292, 0.121810565676533, -0.291338229379988, 0.132029860187234
	, -0.0619599763830828, -0.0101953470995474, -0.339806081287404, -0.00610783190883059, 0.343595556938399, 0.45922973360779, -0.130926651151672, 0.165193251694176, -0.206898478849824, 0.131898911211078, -0.794838068502187
	, -0.102896464955342, 0.409293563404236, 0.55155699228134, -0.356845033973926, -0.43366453025713, -1.14360735425608, 0.0206078415932036, -0.455298749069097, -0.501102687605352, 0.166854099133093, -0.507628717667104
	, -0.545874094491185, 0.710739555216695, 0.351473697848172, -0.288579879477547, -0.16073061092856, 0.0879418542060516, 0.0645434263665156, -0.0709934841681453, -0.315163916650888, 0.648526816231598, -0.559867026498418
	, 0.0122295161347135, -0.648408032548762, -0.392988205504094, 0.110033763476781, -0.21809731163505, -0.720946893842597, 0.236241573156313, -0.356424449229177, 0.644796415743706, 0.00233017108194139, 0.186032237304362
	, 0.197988490969018, -0.234861621276321, -0.293874293977374, -0.14698338452267, 0.47975944928883, 0.46108030586526, -0.433966310854933, -0.0111475475899691, 0.0707282780733573, -0.1718097991457, 0.131497981311102
	, 0.367206648693032, 0.0280724281080651, -0.138777008383874, -0.395191287852321, -0.627408009263626, 0.115171560510814, -0.00594253840815298, -0.500049728051291, 0.0947396534104383, -0.285663273094631, -0.533012656022874
	, 0.0102176087763959, 0.286476870680107, -0.398072183348718, -0.173476183552629, 0.160232910901902, -0.264953818630011])), New Column("Aacs", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.137879412293336, -0.214232151242607, -0.607802853653451, -0.0000509962553874953, -0.235167673570545, 0.356592972775085, -0.316888362503407, 0.137496204112697, -0.178623273861549, 0.130035893155972, -0.644412520397794
	, -1.04257353485421, 0.288343197604592, -0.0478714962560644, -0.509629638001409, 0.423155505012218, -0.513115934416314, -0.755435953213785, -1.00990118305775, 0.182162050763296, -0.630493781666373, 0.290672287268647
	, 0.335285043757299, -0.328174636919978, 0.112458987807708, 0.343579225404331, -0.550143436157038, -0.0987724277521318, 0.325057123940492, -0.114863056957727, -0.161039209142336, 0.280824326167431, 0.201688745222498
	, -1.4154017777241, -0.424384510753387, 0.222263529155952, 0.584650355011814, 0.0725076510023398, -0.549558283161202, -0.149271353136928, 0.0119531224667388, 0.0359844293285913, -0.423574370650912, 0.327402794278865
	, -1.19699905353619, 0.111214853029653, 0.377692669162071, 0.385672465307116, 0.0355574528545242, 0.417292858289973, 0.152311915361472, -0.158583063439984, 0.155438112019605, -0.00147538379074335, 0.267575692721814
	, 0.370440967937263, -0.284081380433343, 0.0874134998781335, -0.559410096768063, -0.978085454755212, -0.270477240089023, -0.392088186680322, -0.328163949924472, -0.016795647057828, -0.373752169585948, 0.26443810563171
	, -0.218391642886131, 0.0834241285628991, -0.0942641604523044, 0.082889336228506, -0.230104463286827, -0.570303422301331, 0.131940982297379, -0.0445041952280137, -0.255494895847473, -0.421988302938458, 0.127390873083606
	, -0.285665043026049, -0.540200343526685, -0.394384850629408, -0.296119243326174, -0.545324188934496, 0.169311063304795])), New Column("Aadat", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-1, -1, -1, -1, -1, -1, -1, -1, -1, 3.03957007511411, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 2.4954602412827, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1
	, -1.90543132447921, -1.90543132447921, -0.18320376660303, -0.223223236996024, 0.184996888536126, 3.24239206294588, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921
	, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, 1.81959668528284, -1.90543132447921, -1.90543132447921, -1.90543132447921
	, -1.90543132447921, -1.90543132447921, -1.90543132447921, 0.966409996401399, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921
	, -1.90543132447921, -1.90543132447921, -1.90543132447921, -1.90543132447921, 3.04025077136512, -1.90543132447921])), New Column("Aaed1", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.866918714639215, -0.0355529318787036, 0.35978852940279, -0.55217077044421, 0.518156810882079, 0.379232536157697, -0.570236079145646, -0.151756784412569, 0.496699444781486, 0.5041225287666, -0.690033540606024
	, -2.03721471074637, 0.167734343603438, -0.742878479758855, -0.0689301888841066, 0.275986405515705, -0.920344313868928, -0.279551847933717, 0.439622251350578, -1.36954567909656, -1.14025721891798, 0.1226250050842
	, 0.226659203391946, -0.992815983629899, 0.321191612737405, -0.805080206654978, 0.113075635846489, 0.739002676876075, -0.554352460236338, 0.539802749330687, 0.151093659592801, 0.97428285752189, 0.0962633206168462
	, -0.418336721223444, 0.213461604322663, -1.2242311915235, 0.0216255668069706, -0.179352043059626, -0.602554890518938, -0.128283155293057, 0.510781055384569, 0.308289924158196, 0.0463106414965851, 0.188124194112507
	, -0.223780119687496, 0.483797694548891, 0.200273873098006, -0.0346324866891596, -0.402653241157418, -0.692452423786994, -0.582520411249499, -0.706287708096161, -0.356083543337492, -0.465972692494497, 0.367892753858363
	, 0.0248625108841381, -0.195306020012966, -0.584128169162088, -0.16693652193702, -0.133195111737126, -0.20714006846831, -0.284622232700636, 0.249533595103734, -0.393056574983021, -0.272654498715194, -0.0834356286024346
	, 0.27351075105437, -0.289326610765915, -0.440502737115976, -0.193285648440968, -0.0638422912127192, -0.230453176660898, -0.692983753449574, -0.637256627875435, -0.442444832740862, -0.837461587145015, -0.276158563472018
	, 0.449828676999931, -0.67636223909018, -0.691271314153755, 0.131887831369694, -0.249671050653053, -0.421616980225493])), New Column("Aagab", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.100521830553712, 0.00297614431517097, -0.250573372384645, 0.020345100941879, -0.795980126401101, -0.367137463761609, 0.0477273362740658, -0.926208226887568, -0.056043357595617, -0.861839205114859, -0.270041063163989
	, -0.501651762675685, -0.258499879782122, -0.655641547468853, -1.12788136649218, -0.268546792500635, -0.471681477699587, -0.785631896863, -0.993289952181361, -0.126882514054691, -0.526844437067745, 0.0274602257702533
	, -0.090249900918637, -0.0479754134172946, -0.333379929769897, -0.0815922172619355, -0.351217183449455, 0.420838459027956, -0.00437786089940912, 0.0896468132785762, 0.054683197402032, -0.466683554982977
	, -0.226272724442168, -0.411336453361619, 0.30473218287109, -0.472502659508257, -0.185405392617881, -0.352623574558784, 0.120205532762251, -0.0926901018336059, -0.707611416359054, 0.0137804774720775, -1.27160769823023
	, -0.270449769046637, 0.357274652569368, 0.112351545477514, -0.121925291368892, -0.0802326261951685, -0.0743468114874925, 0.106212177331855, -0.104270960392248, 0.0749061476561561, -0.102179044666763, -0.199536708198717
	, 0.200914953509815, -0.241491129607871, 0.136317228946505, 0.112399477879292, -0.412849112300404, -0.508560325370698, -0.172969877921291, 0.315393512708071, -0.212177273883628, -0.0877085078699317, -0.101217723578743
	, -0.41440020696123, -0.220828659355364, -0.300736721104674, -0.0382574974271433, -0.126113666815025, 0.0836187028384535, -0.143628540791061, -0.390562096252611, -0.536627694815133, 0.301609952204373, -0.125235238613051
	, -0.0241555274906938, -0.489722916376312, 0.0718441493546511, -0.137888494750066, -0.0883027254277595, -0.176535972225986, 0.0788898459661458])), New Column("Aak1", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.0354042694136597, 0.266283378393392, -0.159523061747656, -0.00698174605454272, -0.0139128153323474, 0.199842364646832, -0.046867646239236, -0.229500195192868, -0.0574110302567293, -0.269743746010014, -0.497441469727088
	, -0.0506710646815626, 0.0862070985500838, -0.0325986119837598, -0.28390476738472, 0.118963857071927, 0.0704449765832877, -0.0683177235340117, 0.0413061497135767, -0.197132201801167, -0.476510160155775
	, 0.00374144687812452, 0.231929745594496, -0.088785239074703, 0.0510869386172106, 0.109613728658471, -0.0208744681562934, 0.0263742931365675, -0.40847196424356, 0.287065856738527, 0.214149507272487, 0.0041976358717372
	, 0.000272409544348035, 0.0201343899143007, 0.14386935358233, -0.059816182361019, 0.208294161474224, 0.221191752756942, 0.390515064064585, -0.0624834882441886, 0.201282993724207, 0.0262057397895911, -0.333377586296181
	, -0.20728612765797, -0.00621204873976824, -0.141546880506677, -0.100474635618629, -0.0265155805611655, 0.0105829033983886, 0.127529499629862, -0.105552357290564, -0.0260368133109543, 0.0590807014295958
	, -0.0554851157810881, -0.0788283400082807, 0.0857201493517732, 0.0816546907419002, -0.0780830143395771, -0.0959709478400637, -0.138715760620628, -0.12288768918618, -0.25085543579183, 0.20512128278562, 0.0422479173621098
	, 0.0771894746125473, -0.0662950792658114, 0.0996977030849508, -0.138327756501366, -0.134126418574465, -0.0950430682594122, 0.0291665977983075, -0.184626209309898, -0.216376624917143, -0.116745889399779
	, -0.10130006594913, -0.124283393734176, -0.240954463300682, 0.037317458955626, -0.00309987762193511, 0.0138956962113796, 0.00983757102644603, -0.557887237420153, 0.0422757599209043])), New Column("Aamdc", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.1995417231616, 0.123238734209101, -0.0390174510887904, -0.366124584631915, 0.189889153421849, 0.297315792730439, -0.204861778051628, 0.644196148330344, -0.150340882514954, -0.119916842264003, 0.035349438843336
	, -0.50967082991462, -0.0235802583781394, -0.0125465117502787, -0.269360909399128, 0.436729579373655, -0.145394093837207, 0.70914871151124, 0.072867844705939, 0.486446502371712, 0.497376794749748, -0.521483110882799
	, -0.171156346630022, 0.0404257665752714, -0.0283880699398478, -0.0798331350163332, 0.715836270086955, 0.0458377951290441, 0.482563701556475, 0.288288328102475, 0.141299276808309, -0.0085896338880864, 0.316427989457033
	, 0.551174111186787, 0.113236463538881, 0.223362715252397, -0.00144842145267556, 0.252345831476073, 0.25827309106779, 0.182421968166936, 0.462444408899306, 0.309510496751765, -0.046517900154863, 0.573458788963355
	, 0.350505615170925, 0.0857958988064741, 0.219667772531018, 0.287783935212656, 0.129277147718095, 0.200785510352826, 0.253893120814467, -0.0452644848567144, 0.0129784131152476, 0.155910570025335, -0.159921429783434
	, 0.19859629454403, 0.0504232938631741, 0.112537300641231, 0.170425419981434, -0.171376748211555, 0.246494914538051, -0.342642511263233, -0.024932333524311, 0.235166111661173, 0.109794383222558, 0.492622527641912
	, -0.0506080203231015, 0.0468770534321241, 0.236444005862752, 0.308199573906992, -0.018446774324008, -0.086051285359184, 0.0669629201403048, 0.240447678903782, 0.170650053499304, 0.524364248760436, -0.158103185956079
	, 0.209939470184791, -0.0557519044179111, -0.15710720153555, -0.0717279656630581, 0.205996781401857, -0.0989275401586824])), New Column("Aamp", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.000242044651138889, 0.0688676533156075, 0.346279133273694, -0.0988388487142752, 0.166437228561251, -0.0713731763908139, -0.30106214702515, 0.333717663602492, 0.130067664181179, 0.316944479145663, -0.107470689389753
	, -0.206446381934179, 0.421918051381814, 0.0928281568891359, 0.651706690838167, -0.00997167182745604, 0.220096983619569, 0.0169869624555956, 0.434498389470461, 0.137224487527158, 0.277159625059149, 0.278599194828827
	, -0.00253189258363462, -0.201502449149159, 0.101893335940831, 0.694052436750378, 0.132439185999581, 0.101637356685953, 0.0515499611759032, 0.202844301306394, 0.145526378095252, 0.501038153476858, 0.267827523341214
	, -0.209007983513515, 0.0798920207495959, 0.276774188071595, 0.099163045670281, 0.205743282864671, 0.184669297450094, -0.0906855543142197, 0.2784618904451, 0.00875065315072407, 0.0307864683555921, 0.291541997712992
	, -0.0976357904498086, 0.0894847115464419, 0.169856652086411, -0.0890112085915993, -0.191723994819631, -0.0646880453275847, -0.00540356922916751, -0.0478914123346859, -0.147266055159303, 0.0195249048436687
	, 0.230074212000333, 0.37722670986377, 0.0511393593217858, -0.0601677538152307, -0.0781266854751454, -0.138819276865822, 0.146667427477973, -0.160819167327181, -0.240274942174234, 0.110385788909953, -0.0678587392997783
	, -0.004702833619961, 0.173320231509055, 0.0103324493985738, 0.0970943225382516, -0.265829355471097, -0.0497896228407147, -0.246504515622619, 0.185495469178196, -0.0559327759930007, 0.15927271404188, -0.12010084459336
	, -0.0292140337950439, -0.21502708091681, -0.133147095986847, -0.296128181719413, -0.217846738760879, -0.0747472739580072, 0.150051962989742])), New Column("Aar2", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.592382438036819, -0.999682893616537, -0.491439613330293, -0.763393510991596, 0.565718373232432, -0.642168063804764, -0.165390769862364, 0.023458258414294, -0.753873096020482, -1.0098834289865, -0.76348554279401
	, 0.5397558741921, -0.345315543891851, 0.330278030752466, 0.855444362019104, 0.0720246512253897, 0.270148762915413, 0.977543100691486, 0.0143613403771042, 0.556451762304933, 0.357959511417538, -1.80074497212904
	, -0.145464633133596, 0.856532152537658, 0.0196153972534453, 0.552883897841962, 1.18213519879395, 0.029037381487142, -0.301668699837523, 0.423937227104815, 0.104147904944366, 0.680195558521881, -0.693859512914635
	, 0.531165653893584, -0.476613214504396, 0.939333359676733, 0.128098366296504, -0.286018399613739, -0.292469204302475, 0.401469785473574, 0.204947750133429, 0.0629496833945168, -0.118041709584362, 0.435037237985132
	, 0.302664868710522, 0.181823271616306, 0.498162261116281, -0.129414907937149, -0.168624186516742, -0.714015907039339, -0.0608670725455505, -0.0847303600353296, 0.421346621900374, 0.437949827748001, -0.91004842645499
	, 0.0336258745657573, -0.400588247705265, -0.290679620707218, 1.2459037869453, 0.0921847516875417, 0.226988087928731, -0.132975713686276, 0.266159958415945, 0.419408339763512, 0.393488977094261, 0.335217146211757
	, 0.335682569380143, 0.0428992600999855, 0.370140774736476, 0.151871102312714, 0.186382916937519, -0.0915917470964313, 0.392760740338252, -0.218212032793407, 0.884666075151955, 0.020644999738634, 0.032464773777119
	, 0.502399052437045, 0.140756463093144, 0.173397602104927, -0.284155815120194, -0.122142865366025, 0.376810989051211])), New Column("Aard", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.576436768617217, -4.18661968441004, -4.18661968441004, -4.18661968441004, -1.43669940962824, -4.18661968441004, 0.526481735855759, -4.18661968441004, 1.33772758838227, -4.18661968441004, 0.272284753876763
	, 1.01908335896062, -0.831114529243879, -1.43312892743234, 0.984773199512106, -2.05506266273171, 1.12934900979788, -4.18661968441004, 0.875517713179956, -0.654673738678681, -1.21353950105741, -4.18661968441004
	, 0.0893183416664882, -0.432987368388902, 0.221338201361477, 2.56812020246164, -1.36240116790686, 0.383495465405844, -1.22847912209932, 0.728990562671595, 0.931141675415371, 2.0030208932321, -0.00509124200737417
	, -4.18661968441004, -4.18661968441004, 1.88261072169985, -1.18051881596853, -1.37096024354962, -4.18661968441004, -4.18661968441004, -2.00718486331753, 0.262980482661847, -4.18661968441004, -0.96064443686274
	, 0.113075215743552, -0.283471748907417, -0.311644182947569, -0.855008407309954, -1.98602788877821, -1.91615493263892, -0.31533366177574, 0.424068995417314, -0.217808846901558, 1.23909372740497, 0.0584703974864285
	, -0.0856399903232328, -0.134256454367433, -1.29584413722888, -1.1911110613303, 0.259107263546144, -2.07764357515421, 0.150667538001512, 0.744511234228503, -2.76346347206447, 0.730415524296485, -0.954570276955472
	, -2.6387047594991, -3.13480888646355, -0.85226280364754, -0.365211864588248, -0.0997941281565697, -1.15241147935986, 0.135951614814516, -0.720318743666418, -2.18582756491525, -4.89627877893131, -3.23940160087865
	, -0.683116170871343, 0.191430113766816, 0.744165351448713, -0.35026462968852, -1.81657687309291, -0.452851346372583])), New Column("Aars", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.381552519473018, -0.277271955274264, -0.366419945404805, -0.0129862420213077, -0.258102473889839, -0.222602769742451, -0.359027608939517, -0.0593905993703989, 0.039191208786346, -0.203198823470718, -0.564643048821888
	, -0.346787997263488, -0.0238380306724403, -0.603675587025865, -0.21554589109837, -0.559579513681193, -0.0671727372426867, -0.267799066178486, -0.476871295353735, -0.109007332147553, 0.816214077606811, -0.325480902068951
	, -0.0674675031865156, -0.238161581788818, 0.01228266486886, 0.165729570351727, 0.661834861438848, 0.0108385168866115, -0.414664917591459, -0.310033699195616, -0.228077460164272, 0.332938487944097, 0.728319214134915
	, -0.198328691643175, -0.036869712524248, 0.247282910063405, -0.0674687758294303, -0.318633016360934, 0.16543040769424, -0.4558430715265, -0.142781446525554, -0.191552054691724, -0.0521964196429233, -0.154749369323716
	, 0.126533248439089, -0.264514757470167, -0.240209172424381, 0.0454510266639136, -0.218420489859272, -0.125746218253605, 0.0129255068576734, -0.165457378373924, 0.619832154510543, -0.109170240396971, 0.0487448806055312
	, -0.133077033557339, -0.0571689025640866, 0.70144110092893, 0.117629679034054, -0.0965221595892085, -0.266858913442767, -0.19088785348628, -0.288034667817304, -0.0262358209859552, 0.539488327652539, 0.194345710180902
	, 0.031677066618786, -0.122416458166546, -0.457980965999695, -0.195584226977366, -0.300629813751965, -0.254695719748261, 0.0914529106883055, -0.189204815404611, 0.0710496178134, 0.0835262820230994, -0.5795208263242
	, 0.35910997892207, 0.196561235966929, -0.157379440952257, 0.107846513449965, -1.23189639553942, -0.462356822349298])), New Column("Aars2", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.56370000391017, 0.259049425906782, -0.142458974847272, -0.538439166310289, -0.528815874999131, -0.284059774597781, 0.321046203192238, 0.256932462519103, -0.0140960698080141, 0.252353990895745, -0.825758056585292
	, -0.146247084249886, -0.0588481881395468, 0.204446965893634, 0.335845919707866, 0.163390617505524, -0.343917181701013, -0.683406521937351, 0.0473014103196169, 0.0983336659707447, -0.181536583305699, -0.124711851215716
	, 0.0540172269890754, 0.37943478614697, -0.0968119818025529, -0.165018111994858, -0.112755947745652, -0.172524830696924, -0.127819570302777, -0.260649593074262, 0.101732497488727, -0.132513745034011, 0.0192705084422455
	, -0.452733662724549, 0.355009328385283, 0.350565950703948, -0.0189085403484019, 0.290827032443408, -0.279130918186852, -0.230455208428982, 0.323004538372492, -0.161120684894872, -1.14477746926977, -0.295193671930399
	, -0.250129018199609, 0.336055068165784, -0.508675006951189, -0.297616825538141, -0.00835175189357172, -0.313539770031452, 0.128042512375108, 0.250764863166205, -0.290199659919622, 0.024916109478158, -0.718596815755164
	, 0.0621879919222842, -0.016955556222126, -0.513740049801874, -0.0804304869741852, 0.0145328825062473, -0.223688264503534, -0.230070232870466, 0.0285166005993779, -0.483535332248298, -0.375079164568314
	, -0.821284449532678, 0.421073405401421, 0.11482040162911, -0.00504974370860894, -0.280873736277437, 0.311422240289048, 0.00169964447847356, 0.465609647948016, 0.129628780280995, -0.800541349273108, -0.578203531847002
	, 0.113268717642004, 0.276764471470356, 0.261329058301162, -0.188039145813639, -0.0944419635973278, -0.988799392231905, 0.0828118317216048])), New Column("Aarsd1", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.0775309297239199, -0.77023652469145, 0.453700238730086, -0.165231385257632, 0.258071437244498, -0.0458898936780413, 0.511249724651048, 0.263048328997108, 0.0615472043308184, -0.660279511396255, -0.674353655064956
	, -0.111878753756913, -0.452420549513107, -0.289891672499848, -0.190172376947098, -0.259999663745776, 0.624781283150298, 0.0621853800690253, 0.523000772041049, -0.033431636211845, -0.150941220326053, 0.44487991789303
	, -0.803544882785047, 0.0439631293580361, -0.125143424845783, 0.167413649894632, -0.615938926095215, 0.00633288872889345, -0.249384509374555, -0.19092459202529, -0.00925189424806262, -0.0244013819027655
	, 0.20363362467533, 0.283429133186117, -0.0029543784541501, 0.0614187810633516, -0.898110293905064, -0.28532496927276, 0.376142578038583, -0.139027110041917, -0.191098444982526, 0.15629398772134, -0.334454051385482
	, 0.146240168266551, 0.288747557683449, 0.0211099329659213, -0.121404361547396, 0.12330125945463, 0.124987753408286, 0.333774787247538, 0.0174394429017688, 0.0945462077533155, 0.350817788161354, -0.11477264702456
	, -0.113584836460398, 0.234861491628534, -0.270580107752752, 0.160256001009865, 0.156362790884484, -0.01530904018819, -0.444859365697234, -0.153189397084576, -0.00309606205385402, 0.520761872043527, -0.87359971724711
	, -0.13715385663458, -0.0102438842196419, -0.17968884017154, -0.0732099589868824, -0.277329750309972, -0.440211148321931, -0.0792268014263261, 0.321679701233516, -0.530011571724311, -0.0932253632677, 0.234750995345865
	, -0.402991888951703, -0.0578988111749439, 0.201572715580303, -1.64390445741411, 0.203178188558452, -0.506787467820891, -0.478831683487924])), New Column("Aasdh", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.0641296957809942, -0.531085318420014, -0.168067903852681, -0.0566243977406144, 0.0889941390432757, 0.499223606005335, 0.0673613939267232, -0.149857058369372, -0.26577408150552, -0.360089630940763, -0.594400588763624
	, -0.337204862475981, -0.541076679554104, 0.662448649812306, 0.178233116231485, 0.224683332011629, -0.207339626998613, -0.167841848198272, -0.52322004601046, 0.256076300696271, 0.229836068913518, -0.433943687241812
	, -0.604277529034139, -0.0919800103479309, -0.0987685121059183, 0.0848579791458568, -0.346136145509651, 0.359257794374475, -0.316988086561503, -0.254045036458178, 0.193387516073782, -0.103859813434069, -0.0864495927725812
	, -0.00309787600660745, -0.33738909097666, 0.109579168809138, -0.370791572722859, -0.186802208670549, 0.194610393736915, 0.259398911794793, 0.54416037698582, -0.0552468739954544, 0.227732775826661, -0.255939041632832
	, 0.234777952382031, -0.133937084306603, -0.0704648790105423, -0.059627656284882, 0.281220409179924, -1.0411803835504, 0.475027432820981, 0.0860034937822701, -0.0908023285220956, 0.102063484785029, 0.0477409412313813
	, -0.103458340413888, 0.229720831565208, -0.539272913243195, -0.0452826272580367, -0.319871252978417, -0.350513581415917, -0.0786523597487941, 0.131280219301453, 0.143050787480676, -0.25409622431794, 0.00676232086566999
	, 0.467600928994669, -0.394164543889778, 0.0875687349865572, 0.230852919308426, 0.201091416664657, -0.13722649307952, -0.470953710361318, 0.149109516649162, -0.0687035780484021, 0.218308232102038, -0.299152716703581
	, 0.735428801063257, -0.106539135140873, 0.282873983336278, 0.447415253815101, -0.593606745668544, 0.0902605991578141])), New Column("Aasdhppt", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.26098496657189, -0.214384961116347, -1.43490445585715, 0.512618962389607, 0.683287357773077, -0.353950665301337, -0.367280769782585, -0.759311806751667, 0.570909773257077, -0.679894546318779, -0.766847768549455
	, -0.509017522712098, -0.505998878237998, 0.159136872662728, 1.07588346920567, -0.649057206070534, -0.926402195401432, -1.06268771476089, -0.336421283680411, 0.246312373191365, -0.0168294619218686, -0.848545515975163
	, -0.334690733657502, -0.982812592271055, -1.42444473074097, -0.80560053069922, 0.138864039595061, 0.360616028433647, -0.137444998702662, -0.185394463820601, -0.143145763447753, 0.181500045667645, -1.23241923075404
	, -1.28538210104772, -0.41505304843766, -0.135595163357538, -0.494581236944381, -0.506621600830845, -0.858200562489999, 0.415770620939997, -0.113988323908326, -0.830191038289966, -0.14471233306653, -0.416640415014981
	, 0.272583455826104, 0.672438626457735, -0.112173272259756, -0.55174383666688, 0.81746027769916, 0.422315571015344, -0.0736102955820408, -0.122720918606961, -1.19601980787473, 0.339173540527786, 0.216491304303007
	, -0.363212148090257, -0.0148135680616873, -0.419794313553921, -0.363959405342507, 0.0223805119903572, 0.0385628091939914, 0.176773684260199, 0.019725084163762, -0.0309742000414543, -0.411901006511386, -0.0767608254745185
	, 0.252517094962624, -0.247871148104094, -0.769045198009395, -0.441573765637234, -0.369412316646541, -0.442196948125574, -1.41841385849261, 0.0381511647297566, 0.178371062308783, -0.79501795772227, -0.162154902259007
	, -0.370979351116612, -0.131184460739919, 0.110679498816888, 0.309903334897374, -0.709893070424897, -0.292754588467881])), New Column("Aass", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-1.33429897067622, -4.24854370087211, 1.38854424152265, -4.24854370087211, -2.29867272348175, 0.867753042341526, -2.04560254131496, -1.93117709199367, -2.17264325503116, -4.24854370087211, 0.773288820056137
	, 1.48545906460775, -0.893038545705943, 0.334847366395996, -0.0376621060215176, -0.7701278338753, -4.24854370087211, 0.372822555767717, -2.26807419940635, 0.998798542458095, 2.18860680993472, -4.24854370087211
	, -0.220822178531046, 1.5893281293781, 0.159414184899413, 0.496958208669943, -4.24854370087211, -1.50684627919627, 0.442308927827179, -0.444312542699738, -4.24854370087211, -0.303859678070377, 0.328007122571316
	, -0.662178113930418, -4.24854370087211, -4.24854370087211, -0.335146428106065, -0.239463078243343, -4.24854370087211, 0.725557602287833, 0.222550346865237, -0.258199001741251, -0.839261191584297, -2.32805465337437
	, 0.230001827665644, -0.159585074024723, 1.10858267245128, -0.383205238913175, -0.786832878179109, -4.21661402987405, 0.364331087281531, 0.301472060826317, -4.21661402987405, -0.150601413672008, -0.216078437700039
	, -1.0277159580844, 0.331850359652465, -4.21661402987405, 0.0361656950668213, -0.567419103553394, -0.504029958303846, -0.775112969544648, 0.452805319270636, -2.0837987230072, -0.923598415182059, 1.12350791997252
	, 0.349665481095046, -0.0682463065118867, -0.418245853283473, -0.146227236147411, 0.327181933842316, -1.13965090160889, 1.31690207771394, -1.1603683224371, -1.50616281585798, -4.21661402987405, -0.417527409909484
	, -0.689471689056249, -0.388559349093595, -0.491912283656667, -1.13705151989232, -4.21661402987405, 1.00546675371112])), New Column("Aatf", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.731501079003895, 0.612353261076841, 0.0296788326643995, -1.00122324993935, 1.31740583712885, 1.06746250572805, -0.839173365239262, 0.748289896871536, 0.44124836022798, -0.424093404791089, 0.469444068739964
	, 0.0933995832106367, 0.503271665450702, 1.2896457277611, -0.244545567032124, 0.667580392167989, 0.383576001681059, 0.181979949480888, -0.139559439453006, -0.340440373063514, -0.667173876704508, 1.05850956381585
	, -0.684550152629721, -0.353039250628702, -0.0805807950423467, -0.114904579993209, -0.504431625675751, 0.685636310404034, 0.173488540965222, -0.903167129151036, 0.45945140936709, 0.0059024236032211, -0.0149793897076702
	, 0.282228144214295, 1.13363563237285, 0.748138455685411, 0.157452909528033, 0.888447132478878, 1.41776717120261, 0.0159652734015395, 0.118643198380056, -0.216036915458417, -0.618364785272745, 0.980734570892635
	, -0.137828631447932, 0.185571960481595, 0.184761078929796, 0.0627050254218249, -0.040564652963393, 0.20406271313043, 0.804476136345161, -0.492743243045834, 0.403236425961363, -0.27532814582575, 0.538429477630375
	, -0.306330390243911, -1.02146438151773, 0.617845490281972, 0.415464810470803, -0.179658219522744, -0.0777717775163843, 0.220341322828236, 0.116841632671536, -0.583142224314517, 0.863203214152486, -0.396796551641597
	, -0.227642182573046, -0.415686713497748, -0.917190503646648, -0.395106181130231, 0.479219423489087, 0.313764626258507, 0.50055813107395, 0.371209537584459, -0.539248531637803, 0.550832123741304, -0.407766952100223
	, -0.479950642820783, 0.262101609278626, 0.0928044795768769, -1.72105556852827, 0.253103046297972, 0.711676488187416])), New Column("Aatk", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.0602648425763588, -0.0427194504647922, 0.0849939243188179, -0.236845268247073, 0.159865996342218, -0.181591518126898, -0.38591740839424, -0.249336735741599, 0.0501593795459041, 0.189453269454154, 0.10749907214905
	, 0.0290738855803278, 0.354135592337746, 0.239635577068661, 0.639519723790691, 0.266720747921629, 0.11150720231698, 0.0224487242501498, -0.145766176804535, -0.344733297797245, -0.540442014853709, 0.242770211645615
	, -0.0683871636148114, 0.0203849896292792, -0.109292008700374, 0.0996455112224629, -0.531314628759109, -0.0656075251245115, -0.247099295185248, 0.0355666722362577, 0.337412739112654, -0.529131826983343
	, -0.0514037657746665, -0.221839273213766, 0.152268931302268, 0.124055247084687, 0.252947018216209, 0.358618670060248, -0.16105174531361, 0.286476391646315, -0.0816675537934738, 0.0331286682415839, 0.241718036745509
	, 0.319101637583313, 0.360872330784111, 0.0567141905180041, -0.352306900555711, -0.318736120440883, -0.0677350781268134, 0.179821840552836, 0.211828462137175, 0.185197973752504, 0.0978221920199035, -0.317098763076642
	, -0.0153136024687647, 0.256587766481416, -0.0573106830327553, -0.213062578629831, 0.0852641247306076, -0.322113549269397, -0.0562350283874333, -0.104039982273103, -0.116570355362194, -0.0419612995479431
	, -0.12549501180162, -0.105819089084859, -0.0168731112603016, -0.192116255334477, -0.190454895205564, -0.105662504841623, -0.0821315488177484, -0.147162626684985, 0.0673530388666669, -0.191564366164622
	, -0.228292899556915, -0.317068006684324, -0.250308353663058, -0.0749036477346226, -0.238628455760148, 0.111168581077966, -0.162481709425458, -0.782637552240827, -0.21468755918986])), New Column("Ab041806", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-1.7488880931609, 0.374727125828209, 0.0694331186096393, 0.464817640711023, 0.61571707153042, 0.570760274164787, 0.81811382241491, 0.731088232505027, 0.601881525256183, 0.0992528232702634, -0.240696835046214
	, -0.196023379931541, 0.119502153348152, 0.570063099233579, 0.52591589272696, -6.92962029935519, -1.8970668608962, 1.0708239806114, -0.474950063091668, 1.20840800608798, 1.34316610738257, -0.715045201878828
	, -0.0308491926794609, -1.53702773793251, 0.615133296828739, -0.609278269626691, 0.329674106686765, -6.92962029935519, -0.289041336836592, 0.893197316971388, -6.92962029935519, 0.544384269433581, 0.530666648599411
	, -6.92962029935519, 0.313880173340381, -2.92769182102474, -0.919243830126821, 0.0402360521896716, -0.231026280252822, -0.078170497676765, -0.020534612849848, 0.773272890603599, -0.369753961301677, 0.254439147815329
	, -6.82218638333476, 0.364061808371128, 0.0738737012494593, -0.493511408440505, 0.589775244930729, -1.67068323282492, 0.456300163519756, -0.101919419754366, 0.972919988498396, -0.0363154377012626, 0.180604770517688
	, -1.56435659260566, -6.82218638333476, -0.842445907942234, 0.53961009994317, -0.858225510050698, 0.338164475009944, -0.177969007270124, -0.0121473690945378, 0.382649429606473, -1.38750229462682, -0.156285613099291
	, -1.08099805652573, -0.683433593093228, 0.48475902773233, -0.370697536079117, 0.291252124390516, 0.668529442808329, -0.607777708634468, -0.649902796123809, -0.215113715161105, 0.719863363846495, -0.233044755977211
	, -1.00192724760467, -0.464781991388668, -0.0662299450291269, 0.467014102685838, -0.878229058051954, 0.337079034538026])), New Column("Ab124611", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-2.60660169160644, 1.05642551359936, 1.58017792383927, -2.60660169160644, -2.60660169160644, 1.16236457582684, -2.60660169160644, -2.60660169160644, -2.60660169160644, -2.60660169160644, -2.60660169160644
	, -2.60660169160644, -2.60660169160644, -2.60660169160644, -2.60660169160644, 0.871814175390367, -2.60660169160644, 2.01476456503338, -2.60660169160644, -2.60660169160644, -2.60660169160644, 1.61398291130174
	, -2.60660169160644, -2.60660169160644, 0.666844025015194, 2.489468984945, 2.05612854193069, 0.135095730069394, -0.143464559897352, -2.60660169160644, -2.60660169160644, -2.60660169160644, 1.78591598532908
	, 2.69867089908809, 3.36996932763127, -2.60660169160644, 0.399499176835074, -2.60660169160644, 1.26424805991694, -2.60660169160644, -2.60660169160644, -2.60660169160644, -2.60660169160644, -2.60660169160644
	, -3.33596494809105, 2.2470550698792, -3.33596494809105, -1.65375686060787, -3.33596494809105, -3.33596494809105, -1.38487789040482, -0.282108288918681, -3.33596494809105, -1.28291542287808, -3.33596494809105
	, -3.33596494809105, -3.33596494809105, 1.91567666933231, 2.97287238822663, 0.611974939495279, -3.33596494809105, -3.33596494809105, -1.55158980420959, -3.33596494809105, -3.33596494809105, 0.22166686970469
	, 1.23031456287804, -3.33596494809105, -3.33596494809105, -3.33596494809105, -0.0241798865336199, -3.33596494809105, -0.00487651094033888, -0.279719240654111, -3.33596494809105, -3.33596494809105, -3.33596494809105
	, -3.33596494809105, 2.32249502219451, -3.33596494809105, -3.33596494809105, -3.33596494809105, -0.70618304106884])), New Column("Abat", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.207447439777614, 0.12452495876569, -1.88419999711514, 0.280981312140442, -0.650875971346832, 0.11336140017737, 0.367266036385988, 0.217627122918646, -0.672206307309804, 0.22154468298893, 0.206494043293
	, -0.622602546479454, 0.604285164394147, 0.216876934970204, 0.796136668795265, 0.275718570537896, 0.0186773910834672, 0.0161956069377786, 0.225773338152908, 0.395450127294439, -0.471094784771354, 0.278319355096605
	, 0.117168717870016, 0.0804383079392495, -0.243856428154881, 0.353150154961537, 0.0591225800328783, 0.230455847718007, -0.435947945008799, 0.0142471393575026, 0.57156382484991, -0.373868407642381, -0.510252437347609
	, 0.128208819946584, -0.263502744691208, -0.815340957964633, -0.0815248479761977, 0.0327627042076216, -1.05996430438134, -0.060703533774789, 0.0242290375547652, -0.0547830836551461, -0.321593442719715, -0.168509660735308
	, 0.106425443671264, 0.247290466055149, 0.0987781741531802, -0.509810390857696, -0.406971036727688, -0.145925440217368, 0.160026329858411, -0.139824180606135, 0.0268715217384734, 0.195856715709147, -0.0235284836780778
	, 0.114964778024548, -0.0688098406709736, -1.11194228606597, -1.12360381628554, -0.125620831495603, -0.222503105280203, -0.49970616921884, -0.300134634512075, -0.373668430606202, -0.285259535048976, -0.0124007073325841
	, -0.476591429195346, 0.154582630379378, 0.307816474416252, -0.0594375250628417, 0.0684281616420968, -0.149754432838721, 0.0882672818349865, -0.44774641606845, -0.331418233210147, -0.486164774603015, -0.303080293142667
	, -0.18624246705371, -0.0597865785003588, 0.0171320688125673, -0.323752848896799, -0.578013130304088, 0.24017785790586])), New Column("Abca1", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.650012976329691, 0.946601184800717, -0.673070407675591, -0.121906826969383, 0.131004868990757, -0.0263123961118977, -0.464420711765859, 0.170875536412335, -0.0520929039837967, -0.190217474861485, 0.604644422386605
	, -0.386802831002664, 0.104657573150857, 0.773707400195243, -0.189079056822127, 0.648317460303116, 0.501553538969956, -0.632943677454574, -0.0996924853039524, 1.12420700889452, 1.2805450245044, 0.343245018492401
	, 0.604996356957599, 0.253987399117842, -0.0543603230780993, 1.00750637054027, 2.03591568522746, -0.00769096452549306, 1.47974116485258, 0.638290579118552, 0.819985694904337, 0.972271481755948, -0.219540050412242
	, -1.80130146657868, 0.882321438471274, 1.92912838571879, 0.151655259890517, 0.764063152571188, 0.0299343283138376, 0.142524847115344, 0.807993497683303, -0.0114221226812441, 1.21929294271097, 1.25628136444368
	, 0.924699221729459, -0.896376465716342, 0.0541115937005077, 0.075595274040267, 0.114135612022452, 0.079236909960249, 0.036730006154428, 0.214788605415661, -0.661515100679358, 0.682884466921061, 0.53153033218789
	, -0.226736131612026, 0.271664207852874, 1.17976562893974, 0.412819354719953, 0.406587229261229, 0.181445646026069, 0.532280315761866, 0.0294661915367593, 0.341658208298637, -0.561102610688967, 0.325053923588365
	, -0.308756350457505, -0.09299481246264, 0.0784948284915131, -0.353329451080276, -0.46340551181608, -0.967862295608343, 0.00584156883793542, 0.516677520448681, 0.238591330532668, 1.13812078023043, -0.632019715732383
	, 0.22029010925285, 0.571973605023667, -2.61406759533806, -0.387953747498347, 1.10434545308707, -0.539321451571547])), New Column("Abca2", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.207950147349848, 0.285620678132274, -0.305378578615386, -0.0732900697124877, -0.658245127895172, -0.0129180259065467, -0.287659974873984, 0.366375261664057, -0.114924481456764, 0.548942966999968, -0.195475500056382
	, -0.0936099199871747, 0.522263117272519, 0.406280688736977, 0.5162644462523, -0.0733519200839354, 0.404316314800489, 0.124196724842119, -0.0067571542267007, 0.0526296488154419, -0.0237743837810136, -0.505662217972265
	, 0.124714309354316, 0.185159267128746, 0.0616583939571606, 0.457570479365442, 0.251835224690927, 0.270169758986325, 0.0966315613975732, -0.0000021279471979571, -0.164171357231113, -0.00972192104480836
	, -0.481274680490114, 0.130540391647054, 0.213818255507307, 0.491034014386461, 0.0190481341966971, 0.504078283430356, -0.153767641448201, 0.294237195289126, -0.188592317580054, -0.347577227425084, 0.372990535068733
	, 0.154841204069933, -0.243429050968929, -0.385304697944005, -0.607884945074139, -0.116894798137185, -0.197834284259628, -0.368055045406273, -0.0893222614901094, 0.153710883041218, -0.332409764767988, -0.351444371191881
	, 0.029183315794788, -0.336809837857346, 0.0203824177365259, -0.401464492149458, -0.147825005582178, 0.000745745293411021, -0.432839107054383, -0.343305344246494, 0.276213217962289, -0.241367013592383, -0.521650104112949
	, -0.301467627352495, 0.0278823481368178, 0.104059642016709, -0.0878591712470543, -0.346799060757961, -0.301912473072149, -0.196874201000886, -0.235776539890952, -0.481352464898466, -0.0529794358596831
	, -0.242267720905801, -0.533965624362624, 0.303874250283786, 0.0767407450469962, -0.741170163882468, 0.055969816169404, -0.651494739858869, -0.471173115334973])), New Column("Abca3", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.348402000661064, 0.2950553076169, -0.0979894581300396, -0.168362102228944, -0.31294914325508, 0.253921155637306, -0.793168556874192, 0.563631109343788, 0.191329545379698, 0.0708027504309755, -0.00733973897080355
	, 0.239839273010949, -0.0984331482052989, 0.572026508062114, 0.369954506239556, 0.000578922155577601, 0.0519127730874677, -0.649297935405662, -0.300240347978059, 0.388138168972171, -0.517304707094835, -0.60224411586265
	, 0.134480168986399, -0.0164940671316546, 0.288877359370589, 0.454395388421881, 0.0955329307463804, -0.156354607227987, 0.426731963386092, 0.249803058899585, 0.147044104552403, 0.383254471899457, 0.0781552695385475
	, 0.00291535868146174, -0.227931677966297, 0.608772069388297, 0.149415114374458, 0.634835574599211, -0.245022331655163, 0.388185114517259, 0.325152530715728, -0.388704933705674, 0.383857835426782, 0.420448974430307
	, -0.640544181653029, -0.15287874967705, 0.000930852445327166, -0.318751380758157, -0.399729775272053, -0.237069734160787, -0.000734962205999688, -0.150055947128216, -0.106377646904735, 0.266513817239815
	, 0.0182365685539211, 0.345198121348112, 0.0153021586545896, -0.0429178207256647, -0.000676452865875697, -0.539602965408388, -0.269324954680203, -1.12570961695309, 0.473290656574238, 0.133640966923387, -0.0110855135551333
	, 0.216592219003675, -0.0983861814658999, -0.268532470771261, -0.399037249500729, 0.236831449805545, -0.285431610976062, -0.13666934404705, 0.00593797984644593, 0.148362657333731, -0.592839304982018, 0.408576831242093
	, -0.27239048242944, 0.378374714356535, 0.105208487518568, -0.10843363668251, -0.0393126642363566, -0.505277361800223, 0.0866151496148107])), New Column("Abca4", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.299941358981567, -0.241709477699667, -0.109581568663729, 0.207660098705061, -0.0771941764965948, -0.337536031021226, -0.203265400729147, -0.0658512750218374, 0.0524770822684796, -0.0586559548943946, -0.826528915697323
	, -0.105256490229823, -0.178029096329162, -0.110474094915673, 0.357136456604816, -0.02446425102313, -0.00981910607158494, 0.028381603454776, 0.0203127367132733, -0.516509176994674, -0.733956404841191, -0.359935335347177
	, -0.435082150628448, -0.046713087305537, -0.0435745163013348, -0.366332966987288, -1.575011500376, -0.100995093010394, -0.906833625849728, -0.183728859726598, -0.32920104712551, -0.555314664719863, 0.0327275394278249
	, -0.230383950612621, -0.314932014256858, -0.870777912864535, -0.100213491309064, -0.194977543537261, -0.0103916771804582, 0.114305088083112, 0.0894192932840359, -0.144908339363817, -0.116698476129753, -0.680317560242755
	, -0.397287553838378, -0.125255684306509, -0.0310306197880645, 0.092392253102443, -0.16992550135838, 0.135424194128458, 0.141327520955892, -0.061876268371365, 0.0550123196080527, -0.0861763173586998, 0.215359821248983
	, 0.0230212376568704, -0.0504811232670908, -0.611585686103053, -0.561171692350067, -0.0340618750448054, 0.0174399381499275, -0.586637736847744, 0.0904134551641373, 0.0091129446265333, -0.0937705154903946
	, -0.726550688067408, 0.247897024633923, -0.161352647755341, -0.261728272915761, -0.150742349420787, 0.0486673708943301, 0.03020450045954, 0.248814180264475, -0.149507171263048, -0.306062387979562, -0.57301652876124
	, -0.176844573471927, -0.51590772426931, -0.429296338155898, 0.0379654549603292, -0.089368098248795, -0.479008556300579, -0.108322078837285])), New Column("Abca5", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.584927944251575, 0.925423115498651, -0.640724598842426, -0.07513429634653, -0.174877821646441, -0.0897701351317673, 0.261008285044014, -0.642098609973225, 0.0972084092720165, 0.0050365741965549, -0.318552333981169
	, 0.323100437688482, -0.395829290294898, 0.465763916586987, -1.05288653757528, -0.743614821868123, -0.0622251455248442, 0.4576957548047, -0.267178617135578, -0.946516704202261, -0.632494515635445, 0.488087114746506
	, -0.191973777519866, -0.519276532490019, -0.00666656777175751, 0.075757150359463, -0.346569703924805, -0.130961295580075, -0.297805697004299, 0.466584637045708, 0.260773720075126, -0.532074635990686, -0.0558444910161172
	, 0.853644300526448, -0.0434668656005639, 0.584640009186817, -0.032912896409517, -0.0447392237792922, 0.551157193701, 0.26437785830506, 0.125764215325979, -0.398290052492108, -0.3596155025276, -0.25131074839109
	, -0.118294016677867, -0.128141637614434, -0.69928576889749, -0.127357840430587, 0.272388157675977, -0.310457341040805, -0.680867581960549, -0.0467570415703371, 0.0506711590298422, -0.030981107674688, 0.118970777024726
	, -0.296198170766668, -0.154551481021391, -0.550574158126447, 0.363495742435483, -0.268898291766275, -0.0725631525306754, -0.235965507006748, 0.39390366945273, -0.441953657863921, 0.23345715782212, -0.313626881327596
	, -0.522949230572668, -0.396859843701683, -0.141939742372958, -0.754920402732712, -0.135651775256873, 0.0954264741374705, -0.832195585054626, -0.337832577761617, -0.504313149429667, 0.0162849631738087, -0.487647694086278
	, -0.435260793554433, -0.292259274128889, -0.090413150420151, -0.467753312073846, -0.117560597492058, 0.160750865039013])), New Column("Abca6", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-3.52843489819765, 0.520872064894758, 1.05344032272534, -3.52843489819765, -3.52843489819765, 1.40114636053072, -3.52843489819765, -3.52843489819765, 1.52296972339999, 0.210974272281319, 0.930469540089154
	, -3.52843489819765, -3.52843489819765, 2.02454906697629, 1.95685695757199, -1.39687787651932, -3.52843489819765, 1.65822220214396, 2.22730373261341, -1.66380053906588, 0.349723239859264, -3.52843489819765
	, 1.45436836824964, -3.52843489819765, -3.52843489819765, -3.52843489819765, -3.52843489819765, 0.101170777747356, -3.52843489819765, -3.52843489819765, -0.291116084076715, -1.32694702006139, -1.58074656352521
	, -3.52843489819765, -0.681058263419144, -1.42165042537801, 0.0014925964811151, -1.52116583198835, -3.52843489819765, 0.819583193935478, 1.78725330939524, -3.52843489819765, -3.52843489819765, -3.52843489819765
	, -0.899666310140592, 1.29450079156672, -3.532250655293, -3.532250655293, -0.6219997651399, -3.532250655293, -3.532250655293, -3.532250655293, 0.44633290009175, -3.532250655293, 0.860610859062114, -0.851304959305947
	, -3.532250655293, -1.2965862667536, -3.532250655293, -3.532250655293, -0.198480573210807, -0.963715957386029, -1.74787551141153, -0.57406690495301, 0.295810467781191, -3.532250655293, 0.0936745275945497
	, -1.77078076282524, -0.403324171519627, -0.142686281521761, 1.47919092977271, -0.455287527027843, -3.532250655293, 1.13413707808676, 0.818842025434938, 0.414047537294509, -1.12444532516, -0.528819274762955
	, 0.597271384052848, -0.702353241783674, -0.452688145311277, -3.532250655293, 0.911176777265731])), New Column("Abca7", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.179857265499605, 0.394868953915232, -0.229392609607352, -0.0209442685033437, 0.390050780147735, -0.0390731641088598, 0.176225808936531, 0.57943812809563, -0.190150277962333, -0.704833842321839, -0.717721054935004
	, 0.177582360559432, 0.300332485541921, 0.56509370475941, -1.96513912357347, 0.616441069031908, -0.0324500181620081, -0.313317499844023, 0.543201942587358, 0.648580790617486, -0.469419519152567, -0.455496404040946
	, -0.00238049507625414, -0.148256295322122, -0.279893194103642, 0.674675838585942, -0.558362662012686, -0.388410307925288, 0.111307242358826, 0.555848422812008, 0.450999507581295, 0.495252604843795, 0.0533146612495027
	, -0.137199965567826, 0.554454931736026, -0.411702774633296, -0.518817564845276, -0.490733564087352, 0.169288967937537, 0.653695160409025, 0.467095759131307, -0.0239952329931517, -0.283490315002293, -0.156655732306157
	, 0.187554462765582, 0.261522005806111, -0.651488014395417, -0.274159758268881, -0.186195077864967, -0.839685861028727, -0.352543293909452, 0.0131424242395137, -0.420537464403991, -0.235050350052503, 0.258340366815787
	, 0.0809673629513816, 0.00928090230458048, -0.343183606112752, -0.354882550023021, -0.491944286964109, -0.328349792897511, -0.58654819141175, -0.0165098660087055, -0.497445320189432, -0.458814142246824
	, -0.637855241048687, 0.405238947142201, -0.268342171572603, -0.115950705858686, -0.963598206005518, -0.147046454722065, -0.596812854749214, -0.707998362871717, -0.106062291518893, 0.188289214314448, -0.899923901848618
	, -0.0728635578368599, -0.35607776395035, -0.29944418778559, 0.0703128169545273, -0.0860581928825357, -0.988298906990111, 0.161921288063494])), New Column("Abca8a", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-0.398868682881433, -0.106682381621066, 0.21607200475463, 0.0373157401274709, -0.0768870971160143, -0.277944706845783, -0.0323387353288478, -0.507000747616816, 0.0189440112552556, 0.0550206604085658, -0.371326857340069
	, -0.578795292862641, 0.149838860464858, 0.0829126572520556, -0.370574137286867, 0.14553707293421, -0.371169258343681, -0.299174285879941, 0.435684840753811, -0.68137894755748, -0.815911463830174, 0.102542136798696
	, -0.461151749637991, -0.180886661599096, -0.146365647341159, 0.409258344691707, -1.42937231106673, 0.00979666311240763, -0.222654072071512, 0.275161985821991, 0.150198071134421, -0.700016578755339, 0.252770718800791
	, -0.199798201239323, 0.533347308224151, 0.492437687978369, -0.251716742506214, -0.832930913328054, 0.425239317400514, 0.0829376549283748, -0.0624222182188069, -0.0863142736108944, -0.324923201407993, -0.406022962737076
	, 0.345406847504842, 0.218071882787336, -0.324896950369203, -0.0252475620834496, -0.0289288508600807, -0.0958255363555676, 0.0389311600624262, -0.0629535857234078, 0.207018344294939, -0.466734558513438
	, 0.067450496384291, 0.268714143858292, 0.20959960109142, 0.105048256400199, 0.0449652980766385, 0.241689940870193, -0.0548517367186809, -0.245963122349603, -0.40622719574541, -0.132938039333057, -0.642616105301553
	, -0.213162535732452, 0.0583332503857698, -0.388775986861606, -0.209646413341913, -0.569305109328187, -0.388296026146893, -0.291162793073215, -0.0852324693132646, -0.662865764504442, 0.179645253140748, -0.412192186109343
	, -0.541087486030805, -0.49599308249672, -0.0270995139382431, -0.165683383603, -0.585236120191918, -0.403889247898918, -0.219137752517554])), New Column("Abca8b", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.0136951762524748, 0.938793317487277, 0.515974940665259, 0.0821818542755737, -0.225082779553012, -0.169476457758396, 0.290659727347245, -0.794928309505131, -0.10880951980746, 0.17398892075463, -0.37518492718996
	, 0.104074825820409, 0.266849477385066, -0.297066516810888, 0.113148100220798, 0.0382362419716881, -0.320906502333294, -1.07804823151746, -0.547897116616446, -0.44299097737955, -0.819806081370934, 0.00293479938494555
	, -0.811986966527075, -0.0286603258034009, -0.236840563203052, 0.302254736125742, -1.52400081778007, -0.663375400472374, -0.338168881999158, -0.203407320458539, 0.0780248945195766, -0.326087652582192, 0.449907031386271
	, -0.185867319591923, 1.17511653574738, 1.33829421704566, -0.0594888831659299, -0.754363644242875, 0.210046122027403, -0.299420696949872, -1.01993684622675, -0.407622825964915, -0.559270370699304, -0.535797866808622
	, -0.0521085088704364, -0.0636994723541647, -0.672594844591126, -0.212021468559482, -0.663442369883532, 0.257323777441953, -0.0233890666497012, 0.384119216575989, 0.195200291325352, -0.47034850342609, 0.218547399938908
	, -0.281417579041532, -0.30261336438122, 0.773549022485993, 0.331042562184618, -0.207622535915926, -0.923139547620735, -0.471945615787034, 0.136234962178215, 0.181015729362731, -0.799417168548306, -0.926578278886855
	, -0.183282365260292, -1.02220324949096, -0.548241281704634, -0.0220051464242971, -0.66844211464363, -0.136050856128216, 0.0270884975990414, -0.271852696116313, -0.363162163597974, 0.136247051687582, -0.0715798608161917
	, -0.41771941586975, 0.479262270335988, -1.11994605812895, 0.495447602809025, -0.000239740559735988, -0.676104826889228])), New Column("Abca9", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([3.57798168549804, -1, -1, -1, -1, -1, -1, -1, -1, 3.03957007511411, -1, -1, -1, -1, -1, 3.41219948165937, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 2.03546012287779, -1, -1, -1, -1, -1
	, -1, -1, -1, -1, -1, -1, 0.920489047497734, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, 0.32859271388601, -1.76183549912932, -1.76183549912932, 1.66295924614633, -1.76183549912932
	, 0.291214026083654, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932
	, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932
	, 1.64555135414454, -1.76183549912932, 0.411140021122017, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932, -1.76183549912932])), New Column("Abca12", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615
	, -2.24366139568615, 1.11678192770377, 1.02165580542036, -2.24366139568615, -2.24366139568615, 1.41746490868626, -2.24366139568615, 0.542177375428732, 0.91423421045001, -2.24366139568615, -2.24366139568615
	, 0.589059678616212, 2.27284538000606, -2.24366139568615, -0.0142967726611986, -2.24366139568615, -2.24366139568615, 0.721430633715069, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615
	, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, 2.22175231615806, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615, -2.24366139568615
	, -2.22618312354491, -2.22618312354491, 0.266562280020782, 2.51690705455671, 2.13977711945088, -2.22618312354491, -2.22618312354491, -2.22618312354491, -2.22618312354491, -2.22618312354491, -2.22618312354491
	, 1.62712056948285, 2.07778838889833, 1.83997407696862, -2.22618312354491, -2.22618312354491, 1.10624774308577, -2.22618312354491, -2.22618312354491, 0.73200062679508, -2.22618312354491, 1.11296653706059
	, -2.22618312354491, -2.22618312354491, 0.646101092623446, -2.22618312354491, 0.590478378981266, -2.22618312354491, -2.22618312354491, 0.329314364366896, -2.22618312354491, 1.18120372972895, -2.22618312354491
	, -0.050616326437751, -0.121651907614852, -2.22618312354491, -2.22618312354491, 1.76556949355753, -0.375202201042036])), New Column("Abca13", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-2.62632889656634, 1.42297806652607, -2.62632889656634, -2.62632889656634, -2.62632889656634, 1.53097214348643, -2.62632889656634, 3.55786984062408, 1.16697387065095, 2.22171087993648, -2.62632889656634
	, -2.62632889656634, -2.62632889656634, -2.62632889656634, 3.11661968366599, 1.78587058509303, 1.03479740780607, 0.674525203355825, -0.645859395100581, 0.531566709569821, -2.62632889656634, -2.62632889656634
	, 1.86132337375097, 0.230483512049016, -2.62632889656634, -2.62632889656634, -2.62632889656634, -2.62632889656634, -2.62632889656634, -0.541438075044222, -0.696487537931349, 2.08498659374248, 1.30797967871608
	, -2.62632889656634, -2.62632889656634, -2.62632889656634, -2.62632889656634, -2.62632889656634, 2.76219658268815, -2.62632889656634, -2.62632889656634, -0.634047961584201, -2.62632889656634, -2.62632889656634
	, -2.69584905035595, 0.974748145549931, 0.654339582567941, -0.25798880063839, -0.605420837340619, 1.74188583883691, 0.0554679964994243, -2.69584905035595, 0.742819799202442, -2.69584905035595, -2.69584905035595
	, 0.867982974897923, -2.69584905035595, 2.24330055744459, 0.115896670285018, -2.69584905035595, 1.9606351464772, -2.69584905035595, 0.73427152784288, -0.563033743489103, -2.69584905035595, -0.49685108495027
	, -0.438275030923736, -2.69584905035595, -2.69584905035595, -2.69584905035595, 1.3596412692478, 0.381114077909207, 0.635239386794765, 0.360396657080993, -2.69584905035595, -0.158521818406522, 1.10323756960861
	, -2.69584905035595, 2.52550138609734, 1.02885269586143, -0.454988215638043, -2.69584905035595, 1.10875291768089])), New Column("Abca17", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 4.25553530605215, 4.45017603081788, -1, -1, -1, -1, -1, 2.34855092304055, -1, -1, -1, -1, -1, 0.703575771392869, -1, -1, -1, -1, -1, -1, -1, -1
	, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 1.8186352037771, -1, -1, -1, -1, -1, 1.25757401943222, -1, -1, -1, 0.692643724473693, 0.798861054681417, -1
	, -1, -1, -1, -1, -1, 3.37875294375472, -1, -1, -1, -1])), New Column("Abcb1a", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([0.783836344550876, -0.721614627126419, -0.254068747561862, 0.217730994083792, -0.351092583794086, -0.168061361523613, -0.322784258857889, -0.0879379350864507, -0.596434005929654, 0.0241791918500808, 0.467950928287151
	, -2.01168654950709, -0.078411723895108, 0.0488799215092062, -0.389794207813937, 0.0989413326869736, -0.463076590462273, -1.23347319352238, -0.185667274624192, 0.198901931154423, -0.266951609870915, -0.0196291942546606
	, 0.00106633125088138, 0.118424656331629, -0.370839516936298, -0.796907975600496, 1.31294213124371, 0.38469810865509, -0.900555385962323, 0.172694633745984, -0.314340939383731, -0.271602144526966, -0.681239353195842
	, -0.407403650261441, -0.693633472444542, 0.386578610935701, 0.237130308810631, -1.47216047049204, -2.49385602286955, 0.18063784180229, -0.859975483213169, 0.050980295533624, 0.157408490063787, -0.801711517153196
	, 0.145852349988044, 0.244068776877112, -0.567512196082831, 0.580936523485638, 0.162667138738919, 0.00974059798742394, 0.254686529020695, 0.188830012758436, -1.2245814656483, -0.278748578731776, -0.146116521310775
	, -0.242083677969839, -0.0416868143499382, 0.0728674803187732, 0.778918117566822, -0.285778466120423, -0.0933868860936633, -0.0361865195979791, 0.555150124630717, -0.512526995227043, -0.895154395906559
	, 0.533135218892277, -0.260788389715202, -0.245132777834913, -0.169945217465982, -0.220727909831165, -0.00313836350264515, -0.0919847820775571, 0.599038626802235, 0.759027432878662, -0.300659488431794, -0.13701401117159
	, -0.326269745847914, 0.117971489615305, -0.138288122294877, -0.0803917963479694, 0.354904376249969, -0.611049724323835, 0.499787082988112])), New Column("Abcb1b", Numeric, "Continuous", Format("Best", 10), Set Property("Notes", "added 0.1 to avoid log2 of 0"), Set Property("Axis", {Add Ref Line({-0.58, 0.58}, "Solid", "Medium Light Gray", "", 1, 0.25), Add Ref Line(-0.58, "Dotted", "Light Blue", "(-1.5 fold)", 1), Add Ref Line(0.58, "Dotted", "Light Blue", "(+1.5 fold)", 1)}), Set Property("Color Gradient", {"Blue to Gray to Red", Range({-10, 10, 0})}), Set Values([-1.27770811553787, 0.982039332561381, -1.41985510488747, -3.3716618422721, -3.3716618422721, 1.55791941645627, 0.917135402327519, -3.3716618422721, 1.8132857712042, -3.3716618422721, -1.18738427453305, 2.36234092320776
	, 2.10240315317426, 0.270685804262542, -3.3716618422721, -1.24010482059377, -0.239574937794134, 1.41310195469956, -3.3716618422721, -1.50702748314033, -0.398581028713876, -3.3716618422721, 1.3621553751547
	, 0.00215266122541819, 0.279030681374925, -3.3716618422721, -3.3716618422721, -3.3716618422721, -3.3716618422721, -3.3716618422721, -0.134343028151163, 1.52539830681018, -3.3716618422721, 2.45376708002492
	, -3.3716618422721, -3.3716618422721, -1.19631257561054, -0.556002401411674, -3.3716618422721, -3.3716618422721, -3.3716618422721, -0.57313208801912, 0.418304049055715, -0.441676502766139, 1.60718283850533
	, 0.221497436350611, -1.36109575695363, -0.915019425560518, -0.416460375788639, -3.84624152748358, -3.84624152748358, 0.114111358820655, 1.08584216405537, 1.03386534095544, -3.84624152748358, -0.484307502014653
	, -1.59719649498947, -3.84624152748358, -0.0792566628260363, -0.197046601162924, -1.83636646699737, -3.84624152748358, 0.591344775543817, -3.84624152748358, -0.0181804044093827, -0.8135752956996, -3.84624152748358
	, -2.08477163501582, -2.00522946690732, 0.612501524593391, -3.84624152748358, -0.397628990920406, 0.0212146487263925, 0.758544303770241, -3.84624152748358, -3.84624152748358, 0.176163186992555, 0.448606808906659
	, -0.0181868467031254, -3.84624152748358, -1.60538069276567, -1.00409799750288, 0.759724411855794])), New Column("Prin Data Matrix By specimen_material_type", Expression, "None", Set Property("By ID", 363741664), Formula(If(:specimen_material_type == "not eye", Matrix({:A, :A2m, :A2ml1, :A3galt2, :A4galt, :Aa386476, :Aa387200, :Aa414768, :Aa465934, :Aa467197, :Aa543186, :Aa545190, :Aa672651, :Aa792892, :Aa986860, :Aaas, :Aacs, :Aadat, :Aaed1, :Aagab, :Aak1, :Aamdc, :Aamp, :Aar2, :Aard, :Aars, :Aars2, :Aarsd1, :Aasdh, :Aasdhppt, :Aass, :Aatf, :Aatk, :Ab041806, :Ab124611, :Abat, :Abca1, :Abca2, :Abca3, :Abca4, :Abca5, :Abca6, :Abca7, :Abca8a, :Abca8b, :Abca9, :Abca12, :Abca13, :Abca17, :Abcb1a, :Abcb1b}) - [-0.40783718963311, 0.688382366020641, -0.0703818201606135, -1.74820393462455, -1.11818761674836, -1.73568946947707, -0.652766782082089, -1.31669052288985, -0.268024336861669, 0.0964787665895007, -1.83710734373927
	, -1.34361494812515, -0.735711187489235, -0.481591191820795, -0.462173834983341, -0.0480083703631927, -0.145389735985526, -0.828749310990982, -0.150374212607556, -0.309283560299806, -0.0139371405487383
	, 0.126174845916121, 0.142017977315897, 0.0376704593545365, -1.24558798298738, -0.122675457712727, -0.0971328803899685, -0.0705564637293572, -0.072825588662086, -0.358966796440352, -1.15910528309367, 0.216285772675527
	, 0.0114703709166675, -0.60284578171782, -1.13552139838923, -0.0665385225563945, 0.394191096899932, 0.0670707291115471, 0.0894457372009105, -0.240060833953281, -0.0825526516032692, -1.41890147361573, 0.00499478409660045
	, -0.143582099799744, -0.160007110997754, -0.591234081530749, -1.48821322704104, -0.974663664821759, -0.641867317470376, -0.281180175985779, -1.21367944569358], :specimen_material_type == "eye", Matrix({:A, :A2m, :A2ml1, :A3galt2, :A4galt, :Aa386476, :Aa387200, :Aa414768, :Aa465934, :Aa467197, :Aa543186, :Aa545190, :Aa672651, :Aa792892, :Aa986860, :Aaas, :Aacs, :Aadat, :Aaed1, :Aagab, :Aak1, :Aamdc, :Aamp, :Aar2, :Aard, :Aars, :Aars2, :Aarsd1, :Aasdh, :Aasdhppt, :Aass, :Aatf, :Aatk, :Ab041806, :Ab124611, :Abat, :Abca1, :Abca2, :Abca3, :Abca4, :Abca5, :Abca6, :Abca7, :Abca8a, :Abca8b, :Abca9, :Abca12, :Abca13, :Abca17, :Abcb1a, :Abcb1b}) - [-0.347532034883021, 0.0493266419719762, -0.0704193688289335, -1.15929557303596, -0.418972819426301, -0.459394115951035, -1.65139355401173, -1.20296075861544, -0.003607958306936, -0.0987734425255723, 0.132069450012584
	, -1.36647494767326, -2.10864564492592, -0.815171546641713, -0.475287294799229, -0.0860825300832984, -0.13427311289164, -1.33657905083083, -0.249895055869288, -0.0943776667898913, -0.0585875204497421, 0.099530221296311
	, -0.0289417968830997, 0.124557799739987, -0.825252597196417, -0.0714449705917731, -0.129343513343177, -0.0931528854643004, -0.0130602126787216, -0.153862926734853, -0.750680482524109, -0.0118735061584813
	, -0.0973369495820844, -0.521318312464122, -1.85577808283589, -0.177566131109712, 0.0400858124041129, -0.223440258481481, -0.0990296763686958, -0.142151686505579, -0.212530302541635, -1.19937162983913, -0.273002579078509
	, -0.157976272809867, -0.204002300415921, -1.42469101561576, -0.810038146089871, -0.56725338555089, -0.668039309073868, -0.0269633581303957, -1.27466304152463], .))), New Column("Prin1 By specimen_material_type", Numeric, "Continuous", Format("Best", 12), Set Property("By ID", 363741664), Formula(If(:specimen_material_type == "not eye", [0.0352551321020023 -0.152009805821233 -0.29190024611669 0.0543351821827935 0.0152424542394855 0.00797649938997487 -0.0290475047836575 0.0440842799202068 0.301243605007334 -0.0491382243019167 -0.0164365629524262
	 0.0753747546485359 -0.0547941897719441 -0.119022844700234 0.131926528842424 -0.0191065737409892 -0.0395987735521634 -0.158303255517284 0.0530375750414683 0.461989201773552 1.08653393041102 -0.448493153092546
	 -0.439107649503845 -0.318793314047544 -0.0473702870568305 -0.516026131940427 0.0837792671316864 0.497967231585329 -0.0428418414781583 -0.31531183318276 -0.0390220092769589 0.218770101887575 0.405176734833014
	 -0.0405551158698849 0.0661759982898317 -0.151891776870913 -0.333240376529037 -0.398788845057682 -0.368527289424574 0.723454760203145 0.509368701233532 -0.00851575451769001 0.300046033478223 0.837653838680565
	 0.43766847844102 -0.0531959213796272 0.0330779128861281 -0.00207213819433664 0.0113819718345196 -0.255155159474394 0.013989907609283] * :Prin Data Matrix By specimen_material_type, :specimen_material_type == "eye", [-0.0328967662972676 -0.143019123407228 -0.111966600482607 0.0406166563313014 -0.0737489307520066 -0.00377869808327509 -0.0274770261658494 0.101992023835082 0.300039990103144 -0.210482927686769 0.0793265682264312
	 0.0259949244589845 0.00266946761075417 0.0484686112487554 0.274432108867257 -0.00638426529686595 0.05078508797756 -0.124349163985678 0.483567287907457 0.0825527112474112 1.55474628020671 -1.12193646364279
	 0.445053487888363 0.0337614399979698 0.156265447767105 -0.0150415725598738 0.74511399623068 -0.275183592038045 0.584129111863284 0.357601872613679 0.192584432184663 -0.191911526684413 0.869782561510922
	 -0.0223073245205888 0.0106687155270578 0.650059681771061 -0.357881950289647 0.443937307247568 0.0817879746069174 0.898634446598825 0.114574062146122 0.0654948756497239 0.882111741090313 0.130414330267854
	 -0.301997491513787 -0.088345982743203 -0.0814175047620523 0.00527701127190281 0.0676153528450984 0.18846758023349 0.038603074111054] * :Prin Data Matrix By specimen_material_type, .)), Set Property("MDMCC Historical Statistics", {Creator("Principal Components"), Variance("on Correlations"), Number of Columns(51), Number of Observations(44), Freq(0), Variable Names({"A", "A2m", "A2ml1", "A3galt2", "A4galt", "Aa386476", "Aa387200", "Aa414768", "Aa465934", "Aa467197", "Aa543186", "Aa545190", "Aa672651", "Aa792892", "Aa986860", "Aaas", "Aacs", "Aadat", "Aaed1", "Aagab", "Aak1", "Aamdc", "Aamp", "Aar2", "Aard", "Aars", "Aars2", "Aarsd1", "Aasdh", "Aasdhppt", "Aass", "Aatf", "Aatk", "Ab041806", "Ab124611", "Abat", "Abca1", "Abca2", "Abca3", "Abca4", "Abca5", "Abca6", "Abca7", "Abca8a", "Abca8b", "Abca9", "Abca12", "Abca13", "Abca17", "Abcb1a", "Abcb1b"}), Mean([-0.40783718963311, 0.688382366020641, -0.0703818201606135, -1.74820393462455, -1.11818761674836, -1.73568946947707, -0.652766782082089, -1.31669052288985, -0.268024336861669, 0.0964787665895007, -1.83710734373927
	, -0.143582099799744, -0.160007110997754, -0.591234081530749, -1.48821322704104, -0.974663664821759, -0.641867317470376, -0.281180175985779, -1.21367944569358]), Std([1.53726221008019, 1.32938225614806, 0.664719926876226, 2.20764723904233, 2.14150037340936, 2.24206011480269, 1.13637537571269, 1.92609849956494, 0.59228916663767, 1.60400527150785, 1.72249329675155, 0.871095542575974
	, 0.998142053556444, 1.51262797572046, 1.58011268434392, 0.420544484695392, 0.441198055016489, 0.796007326668964, 0.637992102654243, 0.376395218425519, 0.200695116158253, 0.307972126767745, 0.2161291728686
	, 0.622821594181188, 2.18159912718928, 0.314484602674856, 0.339059329725595, 0.365372891655965, 0.311830371070471, 0.57319997590322, 2.00134174776396, 0.637028380652855, 0.258762663411312, 2.19038288681871
	, 2.04821177710112, 0.479129639379324, 0.722763104473278, 0.298859501769004, 0.350164851125787, 0.348142479069789, 0.453143534605368, 2.17063765686262, 0.51287564188352, 0.399044752576719, 0.557920918594334
	, 1.20361762800511, 1.44757967888047, 2.0880624730757, 1.23699407800764, 0.673818838502342, 2.0529406740972]), Moving Range Sigma([0.995358442263065, 1.28679007522767, 0.588667359861678, 1.60363253563615, 2.37946340841644, 1.97832017094191, 0.531601504913143, 2.08343841280963, 0.482809246455553, 1.3577640571258, 1.36507860314346, 0.33021915687705
	, 0.400701992848628, 0.940215328172634, 1.27221113912839, 0.431724180812789, 0.473074076076075, 0.31059287211475, 0.697938610251227, 0.407555055389348, 0.190442442540734, 0.319068495008883, 0.243626742057498
	, 0.650824541082913, 2.29286740103198, 0.295774911472166, 0.309110956334119, 0.384814031103588, 0.295697405848018, 0.515232521156969, 2.13645095685515, 0.650302230500056, 0.235713335824498, 1.79128974747159
	, 1.57565809064977, 0.487387199392789, 0.688417929255581, 0.319771278149242, 0.358013062278678, 0.290840530405885, 0.489052661044794, 2.06266383547823, 0.454184727039903, 0.418286595886843, 0.495435959094761
	, 0.607434981852971, 1.00394433970758, 1.61172699672068, 0.432903416480771, 0.653466636146655, 1.96976990698873]), Eigenvalue([5.28302169296011, 4.17198472651602, 3.78629592090349, 3.29837512258259, 3.08028905302597, 2.85170846102648, 2.41747672482801, 2.40106352548042, 2.06299535997228, 1.99933849490573, 1.87935938017329, 1.75740571031988
	, 1.61010077428313, 1.4855936456236, 1.31486876452184, 1.22276388324241, 1.07583777417073, 0.987684367954098, 0.857783144185771, 0.783053345791664, 0.756581034864579, 0.666918515973711, 0.64830799013579
	, 0.602425669234031, 0.535420401888661, 0.46413848957734, 0.4451350037341, 0.394182871520676, 0.347272043377246, 0.322772896746522, 0.260431614913838, 0.236886534142859, 0.202218449633262, 0.18648807161058
	, 0.134186676835814, 0.114462852331721, 0.0981780264469497, 0.0881537758518295, 0.0538252935788348, 0.0470661830413543, 0.0282440076041481]), Eigenvectors(
[	0.0541963822917931 -0.20207913861926 -0.194031910253839 0.119952914928706 0.0326417214455334 0.0178837911380107 -0.0330088691620449 0.0849106654087112 0.178423323764721 -0.0788179708128093 -0.0283118695071891
	 0.0656586127970973 -0.0546923851019298 -0.180037284643406 0.208458781625378 -0.00803516420819883 -0.0174709018722529 -0.126010551227307 0.0338375540203886 0.173890526511787 0.218062053373722 -0.138123390198683
	 -0.0949039730875409 -0.198551360069395 -0.103342976897887 -0.162282273073128 0.0284061421585712 0.181943727354247 -0.0133593873254764 -0.180736735182358 -0.0780963762476103 0.139362763740702 0.104844611057689
	 -0.0888312317743458 0.135542459058657 -0.0727758522768452 -0.240853849075971 -0.119181835544975 -0.129045303437146 0.251865333711962 0.230817133694308,
	-0.0184846174326959 0.153886302014748 0.334261368801225 0.244184399531598 -0.0640275487104931 0.0478829145137374 -0.00432675400262116 0.0140794317553505 -0.171928353194916 0.028720450357959 -0.176908474998181
	 -0.279037635699541 0.0643641891842268 -0.20155948823632 0.0389708004695553 0.357517344657662 -0.100218880918358 -0.0919466759576698 0.134585881994452 -0.223182341270272 -0.0763724733422777 -0.0429226981560543
	 -0.0419569258244722 0.181648104717064 -0.0432067675427107 0.0593955920586088 -0.0254657410303846 0.0905286722274533 -0.0165246770280046 -0.201147640026585 -0.0716613449103498 -0.238473390333176 0.0984390631167033
	 -0.00932847605658202 0.0698069553449731 -0.149721899532915 0.0890761312455305 -0.0610745254474304 0.0354090144048069 0.143602585664687 0.0138631521605867,
	-0.0618054658938034 0.276355272696944 0.00306454041489707 -0.234173102011278 0.177330000219323 -0.113195649905564 0.171848437156332 0.0445247531835446 0.286426599100219 -0.0571014480865995 0.184004175770242
	 -0.180544809141083 0.059139431641724 0.0202322268303576 0.0333968508236828 0.0680181305921454 0.137984023306412 0.0702418835168215 -0.0604091885039943 0.0163491763083809 -0.0830848970545075 0.0140491901590658
	 0.209579714569114 0.117989909163864 -0.233496297492425 -0.06516650175491 -0.0863918785261474 0.031483517540022 -0.0372908971504298 -0.064959202857542 0.277029415206427 0.244103903113129 -0.165813988898856
	 0.037688524292349 -0.117572019462969 -0.284092993176262 0.239000557411959 -0.0340499646699131 0.270678932916213 0.134231215441458 0.231504701685385,
	0.0364610456445191 0.127893865884134 -0.106475159685254 -0.00722785298064643 0.0133075723456369 0.226327238797421 -0.215532636554482 -0.0424244966646576 0.110034413287138 -0.169941316328569 0.118877325814804
	 0.130390263821507 -0.134395036197195 0.131576518865373 0.16619047294338 0.122843339412769 0.110893842687643 0.110912588925181 -0.0555118048064504 0.088060963014692 0.163475043332451 -0.0178173322348467
	 0.0770964474424815 0.0788533280692936 0.0499282476304602 -0.0803447156072422 0.0844236262821843 0.0314584011000811 0.132826542175694 -0.104883443544966 -0.302093176342484 0.236252956771559 -0.18337684072362
	 -0.1102033418626 0.334707102230357 0.124431057450462 -0.139767195695966 -0.231199691838258 0.0242804400098799 0.0577666069319309 -0.00604996272755992,
	0.0941846866478576 -0.0955828597399612 -0.0571938994933848 0.163349942889512 0.0409674144732821 0.126678004434679 0.0246272289854051 -0.221006182777079 0.106618648823007 0.0431197143077069 -0.0334610292405952
	 0.0869380387096822 -0.00280936517151803 0.104449332789769 0.131248940818571 0.130035888453096 -0.0746406669801059 -0.0861662894999159 0.0523755471831429 -0.152069111439042 0.0527943216530343 -0.00447877261814354
	 0.147303593670229 -0.0607308368044002 -0.0286436716415603 0.29615492363855 0.175218664880871 0.129880786666666 -0.155235719940932 0.172719583321318 -0.102475424325242 0.136019864345826 0.0735755288408215
	 0.162700414658009 -0.121662449954186 0.230619676784623 -0.0386704350955445 -0.0140924522141591 -0.176665799598949 -0.041568234301052 0.00166585549498034,
	0.0331411436786 -0.0816350028551851 0.126123209938375 0.00143886609268607 -0.108598780157928 0.297330303224966 0.277354724279328 0.155325354916064 -0.0551384232742451 -0.0669345413939955 -0.139238010841884
	 0.174327376077825 -0.0843886856208843 0.0642384038186323 0.229179327822495 0.28710729335151 -0.129739273433987 0.0443292190360799 -0.00532798238195626 0.0497145524874486 -0.0215650853417359 0.15726659378757
	 0.102463749102665 0.176849496750439 -0.0862949307881161 0.0925265305053237 0.101008373036094 0.137447167160038 0.0617776186941644 0.00935350578242493 0.0919847037805198 0.0903129340061746 -0.0633591610665474
	 -0.193345290592141 0.0198372045882946 0.178775613958327 0.0455676114494722 0.250505653685456 0.0726958599438082 -0.245033150885976 -0.136534854272676,
	0.232137058312464 0.0956120330164228 0.0526794484346153 0.243179725014017 0.0728816056559848 0.0568790067209687 0.158522566117876 0.126466555215707 -0.143257014872299 0.0741270263215293 -0.0676459511031556
	 -0.10687420961723 0.0966704988726605 -0.117177447792811 0.0271560778104956 0.00409441325758881 -0.0397965053934513 0.271828012261949 0.361633939862677 0.191056748756609 0.0523098557008613 0.0378493959280118
	 0.258975679414566 -0.0780901023595126 -0.0520794276486183 -0.0991278848132116 -0.339158128238078 -0.122367459276598 -0.0372184269385701 0.077586536768421 0.0277121161367201 -0.0253419674358536 0.247353825944633
	 0.094790079731858 -0.115959389006565 0.0243515137434735 0.0147574950036999 0.206816419757485 0.189993729731384 0.201036479890005 0.103846474241004,
	0.10948165897738 0.0234161479235207 -0.0208542384576845 0.00383842184505442 0.0128789892085172 0.0410728315659135 0.201285128225623 0.0360064139011969 0.0929685167572547 0.075397929263977 0.0244081016764246
	 -0.010090809489703 0.00834302268902907 -0.271110240842436 -0.0451282814984571 -0.240407337506103 -0.240764193413603 -0.0654878659903072 0.0374138873355231 -0.0687849602857715 0.0798326560038476 0.0104037683457522
	 -0.0401785957646707 -0.0451411644634809 -0.0145767083553549 0.0190191308223256 0.145670169954165 0.0760868989716121 0.195069400744335 -0.145870973843925 -0.0960431711315133 -0.0549406150024714 0.147977973783063
	 -0.0209128719483336 0.0342512554372877 0.00730127666804015 0.121359050931894 0.179760645367926 -0.134408366118489 -0.0946031051814398 0.00535143354074135,
	0.431839897501506 -0.122557198910494 -0.0492420043279202 0.226776375821134 0.114453564173737 0.207671756123006 -0.00887864784144413 0.0100461875512167 -0.067160611574301 0.0551846199488577 0.0234727340813143
	 0.241205678893288 0.115251054069832 -0.225279644268022 -0.0118837404850895 -0.116126564252937 -0.0704341457274085 0.0599676662018499 -0.0816713257322199 0.0849780166660677 -0.141403143324884 0.153483725130101
	 0.115178621966086 -0.0634253729752817 -0.182905526561669 0.0426227067537654 -0.276732080441226 -0.15345904169933 -0.337532137511936 0.0251780608352165 -0.0369806974022288 -0.0662189897364513 0.0179352921418012
	 -0.123027197391499 -0.075453684025285 -0.033420293200189 0.0168436668108589 -0.0457442515606954 -0.0799125480443263 -0.127559569084826 -0.109677004173408,
	-0.378498820181273 0.150451419459633 -0.116364703002974 -0.0374654034665847 -0.0852840097853366 -0.08902662592997 -0.0627833003861268 0.00862198845416439 0.167028568177826 0.236297993158703 0.120009539686701
	 0.215661401637756 0.138305447972415 0.137239214533765 0.264251454958507 0.197743397921614 0.0577463936324004 -0.174881264223028 0.126886672920673 -0.0430720659173904 -0.172883425181065 -0.0720830497339427
	 0.132370339880577 0.0541105136119885 -0.0883488764154189 0.0876853388424058 0.0112083345803839 0.0439222546529907 -0.0545824349753372 0.0292482944566094 0.0828194850694471 -0.0633458928644318 -0.137038636870522
	 -0.107190017247226 0.270495465105379 0.301400370511177 0.225713981128851 -0.236703090336626 0.042035925504766 0.150180326206212 0.0868664276812616,
	-0.107792767931623 -0.0123727616605236 0.0347505733447151 -0.085191278633249 0.214957318695907 -0.0370861131451215 -0.00122881125860272 -0.0148512424958861 0.034229931854937 0.242895106530343 0.0304001497242528
	 -0.0134254810578132 0.236737909080138 0.0283943187163154 0.105948375404671 0.136000336401439 0.0441423966776692 -0.226975436475927 0.00275389369178389 0.188555563337913 0.00633749680264827 -0.111378307045251
	 -0.319798934962003 -0.104029735176665 0.0574987745727618 -0.214016296124774 0.0226661186509752 -0.129958193679057 0.200908294118021 0.153767340089427 0.0191786535161075 0.256708956559178 -0.00770951152143522
	 -0.0920913652696131 -0.0472318727248395 0.162166920600766 0.255444308192147 0.119572948302281 0.0134944074243523 0.209281841000883 0.074348030484065,
	-0.139175617966921 -0.0649859643674981 0.0769586339153267 -0.0324049569502509 0.230005337014098 -0.0869163214641672 -0.199843298010421 0.213473590853312 0.0266340328360472 0.124392500446071 0.116557610117156
	 -0.302127904388255 0.0501345619595113 0.0618541362878456 -0.0839616290552211 -0.120226828254225 -0.0723501295411627 -0.108363525147718 0.126508976875478 -0.158675672713978 0.188504522494447 -0.0309656454964021
	 -0.0212830165700755 -0.0904467025299195 -0.123205092230173 0.035633498328063 0.00592791227397864 -0.163894711127901 0.0365964957185487 0.227556783382289 0.0436510495454843 0.144767095623858 -0.183308960869526
	 -0.021840925431731 -0.177018101703732 0.195729573038352 0.361331164459252 0.0790858876746568 -0.203977821796911 0.405264444060318 0.100654903899312,
	-0.267180854905367 0.0875549897600153 -0.0744487669902814 0.060531728596791 0.00473270477362314 0.00434034050109502 -0.0117333066875376 0.144881349844312 0.00512487642195457 0.0689932720322732 0.0642334721327238
	 -0.0696760086146839 0.13081097053344 0.028588256123858 0.0421186306970626 0.0628520911032106 -0.129511397492474 -0.0913908331788238 0.112139899489523 -0.0324418767191552 0.195468029732239 -0.0924952911045083
	 0.0293226564875165 -0.014734927565958 -0.220822482223522 -0.0546538089522275 0.166241676367578 -0.063436291681631 0.153468371456416 -0.130652535106778 -0.133215427795368 -0.245452036665487 0.29192928357059
	 -0.137967387540417 0.183550238739335 0.205714620834798 0.0460565366965629 0.119657181280199 -0.0816482103508548 0.0317419450598843 0.00158146100460684,
	0.00658149197845897 0.107151411228464 0.102523771861515 0.0853191890123663 0.0503678965600633 0.341509708126327 0.152594351781416 0.298132541156187 -0.126162095627822 -0.193982312762302 0.0571246860683005
	 -0.150661867636795 -0.0392809050834674 0.00672574335031944 -0.160856035588788 -0.0876490563553924 0.00950741896211285 -0.0642184044360239 0.254124164978333 0.172095189172609 0.122052820159829 -0.0176941367677203
	 -0.0388399476795228 0.0761348127349758 -0.029376849560464 -0.132446034502314 0.11859321292978 0.0585388116037191 0.20653817455495 0.0784289337977547 0.26738290611965 -0.0941801250054841 -0.0794832753273952
	 -0.121996066386832 -0.033071038845818 -0.175539258716579 0.239588626352747 0.0524858808285665 -0.223121318869329 0.0343790896920673 -0.0458949743055698,
	0.0745276627788008 -0.00742352289031054 -0.00846890970982981 0.045866482736257 0.0545410356002361 -0.227186437608702 0.0900524755152768 -0.0960607076263721 -0.149446067629501 0.0152221879926244 -0.0192777262766018
	 0.173006934761103 0.0440483824417461 0.0948658324339504 -0.0412230586476537 -0.0121175998939232 -0.17252155744034 0.119488383011116 0.166624654409913 0.131034861652204 -0.212117397303463 0.120925071061645
	 -0.207627591381688 0.0398012654412672 -0.0542317924751011 0.11206431473212 -0.162622968958244 -0.0773806046356856 0.0104286139066269 -0.223487283809946 -0.032706947151893 0.349433638637494 0.230821396467025
	 -0.0917099369666616 -0.0319972551253694 0.11584458872578 -0.097635597809638 0.242923063773754 0.0361345449835008 -0.223395369648636 -0.0666409436921876,
	0.30248680893015 0.124070885207261 -0.232738099168145 -0.198279102895019 -0.198559172444667 0.0185203014190346 -0.0460562818171685 0.0624639705110217 0.0685517606053754 0.0847170422236787 -0.0667122348840474
	 -0.172486189292172 0.33859966390373 -0.119745459407872 0.129664365139921 -0.0591561283499232 -0.129871458986617 -0.0949016708525817 0.131030386233721 -0.0756266054441062 0.135925085918073 -0.188520584077579
	 0.167683648835443 0.0647693275736247 -0.0970685966446913 0.15044884981849 0.0752598648226713 -0.0353240933836074 -0.188918739204497 -0.0456132979561253 -0.0760405278467153 0.162981083636333 -0.136086399308732
	 0.0132891753525248 0.231303413397578 0.0719741923221638 0.0652379076388451 -0.0397811682259614 0.10621602806817 -0.0157703185952442 0.190434822941297,
	0.261297146696963 -0.0267319603404885 -0.0295761561567935 0.0272432350540086 0.107621945677798 0.149115327281634 -0.152285564627303 -0.112376951074487 0.0725928979049185 -0.000365651919869365 -0.0543984672745325
	 -0.0607479703919134 -0.133151427285297 -0.0863214500915534 -0.215397121681273 0.151669111339699 -0.0753908363020504 0.0070938287905701 0.193308618017614 0.20181666501497 0.0919464948490784 -0.174453082993571
	 0.158800885163842 0.00567929230768195 -0.182987138543014 0.159542166126943 -0.00436364281653489 0.235073766960013 -0.116292254278254 -0.0838129641989196 -0.0280988182257667 0.0910040239160076 0.132938635097881
	 -0.0633223424643098 -0.0228774187173761 0.00692210414296149 0.303978477684155 -0.112960437091612 0.000364239712901557 -0.175356408090214 0.181503706938923,
	-0.10251837860154 -0.177089899477616 0.0314682158073795 -0.381019645225637 -0.116193009948203 0.12491134847105 -0.0499193076625435 0.0558175962163597 0.107916995960895 -0.116588928611942 0.00276891813482791
	 0.0372273734787887 -0.0708187258984008 0.256412767427192 0.162996079275046 -0.155518754141452 0.164491287050231 0.0586320592726928 -0.0249412570541664 -0.0536734306880069 -0.0309041234977688 0.0933211879060983
	 -0.0465461392759195 0.333165541784612 -0.00746869101336773 -0.0115595237668013 -0.0344833500266672 -0.110757696167056 0.0637651727570721 -0.0452086033437882 0.175671135723298 0.0373824970575095 -0.107323250363971
	 -0.0781306304520731 0.251053995161688 -0.181445074501301 0.109383346330046 0.126697583093538 -0.0261962386287903 -0.16965021170109 0.0837364013774781,
	0.0114877333205275 0.110946174211851 0.290043306029369 0.0404462833936692 0.221082903553157 0.15151627427846 -0.233995621003114 -0.111424982450816 -0.209768931680837 -0.115734198660153 -0.152354500564316
	 0.186058842318418 -0.102807027465099 0.00982127472663833 -0.00764898079159213 0.0898961533517198 0.198460050627397 -0.129971206544547 0.0261469694683945 -0.0824734936931717 0.109584567185121 0.176020677904581
	 -0.305789865334075 0.0596028008268567 -0.251798655604478 -0.0169727010955345 -0.0374266683199359 -0.0503454824835328 0.00680116712637829 0.110223762991883 0.228808952777896 0.0115238390775274 0.0852789258196692
	 -0.0422897552864585 0.00298334278932014 -0.0635212435833793 -0.162344312514925 0.0926087170228638 -0.00723062126924838 0.214412716573032 -0.0485616787816112,
	0.18259055541468 -0.114461239381185 0.00356300203232811 0.0384039163831906 0.193967267081839 -0.150803125656219 0.215557846062471 -0.0904908360009979 0.202872197617253 0.226049236327804 0.261002975944995
	 0.367451237133998 -0.197431493962987 0.0228700880368122 -0.0177451217848248 -0.16512982056569 0.0382738486816304 -0.164373393466885 0.0514519319996605 -0.0619022732522143 -0.00872874524231738 -0.151632996265622
	 -0.112538715880183 0.173996581953377 0.148308347677874 0.112895871198502 0.174083669845748 -0.208276438543366 -0.0732187798641201 -0.00121295408477297 -0.0281040004404559 0.00621758158668664 -0.0759774692571699
	 -0.0322657343223 -0.137719081626083 -0.0565270971396474 0.25762443095718 0.317344447964004 0.020411793756102 0.0479379230881857 -0.0630909600177603,
	-0.214565081758059 0.0363611702680933 0.122570626125405 -0.0174423728147235 -0.0719095337288635 -0.00703118480988093 0.30338315607034 0.168365033674048 0.0770153248397999 -0.14041123924491 0.021811027167014
	 0.0164067624253436 -0.212315631437643 -0.0129150682622826 -0.161419395757662 -0.0859120778745548 -0.0340872159667938 -0.190615124529793 0.141377117745051 0.0178154212169519 0.0445228301106336 0.0113478368570532
	 0.0639288853124202 0.21823733392515 -0.124937316057705 0.0614824800717159 -0.21644378795073 0.115592879433119 -0.128336200581221 0.12676713887441 -0.118444341465734 -0.0164975791949203 -0.0634446681298241
	 0.114457469437119 -0.0522576572616415 -0.0575134501173016 -0.104574569947187 -0.0267083427178456 -0.0732648099162924 -0.00811816736573062 0.22239109310352,
	-0.0861676432854897 0.371463558564105 0.221187081602698 -0.157218473149579 0.222317184544606 0.0545813743008152 -0.135939326894093 0.0481223161861953 -0.0502786527014884 -0.0563586197908187 0.0265893393334449
	 -0.0711358646726385 -0.0769848277795182 0.197377333324592 -0.0609996208116516 0.157619294575123 -0.0167518653749272 0.110579985248075 -0.0734277560325139 -0.119195255577153 -0.01970824444709 0.0414858683941727
	 -0.346729770462293 0.108075171981176 0.0917775351755266 -0.204385928361437 -0.0469712930893857 0.0650535032088863 0.0857287829911681 0.207169118374659 0.267380628340512 -0.242195419584712 0.0855770008753007
	 0.0156048649072394 -0.268440743777586 -0.0151917887919779 -0.0256858260930559 -0.0237919712451603 -0.0447048240494176 -0.123125185230482 -0.16300255558497,
	-0.0977661850628304 0.022438993606731 -0.0255229295165669 -0.0371563564125219 -0.115326160679378 0.181830865182488 0.347278106807169 0.267483045932876 0.136988922246176 0.0441353907245999 0.216818396388806
	 -0.163504015995208 -0.0300787388633835 0.0165779065025238 0.0251463183004626 0.139367027445165 0.12164069569224 0.0434159712624994 -0.063593655362135 -0.181626901053815 0.17366895215346 0.0648509342800176
	 -0.111407993040628 -0.0198606141679142 0.152291400631733 0.262948069541875 -0.157214058594147 0.162877332755933 0.0546334729596068 -0.181266465721137 -0.219440351571989 -0.118034105337052 0.116697400790261
	 -0.101602261473068 -0.00577275692485564 -0.0502050767542763 -0.0111448130461567 0.0439237197695174 0.231660494280394 0.0846796543678457 -0.0250547673269631,
	0.0341703121653878 -0.247916042135563 -0.0440029448872049 0.0262516067245998 0.00327469641310238 0.0519471622742939 -0.163689268512638 -0.039724434754773 0.0212419911081795 0.270733582403722 0.456806096053238
	 -0.102420566348398 0.0305417809624398 -0.0591619138322831 0.0653373608663559 -0.0678902863063908 -0.0964066272626436 0.155336686234419 0.0849201430928549 0.120618111451816 0.200719000359704 -0.0123237398053601
	 0.196651775531505 -0.124543382586134 0.0571717749057229 0.109355697593141 -0.0885582270265629 0.0300606295612792 0.159754189245681 0.159124556942007 0.0490443201736238 0.000854690227268229 0.0608574173359013
	 -0.220158045952125 0.197842420048051 0.115143865100236 -0.041488791965169 -0.248324111020914 -0.132509689837999 -0.134258058455701 0.0785289774396897,
	0.245199153985158 0.0806293997137363 -0.146313117433832 0.227663267253799 -0.133632788330446 -0.101651055820981 0.217521681326475 -0.0735674451338722 -0.0576187243615618 -0.0622773617931438 0.0743213889205305
	 0.163462258883464 0.174586054365201 -0.0907416153249732 -0.0133629151246196 -0.233532292667922 0.18625085243159 0.0452970380802187 -0.0201005480562077 -0.129632936994936 0.256886515691172 -0.0485515874942938
	 0.111161339790374 -0.149930184550098 -0.0860247947325805 -0.021458560771073 -0.0285819873702238 -0.0457897685917347 -0.0291735183663845 -0.0090183658484042 -0.156117980830256 -0.167275739631758 0.0233961258147555
	 -0.0731973879945523 0.0923969819044488 0.372835378349712 0.310123881275221 -0.00884998960464697 0.0938233963091837 0.0845452855212529 0.31465105044074,
	0.00419592146225281 -0.0605565216856743 -0.171779192512989 -0.386380430154486 0.0930198542240515 -0.0207449562100833 -0.421525081640314 -0.0312846207949715 0.11389122326629 -0.110263631535241 -0.0534179209963861
	 0.0091909363642194 -0.123684353153791 0.168029743598128 0.140240922859964 0.116585633248984 -0.0367011299436158 -0.0839932812658497 -0.0229381858730426 0.0750208503325393 -0.161571849004144 0.0218054259605517
	 -0.0680646713955675 -0.105093823430994 0.122867003557074 -0.0281719682868162 -0.0482466497937777 0.123691918438222 0.132886408379504 -0.0530035002763293 -0.102722809423703 -0.13699863933365 -0.0502519327109966
	 0.234082325944114 -0.0737402318457893 -0.0197901900420048 0.0514564699274483 0.0769512892108308 0.113766087152898 0.115873108897031 0.0924637374304724,
	0.0389907317341314 0.193285601612193 -0.158372544819746 -0.0545925122041749 -0.00159624520331769 -0.150146049962839 0.0766613538523425 0.179025091249745 0.101615969566652 0.00641765157087061 0.00840922506261038
	 -0.0123927477292575 -0.128607711802526 -0.0000915833353947851 0.00724235681918256 0.259974856587717 0.0245569490342994 0.0979869900813278 0.128869068680528 -0.0423317352900072 0.020774404448375 0.028896482822568
	 0.177040732677734 -0.0330981771364578 -0.064283811566833 0.0918580331729049 0.147152011627104 -0.0703937037143036 0.276014814071108 -0.0528122511725668 -0.133374419491819 0.26389271045851 -0.0745799800276085
	 -0.112220407915536 -0.155321255845032 0.166440953076575 0.0379161440780153 0.201637491943844 0.187542415168608 0.0224088411410439 0.0538807046070406,
	-0.0962584656717945 -0.166774271116486 -0.359360055958926 0.0803891270410155 -0.167190552791897 -0.279858877464835 0.102546264141332 0.0550375592461623 0.091262684337368 0.242681522033747 0.160848377925161
	 -0.132028334474379 -0.108331970042495 -0.0877332183777805 -0.0612641581947804 0.094759460503301 0.00876090878772573 0.114465224568157 -0.0627418561262871 -0.199060613012866 0.1111452436046 -0.209620295252749
	 0.0846731852727664 0.0345551500706434 0.141610833996374 -0.0724219607849953 -0.202355446865902 -0.00301559322391452 0.220631573834553 0.10051118792201 0.244902179977153 -0.0529457917072216 0.0417517725410198
	 0.0829939481928266 -0.117980994319281 0.293924036465302 -0.316096303273231 0.0619398768467761 -0.104719165569967 -0.28982525244838 -0.0322965094880258,
	0.103004388505888 -0.0530768893119114 0.0883501573645591 -0.0528869301540667 -0.102292714697082 -0.114478378577488 -0.235347483014298 0.0597012395182528 0.142349786896819 0.0418047949623949 0.110973261631525
	 0.151249374271668 0.0208675660354344 -0.079663185306322 0.0627313539990634 -0.0143765708730626 0.225847000366215 -0.0710500126727108 -0.0477321203213817 0.201590640484893 0.120014088246444 -0.256849251907077
	 0.0202955726611813 0.039396319049265 0.130819727347365 -0.135926363921089 0.0457134319711185 -0.0142734535414908 -0.015777454767255 -0.000650741347060804 0.356524737326544 -0.122934389417056 0.25873845606272
	 0.107632285585753 -0.0662125352547157 0.240402135427334 -0.00865784558245825 -0.318545858093286 -0.11262948686425 -0.145222023409058 0.166012405007532,
	0.0783150577560363 -0.12710188743187 0.00812941393105354 0.196768470689121 -0.141190863205586 0.00762384183141358 -0.18613035427469 0.175797757381729 -0.102384572166714 -0.00695417723734164 -0.0643161654027119
	 0.0618770429282037 -0.0128025411411376 0.0715854217332113 0.0298594646527367 0.0923190973174797 -0.175658638742117 0.102221984302833 0.0886182941271885 -0.275065210298206 -0.111418251141657 0.132220044709785
	 0.110542597418594 0.0156599756257048 0.000331687225540412 -0.127870644827402 -0.100546828228593 -0.108379990999601 0.0527225026844882 0.294520333955123 -0.163189605285447 0.133665268815813 -0.112940629889709
	 -0.00107309458199537 0.0345372361823275 -0.0260314855618698 -0.0305642579048652 -0.13337488077001 -0.0206341001715539 0.12069373989779 0.0459058588081949,
	0.265317997240025 0.0325176673125297 -0.0000004389204105987 0.0731203770140051 -0.0465374932542676 -0.0795508750171188 0.0622859195753742 -0.0729816080783992 0.0125548524354397 0.158358546253063 -0.118163808591597
	 0.0953368332471423 0.0718545617075107 0.365286809560129 0.243657938936172 -0.0480356389712504 0.0384862533650755 0.135572804200868 0.0729306515817033 0.200603274987294 -0.0813569765022863 -0.225690927864696
	 -0.0119324787001283 0.112523441054805 0.0227044524580496 0.237181188914136 0.0519486610490502 -0.0707161061249199 0.164317949196403 -0.0146139627671833 -0.00435313620678102 0.18894627637231 -0.294334210365611
	 0.0312883662307008 -0.200744723035141 0.367970026252394 -0.148546300764723 -0.0055470654231458 -0.116591345075893 0.0801564960568267 0.151506157293009,
	-0.0936887338759349 -0.111271209750877 -0.0129625845276784 0.0868785970497008 0.0160104620139856 0.0340786978313137 -0.106014654147097 0.175635915967515 0.130254263207317 -0.219760315688324 -0.100679507211181
	 0.0937878074021215 0.0175878263093472 -0.0798428366063995 0.158296300202454 -0.0346446008264563 0.0249206787921449 0.055072852109435 -0.121888739327503 -0.189885059320669 -0.103248930259735 0.225496881582177
	 0.0859731324826552 0.0820031869320274 -0.240589343446438 -0.148856039847018 0.150431879292149 -0.201217377914723 0.0175785112578117 -0.0480525289440039 0.0187596597352647 0.171826502435592 -0.0483460156913896
	 0.366904065732237 0.0802218729330392 0.14786003613098 -0.0405151717731176 -0.0046959764446847 0.0659316162602933 0.0878647608335958 -0.132062018309938,
	0.242117259648491 -0.0158122447864121 0.0186872861261352 -0.15518755078351 -0.160612151491524 0.153332702865404 -0.133711095501489 0.0133352264464337 0.011852808213604 -0.0291531314064014 -0.196639046311242
	 0.152202420488969 -0.292739966911999 0.194684259646043 0.0623767162099267 0.0193179444460935 -0.0199032714868862 -0.14589953317334 0.274691316102663 -0.183023065117081 0.041677307800686 0.195560082645042
	 -0.0873816222199014 0.000951706111981318 0.248936530603479 -0.108772878041949 -0.0916389024680635 0.0353308444608107 -0.0370941793988537 0.0421513589625281 0.175513601643519 0.0348412952385184 -0.173632588148639
	 -0.159615969894537 0.158836577043493 -0.231642791211744 -0.00896170517922497 0.126973095750937 0.102711102287428 0.0206667641807854 0.00906465671870951,
	0.102348748622951 0.122241507331002 -0.108198461155474 0.0115676932791933 0.0823114026599872 0.140214774807253 0.347556448739978 0.166581790031681 0.0747100163639243 -0.0246007179903735 0.00786628106713539
	 -0.156056728037666 -0.024425085031177 0.172130122528912 0.1110053843264 -0.0915170369093265 -0.0723834653852918 0.0417822348816705 -0.136237681936209 -0.260825659029875 0.0124813647865428 0.32407626605222
	 0.199661428800499 0.0685856909999754 0.367363009123057 -0.189227522579602 -0.0878906406568556 -0.057212487884098 -0.0212806140945367 0.0358966515506878 0.0266900426891055 -0.144706139136269 0.203770498342184
	 0.0125193512039862 -0.0499281810933385 0.0975729353099167 -0.179174511591204 -0.0173544363608715 0.0279522318683661 -0.0887735192731246 0.111006053949651,
	0.111467222471881 0.0985361239377403 0.135588709640273 0.148447143675617 0.254902372135839 0.194776123150934 0.209349982368269 -0.108147697818708 -0.109999132856614 -0.15343763839289 0.109451968413044 -0.137106799618027
	 0.112618238135525 -0.217512116311544 -0.191965126412746 0.107797677249475 0.193052816138523 -0.22636298622041 -0.166176467630013 0.0701499162682706 0.0912790901354385 -0.0968231236285698 -0.0626816731926882
	 0.0484756380959151 -0.0737292899958777 -0.107825518289918 -0.0278518575293094 -0.0678429010222617 0.104509456316114 -0.0422358664800254 -0.224011306821715 0.240959589517037 -0.0498299988665388 -0.0313571101909207
	 0.0768975222584963 0.246681983189981 -0.0411038934461041 -0.143716072510595 0.118976758283408 0.0746880442427845 -0.167589131851057,
	0.176513522435414 -0.176971225982188 -0.0328805421695643 -0.0944044410818945 0.216203834710149 0.0890634867052734 0.0608861634570714 0.163948460393474 -0.00375873453544432 -0.0938426876545059 -0.137072575830068
	 0.172130970306341 0.174939153122873 -0.0136023124979233 -0.0032960062102703 -0.0151981192410881 0.137851938522263 -0.168758182880167 -0.0987892765694095 0.239899103596467 0.13088513141914 0.149923634208283
	 0.00126765259394174 -0.0351605827652292 -0.260486619398832 0.267170945697025 -0.155606069239814 0.0217829698724471 -0.125394496500998 0.161263867052076 0.0781789308527327 -0.131155120592832 0.0873037679936806
	 -0.296020359026121 -0.0330188693917269 0.0106827573423888 -0.117556837485012 0.110451707681117 -0.228199072127857 -0.13538497048372 0.0644577010505013,
	-0.0184723633869473 0.0639715250366454 0.176068886838553 0.0690166040771212 0.0911758113679431 -0.375827155822254 0.180944258236646 -0.0596275086131345 0.124782251645855 -0.118736233217967 -0.116321990995514
	 -0.0703177536831582 -0.0777321115372285 -0.0892780406721481 0.0576680704113116 0.206430903902247 -0.00839226996158863 -0.0556714670978724 -0.0787947985384581 0.143428115733676 -0.0146493975782277 0.205261748103524
	 -0.090342448721791 -0.106074282144428 0.0130275016203796 -0.109205010282869 -0.0316110242188162 0.265758791586708 -0.220311597571541 0.203268895336733 0.158002714087556 0.261042718155501 -0.0914157812608587
	 -0.0565132847279191 0.00422986028128725 -0.152695657927558 0.155556281438225 0.145566283244629 0.058219614160171 0.0952941554110567 0.0181596655601211,
	-0.0868464203986094 -0.116656778589607 0.0879743111946031 0.113241991553815 -0.358302071508696 0.0512408068579087 -0.0531121918578896 0.229831132313307 0.0995031379019857 -0.0768188466759315 -0.0415786392734297
	 -0.0133215439234082 0.0611923107679342 -0.073196115870801 0.137675192963108 0.126109259567876 0.15401564538854 -0.238306252785866 0.00975680460041616 0.109124135490749 0.141703009624495 0.0703861686733927
	 -0.00418577987631838 0.0139900595670271 -0.171203033694641 0.0501716296428067 0.00550583186218186 -0.116723107261622 -0.00332671619140953 -0.237088121202983 0.117004499998701 -0.0818998432260904 0.183674989972168
	 0.046691473239259 0.111096657449142 -0.0822766208210688 -0.156529268053743 -0.022653386128331 -0.0637092112726391 -0.224014425413495 0.0453671193073846,
	0.159319258770785 0.0156470573787924 0.135792422066441 -0.196877456295161 0.17011868417443 0.234060079733305 -0.0860189722048615 0.101389879114029 0.365942067148539 0.162965070945499 -0.135368735839525
	 -0.0656989504310053 0.184205376104597 -0.0169926144937031 -0.0449053088695841 0.206466730340685 0.147782547677777 0.006409237129551 -0.0236823045867344 0.269371560459479 0.0229205710837718 -0.150702713638983
	 0.138312889514854 -0.163831524888941 -0.128023386492847 0.271221063804362 0.125623813085314 0.0908658319089575 -0.0741633187798935 0.120315794534632 -0.0382495465457717 0.152826618495327 0.0434756881835058
	 -0.0973363313810819 -0.0754924776981562 0.247655471734969 -0.0121341449813119 0.30469569482179 -0.253124263129837 0.0329527274239159 -0.203287054691803,
	-0.0754081770931001 0.0305850715049538 -0.142410781116002 -0.132139433990717 -0.0340140855652183 0.237432603910838 -0.162123546786229 -0.133288695070149 0.0951579785459005 0.161486786180439 -0.209501844876385
	 0.184849328713496 -0.0114175050153291 -0.136967581991132 -0.0954986715684945 0.0531233597024609 0.282243748872803 -0.0607504124032997 0.0474337410808797 0.124638960874812 -0.074538312977069 -0.0729770166435145
	 0.12798137026373 0.15026327286967 -0.0372188593932677 -0.0961812982521292 -0.101278949897814 0.0892827658941015 0.0468307826599525 0.199732052617874 0.0701969750383325 -0.044622806445549 -0.133008559710581
	 0.0435363492248543 -0.0360910209525401 0.0427171648329919 0.122748125151809 -0.0378624217239684 0.208125509306974 0.0357578533850168 -0.247366887144938,
	-0.0663835974478593 -0.247397941830863 0.0156853614796536 0.0714759345373905 -0.039647219192837 0.0607950581554661 0.0550978048531126 -0.0501388678763179 -0.201813344692836 -0.14453604193173 -0.144549543530576
	 0.105126621409097 -0.0580688978392869 0.0549464401765794 -0.0129057006557678 -0.0920212118832426 0.113381935188412 0.159781615146462 -0.0824288048834632 0.251073361894761 -0.0448090195750216 -0.181952613197356
	 -0.0662371149851826 0.0392779260207211 0.0885115325334098 0.244717603382577 0.150767611410541 0.135082157540404 0.153721325411526 -0.00624118817802251 0.113430609593398 0.122193262747598 -0.217251031566747
	 0.256633525664518 0.3381723034917 -0.10630978354502 0.00753119036402438 0.165506464878405 -0.238858938921167 -0.188977128297189 -0.0150763224414713,
	0.0760291738660924 -0.0891228379751795 -0.015270010699909 0.0295420118052975 0.0548297054380047 0.276350602816102 0.0448279586126453 0.234650571414758 0.0365393405361851 0.115307348588413 -0.122672602471522
	 0.24194275753471 -0.129293632679429 0.0543812291613089 0.0298494102928859 -0.157255656499129 -0.30285529227943 -0.1686969773483 0.165224759118694 0.0486901151632057 -0.296482002067164 -0.0960293054941982
	 0.00473294148738894 0.00450660004377175 -0.00151823751323241 -0.1213370424299 -0.177992805258607 0.22467756365504 0.172765626222339 0.138243291630474 0.0518644717128195 0.114130429540486 -0.0653903771206226
	 -0.0409673438642899 0.226838636798679 -0.039247193982345 -0.0885771432680306 -0.212853213034556 -0.021254675089955 -0.133369420472155 -0.0219230165042146,
	0.125079280090212 0.0962326726901086 0.142027573213694 0.0751773331764136 -0.0291233930585378 -0.172865559472479 0.0998065035654261 0.175066313484414 -0.0687455996874547 0.0790444482130692 0.0881119025825798
	 0.220750664916522 -0.080942160375155 0.160536068918603 0.0338533420014652 -0.145350591697949 0.0468758450412783 -0.153170355089814 0.136633387712539 -0.0314758337675302 0.213132932115778 -0.197177906743872
	 -0.191230260827244 -0.0497999425634547 -0.0461928891966957 0.0109362294116763 -0.159432605268449 -0.131223559670622 -0.287130581705852 -0.0615885821636204 0.220721121669685 0.147484429471749 -0.195737513002935
	 0.0131873260617017 0.0644423807311648 0.0485232562728002 -0.0374215424364257 0.0150174392272323 0.139026895917226 -0.163712467366827 0.108188220542158,
	-0.0291520800017345 -0.0409370595114257 0.0248405730030109 0.0861952826957119 0.267351086194072 0.0972408789482935 -0.12113997819924 -0.130068565282882 -0.0193156035851396 0.144580206029849 0.142204416339881
	 0.23919294344058 -0.117238968424474 0.0637300584162678 0.0422035154534211 -0.0562182458977421 -0.00706338052869176 0.21633764205233 -0.128976642633274 0.0221964773681487 0.389017343391795 0.10395597261833
	 0.0465459974607798 0.398268052027162 0.251173747790496 0.11206442835867 0.318169604107398 0.0957507993034441 0.173607475807029 -0.00571709509415976 0.218499537860308 -0.0486550891442205 0.19484294436419
	 0.0591874207461616 -0.0391752682138638 0.13275180371836 -0.0658419767091127 0.0382432307608255 -0.0272711700309667 -0.0911008396038193 -0.110486218617137,
	-0.0714986139447664 0.115192121273336 0.119666018183201 0.0996796776185175 -0.249567981616617 0.110154296667485 -0.237506790459727 -0.0747031537380389 -0.0259380758610635 0.0451338759783435 -0.0849734390340762
	 -0.11780396014252 -0.237679848102793 -0.244844116900117 -0.150436028222263 0.0315626773056485 -0.102330029230783 -0.142405495920857 0.0859519704213086 -0.0439824069538574 0.125185462963374 -0.103277350403755
	 0.1221105904233 -0.109750817552647 0.133648002337938 -0.0971233840319258 -0.0424837287303088 0.0317684011366062 -0.0989604128128978 0.0711428733080362 -0.0216893513476725 -0.05910417347083 0.0371151525089467
	 -0.0407534648205754 0.253152738028361 0.111243526335717 0.0861265011128727 -0.0628222194519472 -0.0877095323307762 0.0706786521095296 0.064762729486983,
	-0.10010305615593 -0.10161254033093 0.128707346079385 -0.0345784320684042 -0.282872223723118 -0.126439179451118 0.275646607019104 -0.0533620254036319 0.303929072798442 -0.027920631718728 0.0983903109961408
	 0.13588990870528 -0.0677103353255429 0.0401499895671924 0.122211603154387 0.0747118543706143 -0.270266509003508 0.0159919117481891 0.135589350918952 0.0143168125195282 0.022648206843445 -0.124163291866662
	 0.0128545362735286 0.0950878666550859 0.0600773017411655 0.209445942363434 0.138559142869938 0.122469992670977 -0.222619217966286 0.287046395982621 0.0245856389665467 0.0287974652048189 -0.0179618857209099
	 -0.0916524254224162 -0.183242978688241 -0.220871167024541 -0.182268652608747 0.0558234898299495 -0.0135008638158007 -0.227536963205042 -0.14023897280481,
	-0.0129089719120991 0.0331835356167488 0.297000047078912 -0.15847711678296 0.0834505865877192 -0.016523318081317 0.0857997953904349 -0.262604883021461 -0.0621300217980304 0.145629150097954 0.1549739126469
	 0.044579312928549 -0.112124259924382 0.199195047543175 0.0158156570475619 0.143715717220812 0.0751764294332448 -0.152154455428187 0.166129531412856 -0.0178468147698252 0.199838583335784 0.179257977793507
	 0.116456707021378 0.0562005766540474 -0.0773891654782721 -0.0593272180530805 0.0550927289521425 0.0726939490069011 0.156386743975761 -0.201512854556482 0.0283616723800488 0.227249020812275 0.0621422344070885
	 0.0489122715183448 -0.0692973663160467 -0.10997265338241 0.166878026052662 -0.175825029761063 -0.059867378416754 0.152389430880579 0.12292624461457,
	0.155079383823097 0.0491449765289549 -0.166008478242786 -0.229063235708068 0.0158848421350488 0.0753429924134546 -0.0487092707004898 0.130735937950481 0.188938763171607 0.253245118894653 -0.20344713839051
	 -0.00832565569134006 0.212398177547842 0.0674737739618694 0.0671519616643941 -0.309630239823027 0.179503361111568 0.159206069705422 -0.261541899189244 -0.257022640427357 0.00184097507923806 -0.223522125727219
	 0.0478562337491742 -0.094007740854305 -0.119220033995302 0.0530604500307403 0.194136366610903 0.161263985676656 0.0624104050006239 -0.0339498843454091 -0.0191044486816317 -0.0152401841150819 -0.0270671811896853
	 0.129941190241422 0.0415328895447712 0.155999283592352 -0.222805776475957 -0.0643245857995819 -0.0456611166198622 0.094199866405624 0.274385974007377,
	0.146702782964598 0.0221043588526578 0.0248071609503527 -0.00297337250851411 0.180770054483566 -0.117623215653008 -0.233306347176451 0.149207273830544 -0.172306971589381 0.0467708761215375 0.162547586411202
	 -0.0739239162434619 0.196959270259982 -0.0649324920336586 0.0925849565854381 -0.158480960841076 -0.127429620368331 -0.0180144920370198 0.0897403176167999 0.0764202205063776 -0.0996297205465297 0.28717538208009
	 -0.03717264348494 -0.0274698858012529 -0.039555030080241 0.0201217288165571 0.203825574846726 -0.112085944702139 0.207021515205529 0.11265762758125 -0.234782644419331 -0.122647334810151 -0.131248703758107
	 0.129912885098686 0.0686157168249638 0.0168323002210907 -0.0663867707786728 0.0162462530409286 0.0569539354443886 -0.15085503030828 -0.1847247294586,
	0.0755100231595105 0.255531120938976 -0.0978154040782429 -0.0424786334329562 0.13924136471891 0.0290139373732432 0.151061768592006 -0.188365560472444 -0.319653440787693 0.251219804084322 0.0442837483509243
	 0.167825227634066 -0.122643345210942 0.0145820408445483 0.230583613941892 -0.0545888769181264 0.257729131321175 -0.0135592360801792 -0.0748381710957504 0.152278799873901 0.00539813396508821 -0.139583035361133
	 0.0310129755412842 0.154408789250443 -0.0269450884767465 -0.157432600173275 -0.109160633560728 0.0203821645458104 -0.0493642131349076 0.117156280666519 0.0909483367372967 0.111032459836109 -0.0698347782422781
	 -0.0149319623654068 -0.0644933542867454 0.0674475691991224 0.119394653529772 0.18312642131007 -0.128947681771665 -0.0237599642150612 0.176830976480044,
	0.209661877249468 0.184964256138864 -0.0368504822037331 0.365101160028196 0.0588446545343416 0.228209512362922 0.090463694725352 0.215413815426452 0.187087140475101 0.145110631625037 -0.265360659929061
	 -0.0882547916446127 -0.0477714293146196 -0.00993647880662029 0.0583429561887966 0.0890447090067616 -0.0368298535867698 0.204086641328637 -0.0979122059922807 -0.000299363904285651 0.0862808636160865 -0.0333910743732885
	 0.0544640237591866 -0.161312450101559 0.186736797092521 -0.00402634165488655 0.151822667599973 -0.108132283063347 0.0526603131663011 0.0352859378692777 0.162702147691832 -0.0844997439439675 0.0957390826031731
	 0.273036156158056 -0.261885676789924 0.0109147874484735 0.0589531074094828 0.150107989517592 0.0806210724797229 0.103605566780611 0.116690540352958])})), New Column("Prin2 By specimen_material_type", Numeric, "Continuous", Format("Best", 12), Set Property("By ID", 363741664), Formula(If(:specimen_material_type == "not eye", [-0.115080221082747 -0.209900225769572 0.0968290351798219 -0.091300586738557 0.0181978957152887 0.159459303654364 -0.0881917041325403 -0.0477372657620772 0.227230024750367 -0.139140653235179 -0.0443383283327189
	 -0.0492743861702296 -0.0420350246490236 0.120087759602982 -0.027344105246931 0.141234980412667 -0.0577195224249864 0.113728440925647 -0.0259010683035995 -0.534405407348148 -0.357065713815592 -0.774334329655162
	 0.455464025564709 -0.0149777659344744 0.0319980671402773 -0.47608658185314 0.262715470232366 -0.167156696192278 0.113552167106919 0.250527898990933 0.00692692898455528 -0.0970215264670978 1.06798743317025
	 0.00139908891424365 -0.114330512415424 0.370108600355094 -0.156615147072368 0.575014132524245 0.127153690727086 0.822728096455019 -0.126011834498153 0.0847696413947763 -0.352024534598753 0.148202504255094
	 0.0362636104079626 0.0277470602345989 0.0469874864814001 0.0660823251629839 0.0567843328966912 -0.089651973278548 0.00796378410475527] * :Prin Data Matrix By specimen_material_type, :specimen_material_type == "eye", [0.0373396063069139 0.230664696195386 0.512508245952481 0.0771211912202765 0.102552115838519 0.0328516624565287 0.147645873926505 -0.0220060089806933 0.106127832055773 0.0388887660087035 -0.000881690433691752
	 -0.0198426054019754 0.0762297390951024 0.0078039166978775 -0.0471152985227043 0.593774008179762 -0.170869017502479 -0.113708226113662 0.133820227418733 -0.556377109748335 1.3256187250669 0.898204216297108
	 0.0572541789240763 0.513823610465856 0.0446641161167315 0.830570213060789 0.319466444747727 0.752341702486427 0.511002155994955 -0.202136766367594 0.0605407898027054 -0.0558908665183716 0.723319944968535
	 -0.0444360903373565 0.100224045427101 -0.0561517692189069 0.238934370196459 1.01080572261148 0.577594921103846 -0.336405816017908 0.0712808826453921 -0.0402225879506418 0.103441924984378 0.554727570109212
	 0.334725052871437 0.140221006869288 0.0105288459881024 -0.0140032865904578 0.0336143869948544 0.261388008724009 0.101418492908033] * :Prin Data Matrix By specimen_material_type, .)), Set Property("MDMCC Historical Statistics", {Creator("Principal Components"), Variance("on Correlations"), Number of Columns(51), Number of Observations(44), Freq(0), Variable Names({"A", "A2m", "A2ml1", "A3galt2", "A4galt", "Aa386476", "Aa387200", "Aa414768", "Aa465934", "Aa467197", "Aa543186", "Aa545190", "Aa672651", "Aa792892", "Aa986860", "Aaas", "Aacs", "Aadat", "Aaed1", "Aagab", "Aak1", "Aamdc", "Aamp", "Aar2", "Aard", "Aars", "Aars2", "Aarsd1", "Aasdh", "Aasdhppt", "Aass", "Aatf", "Aatk", "Ab041806", "Ab124611", "Abat", "Abca1", "Abca2", "Abca3", "Abca4", "Abca5", "Abca6", "Abca7", "Abca8a", "Abca8b", "Abca9", "Abca12", "Abca13", "Abca17", "Abcb1a", "Abcb1b"}), Mean([-0.40783718963311, 0.688382366020641, -0.0703818201606135, -1.74820393462455, -1.11818761674836, -1.73568946947707, -0.652766782082089, -1.31669052288985, -0.268024336861669, 0.0964787665895007, -1.83710734373927
	 0.273036156158056 -0.261885676789924 0.0109147874484735 0.0589531074094828 0.150107989517592 0.0806210724797229 0.103605566780611 0.116690540352958])})), New Column("Prin3 By specimen_material_type", Numeric, "Continuous", Format("Best", 12), Set Property("By ID", 363741664), Formula(If(:specimen_material_type == "not eye", [-0.0540473163977495 0.010568209477817 0.315290253978106 0.053445997656332 -0.10903397468042 -0.0290654569539251 -0.0760240677267104 0.0163457463609121 -0.0629606267528481 -0.0404981230494817 0.160830475061282
	 0.280226325566164 -0.166122635859345 0.0249159244026266 -0.0744073638721448 -0.675536128792737 0.541708093892269 -0.0427759437999161 0.424266902035473 0.35662306233048 1.15351437601919 0.118390732392532
	 0.59174735269028 -0.170956114367285 -0.00331309858468756 0.0423154972690205 0.667515148397746 -0.589897722235582 -0.136049918803676 0.191965139415353 -0.0849136917862428 0.186612291422516 0.503899063731028
	 -0.0613568691601628 0.0642397042807733 0.346859094667296 0.169963489630939 0.37105677427434 0.316743923807872 -0.159451397470294 0.194333486610114 0.0753119908408542 -0.0347400632430371 0.193202509103686
	 0.141334238314567 0.0414818182026895 -0.0555027932344142 0.0404315614933825 0.0254313271658903 0.19712500539599 -0.0510893689566014] * :Prin Data Matrix By specimen_material_type, :specimen_material_type == "eye", [0.211164035893975 -0.00224985047279214 0.0234991410909877 0.0602977187292219 0.20641298188744 0.175202756752555 -0.00809159029472949 -0.095056094642893 -0.0484298481814641 -0.156984238992855 0.108864025638519
	 -0.196796124310371 -0.000931426738609164 0.126263707865597 0.280091719509867 0.329960191674169 0.397827557967341 0.00942260745965418 0.257605693086491 -0.938661793809014 -0.927990366277237 0.806865618979402
	 1.1563823452673 0.50185578957415 -0.0431311321590864 -0.47927933409762 0.00379462219690331 -0.180235704958964 0.0205242797463916 -0.460920942998856 0.0999994984749991 0.0311941297422107 -0.857725484715446
	 0.0817834211905681 -0.0447764301261737 0.546372272351088 -0.0384369030608523 -0.378680994719527 0.262477463363927 0.244940149856749 -0.240465754067957 -0.0146206559899441 -0.329572431766294 -0.609892611018223
	 -0.562812815447039 -0.00358413616474873 0.0627190985036292 -0.025784350832213 0.02797722277042 -0.245866196335195 0.0670364439489268] * :Prin Data Matrix By specimen_material_type, .)), Set Property("MDMCC Historical Statistics", {Creator("Principal Components"), Variance("on Correlations"), Number of Columns(51), Number of Observations(44), Freq(0), Variable Names({"A", "A2m", "A2ml1", "A3galt2", "A4galt", "Aa386476", "Aa387200", "Aa414768", "Aa465934", "Aa467197", "Aa543186", "Aa545190", "Aa672651", "Aa792892", "Aa986860", "Aaas", "Aacs", "Aadat", "Aaed1", "Aagab", "Aak1", "Aamdc", "Aamp", "Aar2", "Aard", "Aars", "Aars2", "Aarsd1", "Aasdh", "Aasdhppt", "Aass", "Aatf", "Aatk", "Ab041806", "Ab124611", "Abat", "Abca1", "Abca2", "Abca3", "Abca4", "Abca5", "Abca6", "Abca7", "Abca8a", "Abca8b", "Abca9", "Abca12", "Abca13", "Abca17", "Abcb1a", "Abcb1b"}), Mean([-0.40783718963311, 0.688382366020641, -0.0703818201606135, -1.74820393462455, -1.11818761674836, -1.73568946947707, -0.652766782082089, -1.31669052288985, -0.268024336861669, 0.0964787665895007, -1.83710734373927
	 0.273036156158056 -0.261885676789924 0.0109147874484735 0.0589531074094828 0.150107989517592 0.0806210724797229 0.103605566780611 0.116690540352958])})), Set Label Columns(:NGS library ID), Group Columns("Principal Components", :Prin1 By specimen_material_type, 3))
define data table;
uniquetissue = {"eye", "not eye"};
ntissue=N items(uniquetissue);
splitdt = DataTable("PCAfull NGS library ID");
sdt = splitdt << get name ; Show( sdt ) ;
colList = splitdt << Get Column Names( numeric ) ;
obj = splitdt <<Principal Components(
				Y( Eval( colList ) ),
				Estimation Method( "Wide" ),
				"on Correlations",
				by( :specimen_material_type ),
				Eigenvalues( 1 ),
				Summary Plots( Label variables( 0 ) ),
				Arrow Lines( 0 )
			) ; Wait( 0 ) ;
			 obj << Save Principal Components( 3 ) ;
//loop to extract eigen values from each specimen_material_type (tissue)
for(i=1,i<=ntissue,i++,
			Report( obj[i] )[Outline Box( "Wide Principal Components specimen_material_type="||uniquetissue[i] )][Outline Box( "Eigenvalues" )][Table Box( i )] <<
			Make Into Data Table ; Current Data Table() << set name( "Eigenvalues for "||uniquetissue[i] ));
ian_jmp
Level X
Re: Problem extracting eigen value data from PCA report when using 'by'
// 'obj' is a list because of the use of a 'By' variable
firstByReport = Report(obj[1]);
// But 'makeCombinedDataTable' helps you out without looping
dte = firstByReport[TableBox(2)] << makeCombinedDataTable;
FYI, my browser was struggling due to the large script. Generally it's better to upload the JMP table, rather than the means to create it.
ian_jmp
Level X
Sburel
Perfect, worked like a charm.
Thanks also for the tip about attaching the data as a table. My browser is also struggling with the long script.
Best,
Sebastien
