Adhil71186
Issues in running a R Script from JSL
This is my script:
R Init();
x = R Submit File("C:/Users/adhil/Documents/JMP/Test Program Validation/Jun 2021 Test Program Release Validation/compile.r");
df = R Get(main_df)
R Term();
 this is the R Script I intend to run
library(dplyr)
setwd("~/JMP/HPLED Validation/Jun 2021 HPLED Release Validation")
new_tProgram_data <- "./data/A05/data_01.blu"
por_tProgram_data <- "./data/A05/data_02.blu"
new_df <- read.table(new_tProgram_data , sep="\t", skip=2, header=T) %>%
  select(c("Row", "Col", "Voltage", "LeakageV", "Power"))
colnames(new_df) <- paste(colnames(new_df), "NEW", sep = "_")
por_df <- read.table(por_tProgram_data , sep="\t", skip=2, header=T) %>%
colnames(por_df) <- paste(colnames(por_df), "POR", sep = "_")
main_df <- merge(new_df, por_df, by.x=c("Row_NEW", "Col_NEW"), by.y=c("Row_POR", "Col_POR"))
However when I run the R script from JSL and try to retrieve the main_df from r via
df = R Get(main_df)
I get the following Error
x shows -1
please advise
Re: Issues in running a R Script from JSL
You may have already tried this, but if not: try running the code (as you only have a few lines) line-by line using R Submit ( ) statements interspersed with R Get statements... you should then be able to see whether the problem is the original data (beginning with the files xxx.blu themselves), the merge itself (perhaps empty), or something else.
Cheers,
Brady
Adhil71186
Hi brady
I ran the the code in r studio, with the same blu files and it works. I haven't run line by line though
Adhil71186
When I type print(main_df) in the rscript , the data frame gets printed out in jmp logs, I have a problem in importing it to jmp
