Madhu_Acharyya
Problem Linking JMP Assistant to GPT‑4
I am using the JMP Student Version, and I also have an active OpenAI (GPT‑4) subscription. I have linked it to JMP Assistant (LLM), but the integration is not functioning. I am not sure what the issue is. Could you advise on what might be going wrong? Please see the attached screenshot.
Re: Problem Linking JMP Assistant to GPT‑4
I noticed the errors have litellm listed. These might just be left over logs statements but the latest version does not use this python package. Are you using the latest version of the Assistant that was posted on May 8th? https://marketplace.jmp.com/appdetails/Assistant?tab=version-history
Madhu_Acharyya
Hi @kristen-slappey . Thank you for the solution. It is now working.
Madhu_Acharyya
