dustincurry
Printing variables to display box/window
I have a script that calculates some slopes and offsets based on a large data set.
Once the slopes and offsets are calculated I want to output them to a new display box or window.
It has been a couple years since I have really done much scripting with JMP so I'm fairly rusty, so I'm sure the code below is far from correct.
How can I output the variables to some kind of pop out window?
My variables are Slope_1C, Offset_1C, Slope_2C, Offset_2C.
New Window ("Slopes and Offsets",
Text box("1C Slope = ", Slope_1C),
Text box("1C Offset =", Offset_1C),
Text box("2C Slope =", Slope_2C),
Text box("2C Offset =", Offset_2C),
Thanks!
Re: Printing variables to display box/window
If your variables have numeric values, you will have to change them to characters with Char(). Then you could concatenate them, for example:
Text box("2C Slope =" || char(Slope_2C))
I would use Lineup Box in case like this:
Slope_1C = 1;
Offset_1C = 2;
Slope_2C = 3;
Offset_2C = 4;
New Window("Slopes and Offsets",
	Lineup Box(N Col(2),
		Text Box("1C Slope = "),
		Text Box(char(Slope_1C)),
		Text Box("1C Offset = "),
		Text Box(char(Offset_1C)),
		Text Box("2C Slope = "),
		Text Box(char(Slope_2C)),
		Text Box("2C Offset = "),
		Text Box(char(Offset_2C)),
