Printing List of Columns (variables?)
Just checking to see if this is available...Is there a way to print out the entire list of columns/variables in a study (with short and long names) for reference?  With a very large database, it can sometimes be difficult to navigate through the list and could be handy to have an entire printout if available.  Thanks!
Re: Printing List of Columns (variables?)
Here is a simple script that will copy all of your column names into a column, which you can then do anything you want.
newdt = New Table( "columns",
   New Column( "Column Names",
   character,
   values( dt << get column names )
ms
Super User (Alumni) ms
A quick way to get all column names to the clipboard: Click in the columns field in the tables left panels, type cmd-A and cmd-C (ctrl-A and ctrl-C in Windows).
Paste the list into your favorite editor and print.
(The columns panel is even more useful for changing multiple column names by simply pasting them from another application)
