JesperJohansen
Prediction profiler for several responses fit by different models
When I have done a multi-factor experiment I fit models to each of my responses. Many times the different responses don't have the same significant terms and interactions as each other. After i reduce my model for each response I want to investigate the effects of changing factors on each response simultaneously. How do I do this when the models I fit are different for each response?
BR
Jesper
louv
Staff (Retired)
Re: Prediction profiler for several responses fit by different models
For each response save the prediction formula to the data table (red triangle hot spot-Save Columns>Prediction Formula). Then use the Graph>Profiler platform to specify the formulas that you saved to the columns in the data table as your Y (Prediction Formula) responses. This will bring all of your responses with their specific fit data into a combined profiler.
louv
Staff (Retired)
JesperJohansen
Great. That was just what I needed. Thank you a bunch.
BR
Jesper
louv
Staff (Retired)
You can save the Predicted standard error too if you need that in your profiler as well.
