Can this be done, that is, can a message be sent to a Picture Box to set the incoming JPG's height and width dimensions in pixels? I can grab the picture and modify its dimensions, so I'd presume it's JSL scriptable?
Else, if not, is there another Display Box which can set a graphics file (e.g. JPG) dimensions? thx... dj
