ChristerMalm
Prediction model screening
I'm using JMP 16.2 Pro, but after updating to Windows 11 and re-installing JMP, the Prediciton Model screening platform is missing from the Analysis menu.
Any suggestions why this may be? I have run all updates, re-installed etc.
/Christer
Christer Malm
Phil_Kay
Re: Prediction model screening
Hi @ChristerMalm ,
Go to Help > About JMP. Check that you have JMP Pro. It may be that after re-installing the software it got associated with a license key for standard JMP. Your IT / JMP Administrator should be able to help there.
I assume you are asking about Model Screening which you will find in Analyze > Predictive Modeling:
I hope this helps,
Phil
Phil_Kay
Hi @ChristerMalm ,
I hope this helps,
Phil
