MRB3855
Prediction Profiler Confidence Interval for the Nonlinear platform
Hi all: I'm interested in showing the confidence interval in the Prediction Profiler plot in the Nonlinear platform results; however, it says the interval is  available "only if a Std Error formula is specified in the launch window". Can someone give me an example of how that is done? I'm on JMP v18.0.0. Thanks in advance!
Re: Prediction Profiler Confidence Interval for the Nonlinear platform
Hi @MRB3855 ,
You have to essentially take the Prediction Formula and the CI formula out of the non-linear platform and use the Graph>Prediction Profiler and 'trick' it into thinking the CI is the SE formula by doing so:
Go to the NL platform and save the prediction formula and CI formula, then you need to have your prediction formula columns named as "Pred Formula [Name of Variable]" and your SE column named as "Pred SE [Name of Variable" - so for example "Pred Formula Growth Rate" and "Pred SE Growth Rate". Then take both columns to Graph>Profiler and JMP will ask you if you want to use the column as the SE.
Thanks,
Ben
Hi @MRB3855 ,
Thanks,
Ben
MRB3855
Thanks @Ben_BarrIngh : Counter-intuitive but it works! It appears the Graph/Profiler is designed to work with the Fit Model platform; so the renaming is using the naming conventions in Fit Model to "trick" the profiler platform into thinking the saved columns from Nonlinear platform are from the Fit Model platform.
