geoff1
Post-query script not working with JMP 15 ?
Just installed JMP15. Starting doing some test with some jmpquery I have.
I used the "Query Builder" to connect to SQL, and added "Post-Query Script" to save the table in specific folder.
When I open the jmpquery file (double click), and click "Run query", I got the datatable from my SQL, but the post-query script seems not running.
Could anyone confirm ?
 I looked at the Preferences\Query Builder and all check box look OK.
But when I run the jmpquery from a jsl script  (jmpquerry << Run ) , NO issue, my table is saved.
Thanks
Geof
@martindemel
Re: Post-query script not working with JMP 15 ?
Here's a link to the support note discussing the bug and workaround:
http://www.jmp.com/support/notes/64/895.html
geoff1
I did more test.
Before I was using JMP14.
Now with jmp15, I open the jmpqury file, I can see my script under the Post-Query script tab.
I save AS new.jmpquery .
When I open the new.jmpquery , the Post-Query Script tab is empty...!!
geoff1
thanks !
