Possible to have title bar display full file path?
Is it possible to have the title bar display the full file path rather than just the filename?
Re: Possible to have title bar display full file path?
Is this what you are talking about?
If so,  this is how to do it
dt01 = Open( "$SAMPLE_DATA/Big Class.jmp" );
bivariate( x( :height ), y( :weight ) );
// Once the report is generated, this JSL will change the title
// to the path
thePath = dt01 << get path;
Current Report()[Outline Box( 1 )] << set title( thePath );
@txnelson
That answers my question in the case of a report, but can it be done for a data table? Ideally I'd the Windows title bar to display the full file path and filename.
The Windows title bar for a data table only lists the table name.  Given that, you technically can change the name of your data table to be the complete path
Here's a slightly flawed solution:
dt = Open( "$sample_data/big class.jmp", Invisible );
New Window( dt << getpath, dt << New Data Box );
  • The window has a small space above.
  • The window thinks it is a report, not a table. The needs-to-save check does not work right.
  • When the window is closed, the invisible table remains open. You might add an OnClose to fix that.
