shampton82
Populate the manage spec limit table from another table through JMP
Hey everyone,
I was wondering if someone could help me with the JSL to populate the manage spec limit (MSL) table by loading the values from another table.  The provided script in the sample library only causes the MSL window to pop up, I then have to select the reference table and save to column properties manually.
Thanks for any ideas!
Steve
Re: Populate the manage spec limit table from another table through JMP
Do you want to populate Manage Spec Limits from spec table or do you want to set spec limits from spec table to measurement table? I'm not sure if you can fill Manage Spec Limits by using Load from Limits table by scripting, but there are most likely at least two ways to fill it otherwise:
  1. Add Spec Limits to measurement datatables columns as column properties from limits table by looping (and then open Manage Spec limits if needed)
  2. Manage Spec Limits platform is Table Box, so you could set values there most likely with some scripting
I would use option 1 as it is in my opinion simpler option.
This script should give some ideas how to do option 1:
//create spec table dt_spec = New Table("Limits", Add Rows(2), New Column("Variable", Character, "Nominal", Set Values({"height", "weight"})), New Column("LSL", Numeric, "Continuous", Format("Best", 12), Set Values([50, 49])), New Column("USL", Numeric, "Continuous", Format("Best", 12), Set Values([150, 151])), New Column("Target", Numeric, "Continuous", Format("Best", 12), Set Values([100, 101])) ); //Loop over spec table and look for matches in measurement table meas_cols = dt << Get Column Names("String"); For Each Row(dt_spec, If(Contains(meas_cols, :Variable), Eval( Eval Expr( Column(dt, :Variable) << Add Column Properties( Set Property("Spec Limits", {LSL(Expr(:LSL)), USL(Expr(:USL)), Target(Expr(:Target)), Show Limits(1)}) ) ) ) ); ); //open manage spec limits if needed dt << Manage Spec Limits(Y(dt_spec[0, "Variable"])); //Close(dt_spec, no save);
It looks like the original request was to use jsl to load a limits table into the Manage Spec Limits platform and then save to column properties.  Below is JSL that will do that.
dtLimits=New Table( "Limits",
	Add Rows( 4 ),
	New Column( "Variable",
		Character,
		"Nominal",
		Set Values( {"OZONE", "CO", "SO2", "NO"} )
	New Column( "_LSL",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [0.075, 5, 0.01, 0.01] )
	New Column( "_USL",
		Numeric,
		"Continuous",
		Set Values( [0.25, 12, 0.09, 0.04] )
	New Column( "_Target",
		Numeric,
		"Continuous",
		Set Values( [0.15, 7, 0.04, 0.025] )
	New Column( "Show Limits",
		Numeric,
		"Nominal",
		Set Values( [1, 1, 1, 1] )
	New Column( "Importance", Numeric, "Nominal", Format( "Best", 12), Set Values([2,4,1,3])),
	New Column( "Units",
		Character,
		"Nominal",
		Set Values( {"lbs", "mi", "in", "ft"} )
	New Column( "Centerline",
		Numeric,
		"Continuous",
		Set Values( [0.15, 7, 0.05, 0.025] )
	New Column( "Sigma",
		Numeric,
		"Continuous",
		Set Values( [.05, 4, 0.03, 0.01] )
	New Column( "Measurement Sigma",
		Numeric,
		"Continuous",
		Set Values( [1, 5, .5, .8] )
	New Column( "Lower Tolerance",
		Numeric,
		"Continuous",
		Set Values( [0.075, 5, 0.01, 0.02] )
	New Column( "Upper Tolerance",
		Numeric,
		"Continuous",
		Set Values( [0.25, 12, 0.1, 0.05] )
	New Column( "Reference",
		Numeric,
		"Continuous",
	New Column( "Resolution",
		Numeric,
		"Continuous",
		Set Values( [0.05, 1, 0.08, 0.9] )
	New Column( "Historical Mean",
		Numeric,
		"Continuous",
	New Column( "Historical Process Sigma",
		Numeric,
		"Continuous",
		Set Values( [1, 2, 3, 4] )
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj=dt<<Manage Spec Limits( Y( :OZONE, :CO, :SO2, :NO ), Load from Limits Table(dtLimits) );
obj << Save to Column Properties;
shampton82
 Thanks for the input.  I agree if there isn't a way to script in those steps then looping through the limits table will have to be the way to go.  I was hoping I could shortcut the more complex coding and just add in some additions commands to the MSL.
You can open Load from Limits Table, but no idea how to go from there to Other and then input path to limits table
obj = dt << Manage Spec Limits(Y(dt << Get Column Group("Processes")));
obj << Load from Limits Table();
Here is a simple script that will create a limits table that can be used for Manage Spec Limits
// point to your table that has limits
dt = Data Table( "your table name" );
// Create the new limits table
dtLimit = New Table( "Limits",
	New Column( "Variable", character ),
	New Column( "LSL" ),
	New Column( "USL" ),
	New Column( "Target" )
// Read through the original table and move to the new limits table
For( i = 1, i <= N Rows( dt ), i++,
	dtLimit << add rows( 1 );
	dtLimit:Variable[i] = dt:your column name that has the parameter name[i];
	dtLimit:LSL[i] = dt:your column name that has the LSL value[i];
	dtLimit:USL[i] = dt:your column name that has the USL value[i];
	dtLimit:Target[i] = dt:your column name that has the Target value[i];
	Add Rows( 4 ),
		Character,
		"Nominal",
	New Column( "_LSL",
		Numeric,
		"Continuous",
	New Column( "_USL",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Nominal",
		Character,
		"Nominal",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
