9873313s
Please tell me how do I interpret the results of cross-correlation in JMP??
First for sample data: go to help, select sample data library; inside the Time Series folder open SeriesJ.
Analyze>Specialized Modeling>TimeSeries
Put Output CO2 as the Y, Input Gas Rate as the X
From the Transfer Function red triangle select Cross Correlation.
The result is a graph of the lag and cross-correlation functions.
I can see that the cross-correlation function has the highest value at lag 5, indicating a negative correlation. How do I analyze whether this is statistically significant or not?
What do blue lines mean in the graph?
#cross-correlation
Re: Please tell me how do I interpret the results of cross-correlation in JMP??
Your example is not a valid time series. The variable in the X role represents time, which should be strictly ascending and equally spaced values.
