VD
VD
Please help for how to script to select the 4 highest cell value in a column
Craige_Hales
Re: Please help for how to script to select the 4 highest cell value in a column
dt = Open( "$sample_data/big class.jmp" );
nr = N Rows( dt ); // needed below to find the end of the ascending sort list
rowsSortedByWeight = Rank( dt:weight << getvalues ); // Rank gives the indexes, ascending
heavyRows = rowsSortedByWeight[nr - 3 :: nr]; // four biggest at end
For Each( {r}, heavyRows, // get each row number into r from the heavyRows matrix
	// look in the log for the report...
	Write( Eval Insert( "\!nname=^dt:name[r]^ weight=^dt:weight[r]^" ) )
name=KIRK weight=134
name=LESLIE weight=142
name=JACLYN weight=145
name=LAWRENCE weight=172
edit: this will work better with missing values:
nr = N Rows( rowsSortedByWeight ); // should handle missing values
Rank() will return a short list, without indexes to missing values, so use the number of rows in the ranked list rather than the number of rows in the data table.
more edit: And if you mean to select the rows in the table,
dt << selectrows( heavyRows )
Craige
Craige_Hales
Craige
VD
VD
Thanks much to Craige_Hales for a quick response.
It works well
