NGC_DAquila
Platform Preset
Is there a way to use a platform preset or a setting to make all my graph builder headers bold and a certain font size and do that with the axis titles and the legend?
Re: Platform Preset
From the File menu go to: File > Preferences > Fonts.  Here you can set the default fonts for all report elements.  You can also set the font (and other formatting) manually in a report and save that as a preset which is specific to that platform.  The first option will be a global solution for all platforms.
Re: Platform Preset
What have you tried with platform presets? Did you face specific issues?
Re: Platform Preset
