  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Mo
Mo
Pick File FilterList Argument Options
Can someone help me understand the Pick File options and syntax?
1. How can I find the options available for the filter list for Pick File? The Scripting Index shows {"JMP Files|jmp;jsl;jrn", "All Files|*"}, but I've also found {"Excel Files|csv;xlsx;xls", "All Files|*"}. How do I find what options are available?
2. What does the "All Files|*" do? I get the same window with and without it.
Re: Pick File FilterList Argument Options
I think you can use whatever you want in there. The syntax is (and * seems to be wild card for all file types):
Label|suffix1;suffix2....
You can try and add different combinations to see what you could do:
Pick File(
	"Select JMP File",
	"$DOCUMENTS",
	{"JMP Files|jmp;jsl;jrn", "All Files|*", "Minitab|MAC;mtb", "Text|txt;csv;yml;xml;html",
	"My custom files|asdad;qwerty;verylongfile"
	1,
	0,
	"newJmpFile.jmp"
Pick File(
	"Select JMP File",
	"$DOCUMENTS",
	1,
	0,
	"newJmpFile.jmp"
Mo
Mo
Thanks, that helps!
