    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
Georg
Percentiles in JMP different from other programs, how to get the same in JMP?
Dear community,
we found that JMP calculates the percentiles differently from other programs, how can I get the same value in JMP?
Other programs are e.g. Oracle SQL and Excel (PERCENTILE.INC)
See some references and example in script below.
Thanks and BR
names default to here(1);
// JMP calculates other Quantiles than Python/Excel
// how to get same values in JMP?
// see:
// web("https://community.jmp.com/t5/Discussions/Quantiles-result-from-JMP-are-different-from-Python/m-p/762983");
// perhaps JMP equal to PERCENTILE.EXC in Excel, and not to PERCENTILE.INC
// Percentile Calculation
// web("https://community.jmp.com/t5/Discussions/Quantile-Percentile-Calculation/m-p/327198");
data = [10.56 10.85 11.08 11.57 11.81 12.27 12.76];
Q80_oracle = 12.178;
// as excel as well
Q80_jmp = Quantile( 0.8, data );
// 12.466
// how can I get same values as in other programs?
Georg
Georg
Re: Percentiles in JMP different from other programs, how to get the same in JMP?
Dear all,
thanks for the input. The reason why we need is "customer expectation", i.e. the addressee expects a certain way to calculate.
Meanwhile I found a way with a python workaround, see script below.
Thanks to all and best regards,
New Table( "Percentile_Cont_Example",
	Add Rows( 7 ),
	Compress File When Saved( 1 ),
	New Table Variable( "SQL",
		"with val_tab as
select 1 AS lot, 11.08 as value FROM dual
union  select 1 AS lot, 12.76  as value FROM dual
union  select  1 AS lot,10.85 as value FROM dual
union  select 1 AS lot, 11.57 as value FROM dual
union   SELECT 1 AS lot, 10.56 as value FROM dual
union select 1 AS lot,  12.27 as value FROM dual
union  select 1 AS lot,11.81 as value FROM dual
SELECT
val_tab.lot
, val_tab.value
, percentile_cont(0.8) WITHIN GROUP (ORDER BY val_tab.value) OVER (PARTITION BY val_tab.lot) quant80_database
from
val_tab"
	New Column( "LOT",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [1, 1, 1, 1, 1, 1, 1] ),
		Set Display Width( 60 )
	New Column( "VALUE",
		Numeric,
		"Continuous",
		Set Values( [10.56, 10.85, 11.08, 11.57, 11.81, 12.27, 12.76] ),
	New Column( "QUANT80_DATABASE",
		Numeric,
		"Continuous",
		Set Values(
			[12.178000000000001, 12.178000000000001, 12.178000000000001,
			12.178000000000001]
		Set Display Width( 334 )
	New Column( "Quantile80_JMP",
		Numeric,
		"Continuous",
		Formula( Col Quantile( :VALUE, 0.80000000000000004 ) ),
		Set Display Width( 141 )
	New Column( "Quantile80_Python",
		Numeric,
		"Continuous",
		Formula(
			data = (As Column( :VALUE ) << get values)[
			Loc( As Column( :LOT ) << get values, :LOT )];
			Python Execute(
				{data},
				{result},
				"import numpy as np
result = np.quantile(data, 0.8)
			result;
		Set Selected,
		Set Display Width( 292 )
Georg
9 REPLIES 9
Thierry_S
I just tested your dataset in Excel, and I got a Q80 value in Excel = 12.466, exactly the same as JMP.
I cannot test in Oracle, but I noticed that in R, I get a Q80 value = 12.178. Moreover, the Q90 in R is 12.466.
There must be an explanation on how the quantiles are calculated between these programs.
Best,
TS
Thierry R. Sornasse
Thierry_S
One more thing:
In R, there are 9 different ways to calculate quantiles.
Method 6 returns the same Q80 as JMP and Excel
Method 7 returns the Q80 you found in Oracle:
Best,
TS
Thierry R. Sornasse
Georg
In Excel there are two ways,
PERCENTILE.INC and PERCENTILE.EXC.
My problem was, that I couldn't get the same value in JMP as customer with PERCENTILE.INC, so that workaround with python was needed.
Georg
MRB3855
Hi @Georg : I'm curious; do you mind if I ask why it matters if they match or not?
Georg
Dear all,
	Add Rows( 7 ),
		"with val_tab as
SELECT
val_tab.lot
, val_tab.value
from
val_tab"
	New Column( "LOT",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Set Values(
			12.178000000000001]
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Formula(
			Python Execute(
				{data},
				{result},
				"import numpy as np
			result;
		Set Selected,
Georg
pmroz
How do I install numpy for JMP 18?  I have a separate installation of python 3.13.2.  I installed numpy for that version but still get this error when trying to run the above code
ModuleNotFoundError: Please install the Python package NumPy.
 at row 7
Python Install Packages example from scripting index should work
// install numpy and pandas packages
Python Install Packages("numpy pandas");
or you can use python side of JMP and use jpip
import jmp
import jmputils
# update to latest version of pip and setuptools then install numpy & pandas
jmputils.jpip('install --upgrade', 'pip setuptools')
jmputils.jpip('install', 'numpy pandas')
https://www.jmp.com/support/help/en/18.0/#page/jmp/install-a-python-package.shtml#
Did you try
Python Install Packages( "numpy" );
pmroz
Thanks that worked.  Wasn't familiar with that command.
