Percent agreement for rater calculation in attribute gauge study
Oct 29, 2023 01:22 PM(3634 views)
Hello.
Can anybody explain what is meant by "number of uncounted matching levels for this rater k within part i for rep j" in the "Statistical Details for the Gauge Attribute Chart" section of the JMP Documentation Library (page 4760 out of 7278)? Also how the example calculation using the data in Table 7.1 is done? Screenshots of the relevant JMP Documentation Library pages are attached.
The JMP help is not meant to teach statistical methods (or the reasoning behind the different methodologies). That being said, if you want to understand the methodology search Inter-class correlation and Kappa.
