ADaskalo
Pattern Match
I'm trying to replace part of text and would appreciate help with the code.
I noticed that running jsl with old column name syntax takes a toll on running time.
I would like to make script a that takes my current jsl code and change it from this:
:Name( "col_name" )
To this:
:"col_name"n
I tried using Regex and Patt Match with no luck.
Does anyone know how to do this?
Re: Pattern Match
If you have a script like this
// this is comment
:Name("col_name");
:Name("col_name2");
You can definitely replace those :Name("colname") type of strings without removing the comments.
Script.jsl
Script2.jsl
path_to_file = "$DOWNLOADS/Script.jsl";
path_to_new_file = "$DOWNLOADS/Script2.jsl";
str = Load Text File(path_to_file);
new_str = Regex(str, ":Name\( (.+?) \)", ":\1n", GLOBALREPLACE);
// Write(new_str);
Save Text File(path_to_new_file, new_str);
Re: Pattern Match
Are you trying to do this with Search Script?
After replace
:Name\( (.+?) \)
:\1n
ADaskalo
Re: Pattern Match
No, I'm trying to do the exact same thing with Regex or Patt Match functions.
ADaskalo
Re: Pattern Match
After T/S for a few days I found there's no way to do this in jsl w/o losing the comments within the jsl code being rewritten.
So I wrote a code in python that do that instead
# This code will replace code in .jsl files that match the Regex in parameters dictionary (pattern(1) and repl(2)) below.
# It is based on the simple def replace(source, dest) function, with pattern now being the source and the repl as the dest.
# The pattern in this code is to replace old JMP column naming syntax to the new JMP column naming syntax,
# e.g :Name( "variable@property" ) into :"variable@property"n
# for jsl code to run more efficiently in JMP17 and above
import os
import re
import tkinter as tk
from tkinter import filedialog
root = tk.Tk()
root.withdraw()
WORKING_DIR = filedialog.askdirectory()
# pattern(1)
pattern = r':\s*Name\s*\(\s*"([^"]+)"\s*\)'
# repl(2)
repl = r':"\1"n'
parameters = {pattern: repl}
def pat_replace(pat, rep):
    for dname, dirs, files in os.walk(WORKING_DIR):
        for fname in files:
            if fname.endswith(".jsl"):
                fpath = os.path.join(dname, fname)
                with open(fpath, encoding="utf8") as f:
                    s = f.read()
                    s_out = re.sub(pat, rep, s)
                with open(fpath, "w", encoding="utf8") as f:
                    f.write(s_out)
for i, (key, value) in enumerate(parameters.items()):
    pat_replace(key, value)
Re: Pattern Match
// this is comment
:Name("col_name");
:Name("col_name2");
Script.jsl
Script2.jsl
// Write(new_str);
Craige_Hales
Re: Pattern Match
...and the complete script might look like this
WORKING_DIR = Pick Directory( "Select a directory" );
pattern = "\[:\s*Name\s*\(\s*"([^"]+)"\s*\)]\";
rep = "\[:"\1"n]\";
pat_replace = Function( {pat, rep},
	For Each( {f}, Files In Directory( WORKING_DIR, recursive(1) ),
		If( Ends With( f, ".jsl" ),
			f = WORKING_DIR || f;
			text = Load Text File( f );
			newtext = Regex( text, pat, rep, GLOBALREPLACE );
			If( newtext != text,
				Save Text File( f || ".new.jsl", newtext );
pat_replace( pattern, rep );
the "\[...]\" escape in JSL is NOT a perfect replacement for the
python r-string, though it does work for this example. In particular,
if the regex contains ]\ it will not work out without more escaping
magic.
The file is renamed when saved so if something goes wrong...you could
save to another directory, etc.
Recursive(1) includes subdirs, change as needed.
Craige
