david707
Pass a Script Variable into a New Script
Basically I am trying to use a for loop to imbed multiple scripts into a data table:
For( SV = 1, SV <= N Items( CL ), SV++,
	DT2 << New Script(
		Char(SV),
			For( x = 7, x <= N Items( ColLst ), x++,
				:Column(Char(ColLst[x])) << Hide (1);
			For( w = 1, w <= N Items( Lst ), w++,
				:Column(Char(CL[SV][w])) << Hide (0);
The problem is when one of these scripts run it doesn't know what SV is. I need a way of capturing SV from the main script and setting it into the New Script. For example if I replace SV with 1 all the imbedded scripts will work as if SV == 1, so I need the For Loop to "set" SV to the correct value for that script.
Hopefully this makes some kind of sense.
cwillden
Re: Pass a Script Variable into a New Script
Try this:
	Eval(Parse(Eval Insert("DT2 << New Script(
		Char(SV),
				:Column(Char(CL[^SV^][w])) << Hide (0);
-- Cameron Willden
ms
Super User (Alumni) ms
Try using Eval( Eval Expr(...Expr(SV)...)) to force pre-evaluation of SV (and CL if necessary).
david707
I tried:
	DT2 << New Script(
		Char(SV),
			For( x = 6, x <= N Items( ColLst ), x++,
					Eval(
						Eval Expr(
							Expr(
								CL[
									Eval(
										Eval Expr(
											Expr(SV)
				), w++,
				:Column(
					Char(
						Eval(
							Eval Expr(
								CL[
									Eval(
										Eval Expr(
											Expr(SV)
								][w]
				) << Hide (0);
The error is:
Subscript Range in access or evaluation of 'Subscript' , CL[/*###*/Eval( Eval Expr( Expr( SV ) ) )]
cwillden
Try this:
		Char(SV),
-- Cameron Willden
akopel
In general you can use this method to pass variable into a script:
Eval (eval expr(
	dt << New script (
		"name",
		Bivariate(
			Y(expr(col_var)),
			X(expr(col_list_var))
