joshua
Parsing strings creating filter condition from excel and applying to it to datatable
JSL: how to create a reference to a table variable inside a column formula
I would like to build custom formula sheet that I can modify and apply to data table.
Say have a sheet-like in the attachment.
Formula Sheet
and would like concatenate this formula so that I can apply to selectwhere.
I come with for loop idea below but I cannot figure it out how to parse it to selectwhere
dt = open("$SAMPLE_DATA/Cars.jmp")
formula_Sheet = open("C:\Formula_Sheet.xlsx",
	Worksheet Settings(
                                            1,
     Has Column Headers( 1 )
condition_list = {}
For( i = 1, i <= Nrows( formula_Sheet ), i++,
	Make_col = formula_Sheet:Name("column_name")[i] ;
	filter_state = formula_Sheet:Name("filter_state")[i] ;
	filter_1 = formula_Sheet:Name("filter_1")[i] ;
	combined_filter_cond[i] = select where(:Name(\!""||Make_col[i]||"\!")"\!||Filter_state"\!||Filter_1"\!)";
	condition_list = insert(combined_filter_cond[i])
//This is the final selection code should look like dt << selectwhere((contains(:Name("Make"), "Honda") | !contains(:Name("D/P"), "Driver") | :Name("doors")>=2))
I would appreciate if admins can help on this ?
Re: Parsing strings creating filter condition from excel and applying to it to datatable
Here is my rework of your script, to generate the selections from the cars data table.cars.PNG
names default to here(1);
dt = open("$SAMPLE_DATA/Cars.jmp");
	Worksheet Settings(
                                            1,
//formula_Sheet =data table("DATA_for_SAS_community");
theExpr = "dt << selectwhere(";
For( i = 1, i <= N Rows( formula_Sheet ), i++,
	If( formula_Sheet:column_name[i] != "",
		If( i > 1,
			theExpr = theExpr || "| "
	If( Contains( formula_Sheet:filter_state[i], "contain" ),
		theExpr = theExpr || formula_Sheet:filter_state[i] || "s(:Name(\!"" || formula_Sheet:column_name[i] || "\!"), \!"" || formula_Sheet:Filter_1
		[i] || "\!")",
		theExpr = theExpr || ":Name(\!"" || formula_Sheet:column_name[i] || "\!") " || formula_Sheet:filter_state[i] || formula_Sheet:Filter_1[i]
theExpr = theExpr || ");";
Eval( Parse( theExpr ) );
	Worksheet Settings(
                                            1,
		If( i > 1,
		[i] || "\!")",
joshua
Hi Jim,
This is the exactly solution that I'm looking for. Thank you very much coming and providing solution for this late in the night. You are a true expert!
